Sep 6, 2009, 11:38 AM
Personal Sales Rating: ( 1)
Drives: TB IX MR SE, 07 R6
Brakes Pulsing and random noises.
I've noticed that my steering wheel tends to shake more when I brake at higher speeds and it increases more when more pedal pressure is applied. I've been thinking it may be build up on the rotor, but there is one thing that makes me think other wise. It seems like I can hear something loose, or moving around a little bit when I am braking from around 20 mph to 0. Thats what makes me think its not build up on the rotor, but I could be wrong. Any ideas at what I should check/look at suspension wise or take the pads out and look at them? They seem to have a decent amount of life to them still. I'm kinda lost...
__________________
E85
Quote:
Found a driedout gerbil carcass at the bottom of the box—AND it had been shaved.
Online
Sep 6, 2009, 11:44 AM
Personal Sales Rating: ( 3)
2002 Ford Focus
Drives: 2002 SVTF, 2006 Honda Aero, 2008 Lancer GTS, 2006 Galant GTS
Its pad material transfer.
Offline
Sep 6, 2009, 12:08 PM
Quote:
Allrighty, so you think I should use 120 grit sand paper on the rotors? I read that someone used that on some of the pulsing rotor threads...
Thanks.
__________________
E85
Online
Sep 6, 2009, 12:22 PM
2002 Ford Focus
That might help, but if its really bad, you will have to turn the rotor (if there is enough material to do that).
Offline
Sep 6, 2009, 01:02 PM
Ok, I will try the sand paper and see if it helps any. My brother's evo did this a few times, I don't think it shook as bad as mine though.
__________________
E85
Online
Sep 6, 2009, 01:07 PM
Personal Sales Rating: ( 0)
Drives: 08 Lancer Evo GSR,96 Saturn SL1
rotors are warped they need to be turned.If you can't turn them,this calls for a new set.just buy new rotors and pads to take care of it..
Offline
Sep 8, 2009, 10:53 AM
I'll take it to mitsu and see what they can do about it. Hopefully free, if not, I'll do the work myself
__________________
E85
Online
Sep 8, 2009, 11:01 AM
Personal Sales Rating: ( 5)
Drives: V///MR
Quote:
Free? Your speaking about the "stealership", right??
resolve, 200 grit sand paper and some brake cleaner
__________________
Haterade, for that deep down hater thirst.
WTB - IX (APEX SILVER) FRONT BUMPER AND WING
***CASH MONEY***
RIP COLIN... YOUR MEMORY WILL ALWAYS LIVE ON...
http://www.colinmcrae.com
Offline
Sep 8, 2009, 01:00 PM
See the thing that makes me wonder is that it was more like of an overnight change. And I don't recall using the brakes hard at all. I mean sure I felt a little movement in the wheel when using the brakes at higher speeds before, but now at higher speeds its just ridiculous. Also I can hear something moving around almost every time when I am using the brakes at lower speeds like coming to a stop in a parkinglot. I really do think something is loose.
__________________
E85
Online
Sep 8, 2009, 05:12 PM
Yup they were warped...A LOT! The creeking noise that I was hearing was the pads slowly moving in and out. The thing that really confused me was that it didn't always shake when I applied the same pressure on the pedal at the same speeds.
All good now!
__________________
E85
Online
Sep 8, 2009, 07:17 PM
Drives: Evo IX TB, 07 ZX-6R
All good now as in the dealer fixed them or replaced them?
__________________
Yea it's an AWD, turbo, corn burner.
"A fit, young racing driver, in a supercar, and he cannot pull away from a fat man, in a 4 door saloon." -Top Gear, Mitsubishi Evo & Lamborghini Murcielago
Offline
Sep 8, 2009, 07:29 PM
Quote:
They turned them, not warrantied because they are a wear item, but whatever. I was surprised how much sheot those warped rotors caused.
If they start to warp again, I'll just buy some better ones.
I guess the guy that worked on my car is friends with fathouse.
__________________
E85
Online
Sep 9, 2009, 05:22 AM
2002 Ford Focus
Its more the pads than the rotors in terms of pad transfer. If they warp again, look into changing the pads.
Offline
Oct 6, 2009, 10:57 AM
Yea, they just fuxed up again.  Not even 1k miles.
I swear something is loose and causing this to slowly happen. As soon as I started hearing noises this crap started to happen. Ugh...
__________________
E85
Online
Tags
10, 2003, 2005, brake, brakes, evo, focus, ford, front, mph, noises, online, pulsating, pulse, pulsing, random, zx  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
