Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 28, 2009, 10:50 AM   #1
Personal Sales Rating: (23)
yahu's Avatar
Drives: 06 Evo MR
spring install question
So I installed Spec-Rs yesterday and have a question that I'm hoping someone can answer. I referred to this guide for torque specs, etc. but after the front struts were reassembled with the new springs and reinstalled on the car I noticed "Step 13" and the "tech tip" plus picture included:
I looked up in the wheel well and the holes don't really line up. Plus, there are like 3 holes on the top. The way I installed the springs was to obviously line up the bottom/start of the spring where the notch is and then line up the top where the "clean" line was from the original spring.
I now realize that the Spec-R spring and the stock spring probably didn't end in the same spot, and am wondering if I need to pull the struts out again and align that top portion. Let me know if you have any advice! Thanks!
Offline
Old Oct 28, 2009, 11:16 AM   #2
Personal Sales Rating: (7)
vicksen's Avatar
Drives: evo IX MR
If you start to get a clunking noise from the front end you might want to reseat them, but otherwise you should be good. The main thing is to be sure they're properly set in the perches. In the pic they're using the KGB struts and it looks like the top plate just has a trough for the spring to rest in. In the top plate on your bilsteins that trough has a depression that you can butt the end of the spring up to.
Offline
Old Oct 28, 2009, 01:52 PM   #3
Personal Sales Rating: (30)
dbsears's Avatar
Drives: AS IX MR gripbox
Refer to this thread for more pics...gives an idea of how to align the top hat using a file.
Bilstein HD-02 and Swift Spec-R ... PICS!!!
Offline
Old Oct 28, 2009, 04:55 PM   #4
Personal Sales Rating: (4)
Drives: TB IX
If it isn't perfectly aligned you will be fine. If you are like me you won't be able to sleep knowing it isn't perfect and will have to take them out and do it over.
Post pics of you car with the springs on!
Offline
Old Oct 28, 2009, 04:59 PM   #5
EvoM Super Moderator
Personal Sales Rating: (3)
2002 Ford Focus
SmikeEvo's Avatar
Drives: 2002 SVTF, 2006 Honda Aero, 2008 Lancer GTS, 2006 Galant GTS
Send a message via AIM to SmikeEvo
You need to redo it. You can take the top rubber mount off of the top metal perch to adjust how it mates to the spring coil. You will have noises and its an improper install, which can lead to issues like shearing off the top nut.
__________________
***New Points System and Forum Rules***
Problem with a post or thread? Use the report post button - triangle sign on the bottom left.
SmikeEvo Racing Blog
Sponsored by:
Swift Springs
GTWorx
Offline
Old Oct 28, 2009, 05:15 PM   #6
yahu's Avatar
Drives: 06 Evo MR
Thanks, all. Smike, you are saying I have to do this with the struts removed, or are you saying I can do this with the car on the ground through the engine bay?
I'm not opposed to pulling them off again but finding the spring compressor was worse than I imagined and dealing with the buttcracks at Schucks/O'Reilly at Thrasher's corner almost resulted in an arrest last night...
Thanks again for the info!
*edit - btw thanks for moving this to the proper place - I was just trying to get help from my homeboys/homegirls in the PNW!
Offline
Old Oct 28, 2009, 05:20 PM   #7
2002 Ford Focus
SmikeEvo's Avatar
Have to pull off the car to do it right.
AutoZone or the like should have a compressor you can use or borrow.
__________________
Sponsored by:
Swift Springs
GTWorx
Offline
Old Oct 28, 2009, 05:45 PM   #8
yahu's Avatar
Drives: 06 Evo MR
^thanks Smike - there aren't any autozones close to me. I know where to get them, worst case. I'll have to find the time before I get an alignment.
BTW - thanks for the reviews and comments on the Spec-Rs. You are a large part of the reason I went with them after debating a couple different springs. I couldn't be happier at this point - kind of like driving the car for the first time with the ear-to-ear grin!
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
