Oct 30, 2009, 02:18 PM
Personal Sales Rating: ( 0)
2005 Mitsubishi Lancer Evolution
Drives: 2005 Evolution VIII
Braking issue at 65+
Here is the issue im having. its an 05 Evo that has recently been acting up when braking at 65+. Anything under than and the brakes are solid and can easily stop the car. Once I get to 65 and touch the brakes the pedal is rock solid and gives me feedback like the ABS is kicking in. Once the speed drops back below 60 the brakes go back to normal. I can reproduce this issue over and over and so far everyone ive asked seems puzzled. There is not a CEL or Anit Lock light on while driving normal and staying under 65. But if i hit the highway and cruise over 65 is when i get a Anti lock light that comes on. And to make things worse, once the light comes on and im over that 65 the brakes seem fine.
So, im stumped and i dont feel like getting bent over by the dealership and pay them to find nothing.
Any ideas?
__________________
05 Evo VIII- AMS 2.3L Stroker motor, PPI Ported Intake Manifold and Throttle Body, TurboTrix Stage 2 Race Trans, Fully built Transfer Case and Evo 9 Rear, CBRD BBK, 1000cc injectors,Crower Stage 3/272 cams, ACT 6 Puck Clutch kit, AMS Race FMIC, AMS TB Exhaust (no cat), Walbro 255lph FP, GReddy EBC, K&N Typhoon Intake, Hochtkis Lowering springs w/rear sway bar. 438AWHP on the old FP Green. Tuning by Turbo Trix
Offline
Oct 30, 2009, 02:26 PM
Personal Sales Rating: ( 2)
Perhaps a wheel speed sensor malfunction... something along those lines.
Does the ABS work like normal at speeds below 65?
Does the light go away on its own immediately when you drop speed? Does it stay on for a while?
Dan
__________________
Professional Awesome Time Attack
2001 Mitsubishi Evolution VII
2nd Overall 2009 Redline Street AWD East Coast
www.ProfessionalAwesome.com
MA Performance
T1 Race Development
JRZ Suspension
Offline
Oct 30, 2009, 02:29 PM
i can slam down on the brakes at any speed below 65 and not have an issue.. i had the car out in some heavy rain in an open lot and was seeing if the abs worked at like 35-40 and it was fine. The light will come on once i cruise over 65 for about a mile and stay on until i shut the car off.. once restarted no light.
__________________
Offline
Oct 30, 2009, 03:00 PM
I have not personally done this, I can check when I get home, but I THINK EvoScan can check ABS codes.
See if you can find someone (perhaps the folks that tuned the car) with EvoScan to check for codes before the light goes away. Should tell you exactly what's wrong. If not, Mitsu can probably scan it for like $40 dollars or so...
Dan
Offline
Oct 30, 2009, 07:38 PM
Drives: Turbo Mirage (for sale), 03 TB VIII (RIP), 05 AS VIII
Even if the light isn't currently on, the car with "store" the code, so code readers with still be able to see them. I'd check it with some sort of reader that with read ABS codes.
__________________
-Rich-
2003 Tarmac Black Evo VIII (R.I.P.)
2005 Apex Silver Evo VIII
CBRD tuned:
331whp / 319wtq @ 24psi on 93 oct.
My Photography
Offline
Nov 2, 2009, 06:53 AM
It does look like you can use EvoScan to check for ABS codes. I ran a test and it seemed to work, but I have no codes so I cannot verify.
Dan
Offline
Nov 2, 2009, 10:03 AM
Mitsu ran the code, its my Right Front ABS Sensor. New the sensor is like 350 so i guess ill be hunting for a used one on here..
__________________
Offline
Nov 3, 2009, 08:48 AM
Drives: '03 Evo 8, '04 WRX
Quote:
In the mean time take a look at the one on there now. It might just need a little attention.
Offline
Nov 3, 2009, 01:31 PM
It is very uncommon for an ABS sensor to fail especially on a car as new as yours. Might just need to hit it with some brake cleaner or something.
__________________
Wicked White IX
AWD Built (673whp/503wtq)
Offline
Nov 4, 2009, 09:22 AM
Or perhaps the wire was damaged, look to see if anything snagged the line.
Dan
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
