Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old May 30, 2009, 04:07 PM   #1
Personal Sales Rating: (24)
Torque specs for control arm bolts after RCA kit install
I do not have a factory manual and installing the whiteline RAC kit. The whiteline instructions do not provide any bolt torque numbers.
I found this nice writeup:
Install a Whiteline KCA395 roll center correction kit on an Evo without a shop press
...but, it has no torque specs for all the bolts either. Can anyone fill in the gap by supplying the factory torque specs for:
1) Control Arm bottom bolt
2) Control Arm side bolt
3) Sway bar end link bolt
4) Ball joint bolt
5) Tie rod bolt
And please refrain from just saying: "just get as tight as you can" ...that is useless
Thanks
Offline
Old May 30, 2009, 04:31 PM   #2
Personal Sales Rating: (1)
drinky84's Avatar
Drives: 06 TB Evo IX SE
Probably more than u need but hey more is better right.
Front axle crossmember bar bolt
49 ± 10 N⋅m (37 ± 7 ft-lb)
Lower arm to crossmember connection bolt (Rear)
167 ± 9 N⋅m (123 ± 7 ft-lb)
Lower arm to crossmember connection bolt (Front)
186 ± 10 N⋅m (138 ± 7 ft-lb)
Lower arm to knuckle connection nut
108 ± 10 N⋅m (80 ± 7 ft-lb)
Stabilizer bar bracket bolt
39 ± 5 N⋅m (29 ± 3 ft-lb)
Crossmember to body connection bolt and nut
Crossmember bolt
Rear roll stopper connection nut
52 ± 7 N⋅m (39 ± 5 ft-lb)
Stabilizer link bolt
Stabilizer bracket bolt
21 ± 4 N⋅m (16 ± 2 ft-lb)
Steering gear and joint connecting bolt
18 ± 2 N⋅m (13 ± 2 ft-lb)
Steering shaft cover bolt
5.0 ± 1.0 N⋅m (44 ± 9 in-lb)
Tie rod end to knuckle connection nut
25 ± 5 N⋅m (19 ± 3 ft-lb)
Offline
Old May 30, 2009, 06:53 PM   #3
Oh sweet ! Thanks for the quick reply!!!
I'll update the DYI thread with these.
Thanks!
Offline
Tags
control arm, torque
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
