Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack
Evo Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack Discuss everything that helps make your car start and stop to the best of it's abilities.
Sponsored by: Tire Rack
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Sep 2, 2009, 01:19 PM   #1
Personal Sales Rating: (5)
Paulnsx's Avatar
Drives: GG Evo IX SE && Black 05 Saabaru
Send a message via AIM to Paulnsx
Anyone Running X MR Wheels on an VIII/IX w/ Spacers?
Is anyone running X MR BBS wheels with spacers on their VIII/IX? Specifically with Swift Sport Springs or some other lowering spring.
I am considering my options. I believe 10mm will work with no issues. 15mm will probably require rolling. I am particularly interested to know if anyone is running a 15mm w/o rolling. 15mm would be easier for me as I could probably run bolt-on style spacers and not have to worry about swapping in extended lugs.
A 15mm spacer would put me at: 18x8.5 +20.
This is 2.65mm more aggressive than a 18x9 +29 wheel which supposedly works w/o body modification on Swifts.
Thanks!
Offline
Old Sep 3, 2009, 04:42 PM   #2
EvoM Moderator
Personal Sales Rating: (12)
MR Turco's Avatar
Drives: WW Evo IX w/ SSL/SE, 2000 Sentra SE w/ SR20
why do you want to run spacers?
__________________
-Mike
The Rules - lub them
Quote:
Originally Posted by Jeremy Clarkson
A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.
Quote:
Originally Posted by Fry
It's just like the story of the grasshopper and the octopus. All year long the grasshopper kept burying acorns for winter while the octopus mooched off his girlfriend and watched TV. But then the winter came and the grasshopper died and the octopus ate all his acorns and also he got a racecar. Is any of this getting through to you?
Offline
Old Sep 3, 2009, 08:34 PM   #3
Personal Sales Rating: (0)
Drives: 2006 Evo RS
I ran a 5mm hub centric H&R spacer on my X wheels........It gave me a high speed steering wheel shake & decided to remove them.......Maybe a bolt on spacer would have worked better for me........I understand!!!.........Peace
__________________
Pro God / EVO9 RS (Under the Influence of 85% Alcohol)
Offline
Old Sep 4, 2009, 06:19 AM   #4
Paulnsx's Avatar
Going for a more aggressive look.
Offline
Old Sep 4, 2009, 06:28 AM   #5
EvoM Moderator
MR Turco's Avatar
Quote:
err? do spacers do that?
__________________
-Mike
Offline
Old Sep 4, 2009, 07:00 AM   #6
Paulnsx's Avatar
haha yeah. im gunna pull a wheel off this weekend probably and see if the 10mm built-in style spacers would work w/o cutting my studs
Offline
Old Sep 4, 2009, 06:13 PM   #7
Personal Sales Rating: (3)
lan_evo_mr9's Avatar
Drives: 88590715
They should, but there's no reason for it, unless you get some tires that are too wide.
__________________
kornfed
Quote:
Originally Posted by leethaxor
My motors always were more tolerant to detonation when I ran with blown headgaskets. They were always faster.
Offline
Old Sep 8, 2009, 07:49 PM   #8
Paulnsx's Avatar
bump, has anyone run these wheels on a IX w/ 15mm spacers? or for that matter an 18x8.5 +20 wheel w/o rolling?
Quote:
your response makes no sense... spacers wont help me fit wide tires
Offline
Old Sep 15, 2009, 06:21 AM   #9
Personal Sales Rating: (163)
Drives: WW IX RS
Send a message via AIM to Mitchubishi
Thanks!
The spacer puts you at 18x8.5 +23 actually.
I ran these wheels with 15mm all around and a friend is running them the same way now. Rear rolling required, front fits no problem.
Offline
Old Sep 22, 2009, 05:29 PM   #10
Paulnsx's Avatar
thanks!!! i was assuming the rears would need rolling. its nice to know for sure. why do you say it would put me at +23 instead of +20? 35 - 15 = 20...
so i just swapped these wheels back on after an autox and i did some rough measuring with just a measuring tape. i am almost positive a 10mm bolt-on style spacer with work with the X MR BBS wheels!
it looked like the stock studs stick out ~25mm from the hub and the X MR BBSs have recessed holes at least 20mm deep!
Offline
Old Sep 24, 2009, 03:04 PM   #11
Personal Sales Rating: (1)
FenixTX717's Avatar
Drives: 99 GST Spyder / 1987 Conquest TSI / 08 MS3
Send a message via AIM to FenixTX717
Lets see a picture!
__________________
99 GST Spyder ~ HX35 build on it's way!
. . .an EVO awaits me. . .
www.tmzperformance.com
Offline
Old Sep 26, 2009, 08:39 AM   #12
Drives: WW IX RS
Stock offset is +38, not +35. I have no idea where people get that number...
Offline
Old Sep 28, 2009, 02:04 AM   #13
Drives: EVO IX
This a nice cheap set up,
Offline
Tags
20mm, evo, hr, spacer
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
