Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Sep 12, 2009, 04:41 PM   #1
Personal Sales Rating: (0)
evol ways's Avatar
Drives: 06 Evo MR SE
what the correct tire pressure?
just noticed my front driver side tire is a little low on air and would like to bump up the pressure but just not sure if i should still use the factory recomended tire pressure on a 255/35/18 tire sitting on 18x9.5+30offset rim so what pressure should i set the tire to? thanks. cars a DD
Offline
Old Sep 13, 2009, 01:06 PM   #2
Drives: Blue by You Evo
There is not just one answer to this question. Think of tire pressures as a dynamic thing, they are constantly changing as you drive your car. Thats why the tire says Cold pressure on the side of it, the pressure will rise after driving on the tire due to friction.
The Factory recommended pressures are what mitsu felt made the vehicle vary safe and stable to drive in all conditions and with all types of drivers. I don't recommend using there pressure specs.
I run 35 cold psi in all four tires, in my daily driven Evo with 245/40r17 tires. I use that spec on the commute to and from work, and also for AutoX. The car feels very neutral and firm. I would bet something real close to that would work just fine for you. You could go lower down to 32 or 30 if you wanted the ride smoother, but it would cause the side wall to flex more during spirited driving. You could go more then 35 if you were looking for a really firm ride and real sharp response.
__________________
WARNING: Car May Cause Heavy Right Foot Syndrome
Offline
Old Sep 13, 2009, 02:39 PM   #3
Personal Sales Rating: (15)
Kracka's Avatar
Drives: Wicked White Evo IX GSR
Send a message via AIM to Kracka
Tire pressure all depends on the tire, tire size, the driver, how the cars driven, your other suspension components, etc. You need to figure out for yourself what best suits you, and how making certain changes affects the cars balance.
Here is what I run:
Evo IX GSR w/KYB shocks, Swift Sport springs, Whiteline 24mm rear anti-sway bar in the stiffest setting, 245/45-17 Sumitomo HTRZ III tires
street = 38 psi (front) / 35 psi (rear)
autox = 45 psi (front) / 43 psi (rear)
If I still had the stock rear swaybar I'd run more pressure in the rear to help get the car to have a more neutral feel rather than the stock tendency towards understeer.
__________________
*formerly S2kracka*
Offline
Old Sep 14, 2009, 06:47 AM   #4
EvoM Moderator
Personal Sales Rating: (18)
Neal@tirerack.'s Avatar
Drives: 2006 Audi A4 Quattro 2007 Mazda CX-9
Start at oe as that size holds the same amount of air as the 17", just in a different shape. From there tune up to get the feel you desire. Don't exceed the tire max psi listed on the sidewall, don't drop below Mitsu's recommendation.
__________________
Neal, Sales Representative
1-877-522-8473 ext 624
www.tirerack.com
Offline
Old Sep 14, 2009, 09:23 AM   #5
Personal Sales Rating: (14)
Ludikraut's Avatar
Drives: 03 Evo VIII, 04 A8L, 00 A4 1.8T, 08 R32, 82 YF750
I run my 265/35 Eagle GS-D3 tires at 38 psi all around for street use. Most lower profile tires will need more pressure than the stock tire. If you look at various cars that come with different tire/wheel combos from the factory, (like Audi and BMW for example) you'll generally see something like 32 psi (+/-2) for something like a 45R17 and 36 (+/-2) for a 35R18. On my wife's R32 I use 32 psi for the 17" winter tires and 38 (per factory recommendation) for the stock 18" tire.
l8r)
__________________
"Learning is the beginning of knowledge ...
knowledge is the beginning of understanding ...
understanding is the beginning of wisdom."
Suspension book for sale, NEW
Quote:
Any society that would give up a little bit of liberty to gain a little bit of security will deserve neither and lose both.
- Ben Franklin, Thomas Jefferson -
Offline
Old Oct 30, 2009, 11:05 AM   #6
Personal Sales Rating: (1)
Drives: Evo IX
Is the recommended tire pressure for 265/35R18 38PSI cold?
__________________
Current hardware :
EvoRed turbo with BB conversion
2.2L stage 4 shortblock + stage 3 head
Kelford 272 cams
3.5" Bar and Plate FMIC
Motec M800 fully optioned
Ohlins Flag L with Swift springs
Swift swaybars
18" RE30 and 265/35R18 semi slicks
Alcon BBK
Coming soon :
Dual denso supra pumps in custom fuel surge tank
HFS-5 meth kit
CF driveshaft
Titanium catback exhaust system
Offline
Old Oct 30, 2009, 12:18 PM   #7
Personal Sales Rating: (31)
boomn29's Avatar
Drives: 03 Apex Silver Evo VIII - 05 WRB/Gold STi (both gone) - 06 EB Evo IX
Send a message via AIM to boomn29
Personally, I always run lower. I've always gotten better wear. Something like 32-35psi cold on everything I drive.
