Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 22, 2009, 05:18 PM   #1
Personal Sales Rating: (0)
Drives: 2003 EVO VIII
Some opinions
So I'm looking to buy some new tires for my stock 17x8 Rims on my VIII. Is there much of a difference/which would you get if you were to choose from 235/40/17 or 235/45/17. Thanks.
Offline
Old Oct 22, 2009, 05:30 PM   #2
EvoM Moderator
Personal Sales Rating: (18)
Neal@tirerack.'s Avatar
Drives: 2006 Audi A4 Quattro 2007 Mazda CX-9
The 40s are a bit short. Many use a 245/40-17 if you want to run 40's.
__________________
Neal, Sales Representative
1-877-522-8473 ext 624
www.tirerack.com
Offline
Old Oct 22, 2009, 06:01 PM   #3
chu
Personal Sales Rating: (14)
chu's Avatar
Drives: 2003 VIII, 1987 E30
Or 255/47/17
__________________
Philadelphia Region SCCA - 2010=new number/new class
PeteyTurbo Tuned|krazyhousecustoms.com
Offline
Old Oct 22, 2009, 06:21 PM   #4
Personal Sales Rating: (1)
Drives: 2003 Evo 8
the 245/40r17 is about as wide as you might wanna go under stock fenders its a shorter sidewall but you get a slightly wider tires...obviously. But it all depends on if you want your speedometer to be off or not. But the 245/40R17 is about the limit you want for your rim size and fender space. especially if you have springs that drop your car and inch or so
Offline
Old Oct 22, 2009, 06:47 PM   #5
EvoM Super Moderator
Personal Sales Rating: (3)
2002 Ford Focus
SmikeEvo's Avatar
Drives: 2002 SVTF, 2006 Honda Aero, 2008 Lancer GTS, 2006 Galant GTS
Send a message via AIM to SmikeEvo
235/45
245/45 (depending on tire - some rub)
245/40
255/40
All fit. Each as their own application.
Search and read. One of these most commonly asked questions.
__________________
***New Points System and Forum Rules***
Problem with a post or thread? Use the report post button - triangle sign on the bottom left.
SmikeEvo Racing Blog
Sponsored by:
Swift Springs
GTWorx
Online
Old Oct 22, 2009, 08:15 PM   #6
barneyb's Avatar
Drives: '03 Evo 8, '04 WRX
Nobody is going to like this idea but it works. If you are going for handling and not for looks then 225/45-17. A tire this size has sidewalls the slope inward from the rim. It is like having more negative camber. It may be the correct size for the Evo with stock rims.
Offline
Old Oct 22, 2009, 08:58 PM   #7
Personal Sales Rating: (26)
gsrboi80's Avatar
Drives: 03 TB VIII
Only times most run the 225s are on snowies in the winter. Skinnier tire def better in snow and muck in my expierience. Im def Not a tire guru though
__________________
4WS TUNED VIII
Quote:
Originally Posted by Evoryder View Post
Its' the turbo punching out for the day
Online
Old Oct 23, 2009, 06:44 AM   #8
2002 Ford Focus
SmikeEvo's Avatar
Wut?
In terms of ultimate grip, wider is better for tarmac. Snow - thinner. Turn in response, shorter sidewall/stiffer sidewall.
__________________
Sponsored by:
Swift Springs
GTWorx
Online
Old Oct 23, 2009, 06:32 PM   #9
barneyb's Avatar
Quote:
Originally Posted by SmikeEvo View Post
Wut?
Wut? - I like that.
I don't know about ultimate grip - no way to test that, but I am running around Goodyear Eagle GT HR's in the 225x45-17 size and they are handling upgrade over the Potenza RE01R's I just pulled off. These Goodyears have a tread wear rating of 440!
BTW, did you see Myth Busters the other night where they made a dimpled car like a golf ball and got better gas mileage. You never know until you try it.
Offline
Old Oct 23, 2009, 06:40 PM   #10
Personal Sales Rating: (23)
yahu's Avatar
Drives: 06 Evo MR
^I think Smike is referring to 255 vs your 225. When you went from RE01Rs, were they also 225? If so, that isn't the width having an effect on hadling upgrade, that is the comp/tread.
BTW - when you say handling upgrade do you mean rides nicer or grips better?
Offline
Old Oct 23, 2009, 06:47 PM   #11
2002 Ford Focus
SmikeEvo's Avatar
255 to 225 is a 1.2in difference. No way they will have more grip, with compounds being the same. And yes, that is testable - skid pad.
And REO1Rs are most definitely stickier than Eagle GTs. And I am running the Eagle GTs on my SVTF.
Tires degrade over time. Heat cycling and wear decrease grip. So you might feel they are better, but thats because they are newer.
That being said, I have AX'd the crap out of my Eagle GTs this year. Wet and dry. Actually did quiet well. But I lost 2s to similar cars on Z1*s.
__________________
Sponsored by:
Swift Springs
GTWorx
Online
Old Oct 23, 2009, 07:43 PM   #12
barneyb's Avatar
Well, I'm not going to be going to a skid pad. I'm pretty sure the RE01R's would win there.
What I found was lack of road wander, improved steering precision and much better turn-in, qualities valued on the street. I got spoiled by the stockers but these tires come pretty close in the turn-in department.
Maybe I am wrong in attributing the difference to the stand up sidewalls and Goodyear just decided to make a really good tire. Tire Rack didn't have much good to say about them.
As for the REO1R's, they went on last spring in stock size. I made the mistake of shooting off my mouth about how it did my own alignment back then and the tire shop people remembered. So, when the tires were being dismounted there were also two managers out there. It looked like a football huddle as they examined the tread wear. Well, they concluded I knew what I was doing. The stones still look like new.
All else I can tell you is that I am having a blast on these new tires.
Offline
Old Oct 24, 2009, 05:18 AM   #13
2002 Ford Focus
SmikeEvo's Avatar
The Evo loves to track ruts. Going to a wider tire can make the sensation worse. A wider tire will also decrease turn in response. Ultimate grip is the amount of available grip at maximum lateral load (breakaway - 255s should be able to take more...also compound dependent).
The Eagle GTs have a very stiff sidewall. I have a XL load version on my car. So even stiffer. I like them more than the GY F1 All-Season I ran on my Evo.
__________________
Sponsored by:
Swift Springs
GTWorx
Online
Old Oct 24, 2009, 10:01 AM   #14
barneyb's Avatar
This a little off of the subject but since this thread is titled "Opinions" here goes.
I am old enough to have run some of the first radial tires marketed in the USA. After bias tires radials were a revolution in ride and handling.
A radial tire has most of its cords under the tread instead of having the same amount everywhere as in a bias tire. This make for thin sidewalls that dissipate heat. It also made the sidewalls flexible which caused the tires to look low on air when inflated to the proper pressure.
Now along comes radials with stiff sidewalls. Well, there are two ways of keeping a tire cool at high speeds: make the sidewalls thin enough to dissipate the heat or make the sidewalls so stiff they don't flex and therefore don't generate heat. Stiff sidewalls have the added benefit of better turn-in.
Go to a tire store and browse and you find most tires of the thin flexible sidewall type. I suggest these soon will be gone as all tires go to the stiff sidewall type. The next revolution in tires is now occurring.
Offline
Old Oct 24, 2009, 11:25 AM   #15
2002 Ford Focus
SmikeEvo's Avatar
There is a lot of engineering that is goes into tires. Not everyone is going to want a stiff sidewall. The internal carcass depends on components use. We are seeing new kevlar/carbon fiber carcasses. Lots of cool things happening.
__________________
Sponsored by:
Swift Springs
GTWorx
Online
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
