The vibrating when stopping is most likely due to a warped rotor, and/or a wheel that is significantly out of balance. It is not likely however, that this would be significant enough to actually stop your car when coasting in neutral or prohibit you from starting at a dead stop. What pads/rotors are you using? Do check the color of the fluid, if you have problems in the lines it could lead to inadvertent bursts of pressure to the cylinders in the brake calipers, or prohibit the release of said pressure if you let your foot off of the brake at a stop sign. Best bet is to take it to a shop, but check the fluid color, and see how much pad wear you have left and the rotors appear to be in decent condition (pitting and gouging) then go from there... Another guess is if you mod and have messed around with the car a bit, check for kinks or twists in the brake lines, that could also send things haywire.