Heck back on my Toyota Celica's (factory Yokohama performance tires) I ran 34 all around and had severely uneven wear down the middle. The next set I ran 32f / 27r - sounded crazy but the rear was sooo light in that hatchback and the tires wore like a dream. 30k miles and still looked to have 1/2 the treadlife left.
__________________
06 EB Evo IX
#929 TTB (MW/GL) & Redline Street
AMS Tuned
AMSOIL
2009 Racing Blog! or Twitter
Offline
Old Oct 30, 2009, 01:11 PM   #8
EvoM Super Moderator
Personal Sales Rating: (3)
2002 Ford Focus
SmikeEvo's Avatar
Drives: 2002 SVTF, 2006 Honda Aero, 2008 Lancer GTS, 2006 Galant GTS
Send a message via AIM to SmikeEvo
Like Neal said, pressure does not matter on tire size.
I always ran somewhere near 34 front and 36 rear for DD. Then when up or down for AX/Track.
__________________
***New Points System and Forum Rules***
Problem with a post or thread? Use the report post button - triangle sign on the bottom left.
SmikeEvo Racing Blog
Sponsored by:
Swift Springs
GTWorx
Offline
Old Oct 30, 2009, 01:13 PM   #9
EvoM Moderator
Quote:
Not sure I necessarily said that lol
__________________
www.tirerack.com
Offline
Old Oct 30, 2009, 03:10 PM   #10
Ludikraut's Avatar
Here's a good post on the subject, which backs up the data points I illustrated in my earlier post. I don't have the time to do a calculation between the stock tire and a 265/35 right now, though. I'll see about posting that later. This should be enough to get the propeller heads started.
Quote:
Originally Posted by DamonB @ rx7club.com
...What supports the weight of the car is literally the molecules of air in the tire. Because of this as the volume of air the tire can hold goes up, the required air pressure to support the vehicle weight goes down. Ideally you figure out the exact volume of air inside the stock tire size and that with the inflation pressure would allow you to compute how many molecules of air are inside the tire. Now no matter what size tire you use you merely fill it with the same number of molecules of air. Unfortunately we don't count the number of air molecules when we inflate tires, we measure pressure which is completely different. If you put bicycle tires on your car the pressure would need to be really high, if you put 15" wide slicks on the pressure would be really low.
To entertain myself I estimated the volume of air inside your stock 205/60/15 (15" wheels) tires and that inside the 215/45/17 (17" wheels) and found that the 17" tires hold only about 85% of the air volume the 15" tires did. With that in mind then 32psi + 15%= 37 psi. This is merely an estimate. Size has everything to do with pressure. It's not strictly the width of the tire though, it's actually the internal volume of the wheel and tire assembly.
Your new tires are wider so you would expect the air volume to go up, but since they are also on wheels which are much larger in diameter your new setup in fact has less internal volume than your original. That means the required tire pressure will be higher. Start at 37psi and see what happens.
l8r)
__________________
Offline
Old Oct 30, 2009, 09:43 PM   #11
Drives: Evo IX
So the 265/35R18 tire is wider but holds less volume than the stock 235/45R17 so we will require more pressure than what's specified for the stock 235/45R17?
__________________
Current hardware :
Kelford 272 cams
Swift swaybars
Alcon BBK
Coming soon :
HFS-5 meth kit
CF driveshaft
Offline
Old Oct 31, 2009, 09:00 AM   #12
Ludikraut's Avatar
^ Yep, that's the idea.
l8r)
__________________
Offline
Old Oct 31, 2009, 09:18 AM   #13
Personal Sales Rating: (2)
Jhero23's Avatar
Drives: on boost
I have two set, I use the same pressure on both. My stock BBS with 255/40r17 RA1 and the other Volk Le37 245/40r18 with star specs. I always go by the hot pressure, 40 psi on all 4.
__________________
tbe + drop-in filter + 93 octane + tune =
60' ..... 1.705
1/8 ..... 7.640 @ 89.94
1/4 ..... 11.977 @ 114.10
Timeslip
Offline
Old Oct 31, 2009, 09:38 AM   #14
Personal Sales Rating: (33)
kmcconn9's Avatar
Drives: 04 EVO VIII - Tarmac
Send a message via AIM to kmcconn9
on my summer tire combo, 255/35 18's, I run 35 up front and 34 out back...
on my winter tire combo, 245/40 17's, I run 33-35 all around....depending on how much grip is needed
__________________
Buschur: TBE (w/ 2 bullet mufflers), UICP, LICP, 3065, Race FMIC, Intake....
Buschur Racing
Misc parts for sale:
http://forums.evolutionm.net/sale-pa...arts-sale.html
Offline
Old Oct 31, 2009, 01:58 PM   #15
2002 Ford Focus
SmikeEvo's Avatar
Quote:
Ok, implied.
__________________
Sponsored by:
Swift Springs
GTWorx
Offline
Tags
2006, 2553518, 39, a4, audi, correct, driving, ed, evolutionm, lancer, optimal, pressure, psi, recomend, spirited, tire
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
