Oct 27, 2009, 08:33 PM
Personal Sales Rating: ( 0)
Drives: 03 Evo
10mm spacers..which ones to get?
i need 10mm spacer, what are some good spacers to get? and how do they work? im used to the 20mm spacers that come with the extended bolts already mounted.
__________________
Buscher TBE/IX Turbo/Megan Manifold/Megan02/Walbro 255/AEM Intake/TurboXS MBC
Tuned By CWill at ASAP
Online
Oct 27, 2009, 08:36 PM
Personal Sales Rating: ( 2)
Drives: 96 Toyota Corolla DX, Tarmac Black Evo IX SE
ichiba slip on... I used H&R and they were good too but I'd say the ichiba are nicer IMO.
__________________
GST filter, Tanabe DP, Catless HKS Carbon Ti, Nisei LICP, FP Actuator, SS brake/clutch lines, RC 1000's, Whinebro
Sponsored by: GST Motorsports
304whp/292wtq @ 23psi on 91 oct- -376whp/357wtq @ 27psi on E85
Offline
Oct 27, 2009, 08:41 PM
Drives: 03 Evo
Quote:
the ichiba v1 with extended bolts?
__________________
Online
Oct 27, 2009, 08:45 PM
Personal Sales Rating: ( 14)
Drives: 2003 VIII, 1987 E30
Ichibas are very nice, I have a set of the 20mm. Mike @ Touge Factory will hook you up!
__________________
Philadelphia Region SCCA - #107BSP
PeteyTurbo Tuned|krazyhousecustoms.com
Offline
Oct 27, 2009, 08:48 PM
Personal Sales Rating: ( 8)
Drives: 2005 TB Evo 8, 1992 Eagle Talon TSI AWD
I am going with the Kics 10mm spacers with built in studs from touge factory. Although they wont work with all wheels though. They will be nice and easy and easily removable also.
Offline
Oct 27, 2009, 08:55 PM
Drives: 03 Evo
thanks guys, im just wondering how the 10mm ichibas work since the studs are not built in??
__________________
Online
Oct 28, 2009, 07:13 AM
Quote:
You have to get extended studs, and replace the stock ones on your car. Not hard task, but pays dividends later on. I recommend ARP extended studs (ARP 100-7717)
__________________
Offline
Oct 28, 2009, 09:09 AM
Eibach makes some good ones as well... +1 for Ichiba though
Offline
Oct 28, 2009, 09:20 AM
Drives: 03 Evo
So the ichiba 10mm says they come with extended studs. So I just replace those with my studs that are on the car?
__________________
Online
Oct 28, 2009, 10:52 AM
Yes!
__________________
Offline
Oct 28, 2009, 01:26 PM
Personal Sales Rating: ( 1)
Offline
Oct 28, 2009, 01:47 PM
Touge Factory also carries aluminum hubcentric rings if you are running aftermarket wheels. The hubcentric spacers are made with a 67.1mm bore to be hubcentric to the stock wheels, so if you are planning to run aftermarket wheels, do yourself a favor and ask for the rings. They're only $20 for a pack of 4...blue anodized too
__________________
Offline
Oct 28, 2009, 04:11 PM
Drives: 03 Evo
thanks alot guys. ok so i have bbs lm 17x9 +35. will i need the hubcentric rings? and also how do i take of the oem studs of the car?
__________________
Online
Oct 28, 2009, 04:14 PM
Yes, you will need the hubcentric spacers. As for the studs, take the brake calipers off, rotors off, use a hammer and bang the studs out. Pretty simple.
__________________
Offline
Oct 28, 2009, 04:18 PM
Drives: 03 Evo
Quote:
cool, you know what size i will need for the hubcentric spacers?
__________________
Online
Tags
10, 10mm, e30, evo, extended, hr, ichiba, mm, spacer, spacers, studs  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
