Oct 6, 2009, 05:35 PM
Personal Sales Rating: ( 1)
Drives: Evo 9 MR
camber plates BROKE MY STRUT!!!!!!
Offline
Oct 6, 2009, 05:36 PM
Personal Sales Rating: ( 3)
2002 Ford Focus
Drives: 2002 SVTF, 2006 Honda Aero, 2008 Lancer GTS, 2006 Galant GTS
What ft/lb were they torqued to?
What camber plates are those? Were they meant for that sort of application?
Offline
Oct 6, 2009, 05:39 PM
Personal Sales Rating: ( 42)
Drives: evo 1 gsr/ evo ix mr 5spd
Damn, I was looking for a set of those nolec plates  Maybe i should rethik this
__________________
The good die young and the pricks live forever!
-Lewis black
Offline
Oct 6, 2009, 06:05 PM
Drives: Evo 9 MR
noltec or something.ment for stock strut, and i didnt sit there with the impact gun on it. just gave it a quick zap with an electric impact gun./ SSCCOOTTT runs them w.o problems. really not happy. if any1 has A bilstein who wants to sell it cheap. and its now blow up. please let me know
Offline
Oct 6, 2009, 06:51 PM
2002 Ford Focus
Quote:
That is problem 1. Never, never, ever, use an impact gun there. That nut is a only 45+/-7 ft/lbs. An impact will over tighten that even in one zap.
You might be able to have the thread welded back on.
I think the camber plate might have been installed wrong too.
Offline
Oct 6, 2009, 06:58 PM
2002 Ford Focus
Option C - you cross-threaded the bolt and it was not actually tightened. You then had play in the camber plate and that caused the snap on a bump.
Offline
Oct 6, 2009, 07:02 PM
Drives: Evo 9 MR
3/8th impact. i didnt specify.lol. its an old school snap on, it cant even take of wheels. wasnt cross threaded.. the plates come as they are. ready to install. nothing what cross threaded. i can still pull the nut out of whats left of my old strut, by hand. it threads and unthreads
Offline
Oct 6, 2009, 07:06 PM
2002 Ford Focus
How did you tighten down the camber plate? Did you use a spring compressor or the cars weight to push the spring down? If you did not have the spring compressed when installing there would be a gap (or too loose of a bolt).
Looking at your first pictures. The bolt does not look threaded enough at all. Nothing is sticking up on the top side.
Offline
Oct 6, 2009, 07:25 PM
Drives: Evo 9 MR
huh.. i had to pull the whole stut assembly out. spring compressor was used. the bolt was loosened by hand to show the brokeness of the strut in the pic.
Offline
Oct 7, 2009, 04:46 AM
2002 Ford Focus
When you were tightening that nut - the springs were compressed?
Offline
Oct 7, 2009, 07:16 AM
Personal Sales Rating: ( 7)
Drives: Dust collecting boosted Civic, '03 Evo8, 09 Audi A3
you're asking about preload the spring for installation- which should be done.
__________________
BOOST doesn't get you laid. Roofies and some creativity does however
*STOP* - selling something with an "Easy fix" if it's easy, just freaking fix it then sell it!
*STOP* - posting stock evos, just because you took your wing off it's not new thread worthy.
Offline
Oct 7, 2009, 08:00 AM
2002 Ford Focus
Yep. Im leaning towards installation error (no offense) either too much tq on the top nut or too loose. Both would shear the threaded shaft.
Offline
Oct 7, 2009, 11:42 AM
2006 Mitsubishi Lancer Evolution My Garage
Drives: every chance I get
Sorry to see that this happened to you after I recommended these plates. I've had them on for about 5k mi without any issues so far, it looks like the strut shaft was either twisted from excessive torque/cross threading or got bent during install and became weak. Did you buy these used? If so it's possible that the shaft was weakened by the last person who had them. First thing I'd do is unscrew the nut from the piece of the end of the shaft and see if the nut was cross threaded.
__________________
- Scott
TBIXSE
Sponsored by: DG Motors
[X] Daily Commute
[X] Trackday
[X] Auto-x (NYR-SCCA #31 STU)
[X] Rally-x (PSCC #31 SA)
[X] Time Attack (RTA #131 SA)
[_ ] Hill Climb
Offline
Oct 7, 2009, 11:58 AM
Silver Sponsor
Personal Sales Rating: ( 20)
Drives: 2004 STi
you can also send it to Bilstein to get fixed.
- andrew
Offline
Oct 7, 2009, 01:14 PM
Personal Sales Rating: ( 14)
Drives: 2003 VIII, 1987 E30
Quote:
- andrew
Might as well send all four and ge custom valving done!
__________________
Philadelphia Region SCCA - #107BSP
PeteyTurbo Tuned|krazyhousecustoms.com
Offline
Tags
broke, camber, evo, focus, ford, front, install, installation, manchester, nh, plate, plates, snap, strut, whiteline  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
