do i need a fender roll with this offset and wheel?
Old Sep 16, 2009, 11:44 AM
vietdragontekx's Avatar
im planning to buy the rota p45r with 30 offset 17 inch, and planning to put 245/45/17 on them. im lower on tein stech spring. do i need a fender roll or im fine with it?
should i go with 255/45/17?
Old Sep 16, 2009, 04:25 PM
anyone?
Old Sep 16, 2009, 04:30 PM
ChuckP's Avatar
how wide?
255 will rub
245 will be cutting it close
Old Sep 16, 2009, 04:40 PM
pfunk47's Avatar
I run 265/35/18 +30 offset on Tein flex coilovers, I had to roll as I had minimal rub on large bumps, still get a little rub if I slam hard on the highway - I live in MI, roads are horrible. Many people run this setup and experience no rub, with 245's you should be fine.
Old Sep 16, 2009, 04:42 PM
Spunkysandoval's Avatar
what is the width of the width of the wheel?
Old Sep 16, 2009, 04:48 PM
ChuckP's Avatar
Need to take a few thing into account:
Wheel width
ride height
amount of camber
different tires have different widths.
Old Sep 16, 2009, 05:03 PM
Evo8motorS's Avatar
255 45 17 will fit with your tein setup you will just need a litle bit of negative camber front & rear
Old Sep 16, 2009, 07:02 PM
Wheel width
ride height
amount of camber
wheel width is 9.5
ride high im not sure what the spec of tein stech is
not sure of camber either.
Old Sep 17, 2009, 09:21 AM
BoostedXevo's Avatar
I would still get rolled... it seems like that spec will get you rubbing. Especially most likely when you hit a bump
Old Sep 17, 2009, 11:57 AM
WheelDude.com's Avatar
I would highly recommend a different tire size for these wheels. A 245/40/17 tire would be ideal or even a 255/40/17 tire (will definiately require fender rolling with this wheel). A 245/45/17 tire is taller than your OEM diameter and may rub on the fender liner if your car is lowered.
If you don't want to modify your fenders then I would recommend the Rota DPT in 17x9 +35 fitment. This model is ~2 lbs lighter than the P45R (DPT is only 19.1 lbs) and will fit without modifications. We have customers running very wide 255/40/17 tires on stock fenders
Here's how this setup looks
-Dan
Old Sep 17, 2009, 12:15 PM
-Dan
thx =) but yeh i just bought the p45r 17x9.5 with 30 offset from my friend. so you saying 245/40/17 won't require a fender roll?
Old Sep 17, 2009, 01:14 PM
mr.paick's Avatar
beautiful shots
Old Sep 20, 2009, 11:20 PM
soevo's Avatar
I would roll them anyways to avoid issues when adjusting your suspension in the future.
Old Sep 21, 2009, 07:01 AM
chaotichoax's Avatar
my car is famous woohoo
with the +30 definitely roll them
Old Sep 22, 2009, 01:40 AM
do i need to roll front too? or just the rear?
tatsuIX
11
Jul 18, 2016 10:18 PM
sflemming12
Apr 19, 2016 02:48 PM
thatevo8
Nov 17, 2013 10:54 AM
Deanjobs666
Mar 12, 2013 01:16 AM
It'sMe
11
Jan 5, 2012 04:29 AM
Quick Reply: do i need a fender roll with this offset and wheel?
