Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 30, 2009, 12:11 PM   #1
Personal Sales Rating: (0)
09Ralli's Avatar
Drives: 2006 Evolution 9 Special Edition
Need a answer hawk pads and brembo rotor slotted or drilled? or stock?front or Rear?
as title says i really dont know what to do, ive been reading on here for about three hours now and still dont know what to do, all the sort of informing threads were from 2003 or later...my car shakes when i hit the brakes at anything over about 60mph pretty bad, when i brake slowly it kind of feels like the rotors are warped because it kind of skips, are the oem rotors brembo or the pads? what should i get hawk hps pads and brembo rotors from lancershop, drilled or slotted? should i get just front or does the rear need it too? any other rotors, i am a road driver.....please help
Offline
Old Oct 30, 2009, 12:14 PM   #2
Personal Sales Rating: (31)
boomn29's Avatar
Drives: 03 Apex Silver Evo VIII - 05 WRB/Gold STi (both gone) - 06 EB Evo IX
Send a message via AIM to boomn29
First up - I'd do a proper 'bed in' process. That'll at least narrow down any potential issues.
If you do need or simply want to rotors, you don't need drilled or slotted really. I'd hit one of the vendors up on the forums - KNSBrakes or Girodisc for example - and they'll hook you up. Tell them how you use the car and they won't recommend anything crazy or $$.
__________________
06 EB Evo IX
#929 TTB (MW/GL) & Redline Street
AMS Tuned
AMSOIL
2009 Racing Blog! or Twitter
Offline
Old Oct 30, 2009, 12:14 PM   #3
Personal Sales Rating: (1)
rocknsnoboarder's Avatar
Drives: 2006 Evo IX
I just got the hawk hps pads and had the same problem with my rotors shaking.
If you are only doing street driving just get another set of blank rotors. If you try to get the stock brembo ones you're going to pay an arm and a leg. Check out the guys at KNS Brakes. They hooked me up with a set of Centric rotors for real cheap.
__________________
13.14 at 109 mph
Injen intake, upper/lower intercooler pipes, ams underhood shifter bushings, forge unos mbc, act 2600 clutch and streetlight flywheel, ams tbe with test pipe, ams base flash
Offline
Old Oct 30, 2009, 12:27 PM   #4
09Ralli's Avatar
thanks guys, i will check out kns and try a bed in process, i will discuss results after the bed in process, i just dont want to pay a arm and a leg for brakes, i researched on here some of the people love the hawk hps pads and some really hate them, idk what to do on the pad situation if bed in dont fix anything
Offline
Old Oct 30, 2009, 12:29 PM   #5
Personal Sales Rating: (3)
Drives: EVo8 2004
people are quick to say the rotors are warped. Most likely due to brake dust buildup. I would do a couple 110 - 60 braking. It should fix the problem.
__________________
Injen Intake and UICP, GSC S1's, ARP Studs, Hallman MBC: 23psi, Helix DP, Magnaflow Cat, HKS Hi Flo Catback, Walbro Fuel Pump, ISP Tune, Mach V Exhaust Manifold, 10.5 hotside, 02 housing, IX Turbo, ACT Clutch, Sparco Catch Can, Powerflex Motor mount, ETS 3" FMIC, ETS LICP, SHEP trans, Megan Coilovers
Offline
Old Oct 30, 2009, 12:34 PM   #6
09Ralli's Avatar
thank you for all the help, i am on the kns website, are these any better than stock?
http://http://www.knsbrakes.com/prod...616&car_id=793
Offline
Old Oct 30, 2009, 12:49 PM   #7
Drives: 2006 Evo IX
link doesn't work.
look up kns profile on here. They have a screen name you can use for AIM. I spent about 5 minutes talking to them discussing my mods and how I drive the car and they had them ordered and shipped out that same day.
__________________
13.14 at 109 mph
Offline
Old Oct 30, 2009, 12:50 PM   #8
Personal Sales Rating: (15)
grillpt's Avatar
Drives: 2004 Accord LX / 03 Apex Silver= Its back Baby!!
Quote:
Don't listen to this man. Sorry Evoterp, but I don't suggest he do 110-60mph stops. That is not the correct way to bed pads.
Your options are endless on pads and rotors. Centric blanks are fine, pair them up with a good street pad, bed them properly and you'll be fine. I couldn't follow the link you posted so I don't know what you were trying to show... Hawk HPS aren't bad, but not great either, they are cheap if your on a budget. Otherwise, I suggest Satisfied GS5, RacingBrake ET300, Axxis ULT. All good pads from what I've been told.
Offline
Old Oct 30, 2009, 12:57 PM   #9
09Ralli's Avatar
sorry here try this
http://www.knsbrakes.com/productDeta...616&car_id=793
Offline
Old Oct 30, 2009, 12:58 PM   #10
Personal Sales Rating: (4)
Drives: TB IX
Buy blanks from NAPA. They work just fine and are a lot cheaper than those name brand ones. Rears for my WRX were $22 each.
Offline
Old Oct 30, 2009, 01:08 PM   #11
EvoM Super Moderator
2002 Ford Focus
SmikeEvo's Avatar
Drives: 2002 SVTF, 2006 Honda Aero, 2008 Lancer GTS, 2006 Galant GTS
Send a message via AIM to SmikeEvo
Pad material transfer - warped feeling. Spec your rotors. They can be turned if they have enough meat on them. Then re-bed your pads.
Hawk HPS pads are crap.
The Brake Rotor, Pad, Line, Fluid, and Duct Thread
Get blanks from a number of vendors here and a good set of pads. Slotted/drilled cannot be turned if need be.
__________________
***New Points System and Forum Rules***
Problem with a post or thread? Use the report post button - triangle sign on the bottom left.
SmikeEvo Racing Blog
Sponsored by:
Swift Springs
GTWorx
Offline
Old Oct 30, 2009, 01:14 PM   #12
09Ralli's Avatar
okay so basically what i got out of these, is first bed process, if it dont fix the problem get blank cheap rotors, maybe from kns? and hawk hps pads suck, so get which pads? i am a road driver and dont want a squeal
Offline
Old Oct 30, 2009, 01:15 PM   #13
grillpt's Avatar
Those rotors should be fine for your app. Like Smike said, most likely what your experiencing is pad transfer not actual rotor warpage. Any of the three pads I suggest should be fine. I know Smike is big on the Satisfied GS5's, try them.
Offline
Old Oct 30, 2009, 01:21 PM   #14
09Ralli's Avatar
okay i really appreciate all of the help, so pad transfer? maybe a quick lesson on that meaning?
Offline
Old Oct 30, 2009, 01:24 PM   #15
grillpt's Avatar
Brake pad material is transfering from the pad and embedding itself in the rotor causing a pulsing feeling when the brakes are applied.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
