Mar 14, 2009, 07:08 PM
Personal Sales Rating: ( 4)
Drives: evo 9 rs
clunking noise after lowering spring install
I just installed tein lowering springs on my evo 9 today and now im hearing a clunking noise when i turn the wheel. Could it be the spring slipping on the perches? It only makes the noise when i turn nothing when going straight. I made sure all bolts were tight so i guess its coming from the springs? any help would be great thanks.
__________________
06 evo IX rs
04 yamaha r6
red rays lug nuts for sale, pm me!
Offline
Mar 14, 2009, 07:09 PM
Personal Sales Rating: ( 15)
Drives: tb evo 8
OT- Are you with speedfreaksdvd?
__________________
03 Tarmac Black Evo
Black on Black
Soon to be corn fed
Offline
Mar 14, 2009, 07:21 PM
Drives: evo 9 rs
no i am not haha
__________________
06 evo IX rs
04 yamaha r6
Offline
Mar 14, 2009, 07:25 PM
Personal Sales Rating: ( 10)
Drives: 2006 EVO IX MR, 06 gsxr 600
eh.. tein, bad choice, but either spring have to settle in or something is wrong with the install.
__________________
PSN ID: kdash106
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
Offline
Mar 14, 2009, 07:26 PM
2002 Ford Focus
Drives: 2002 SVTF, 2006 Honda Aero, 2008 Lancer GTS, 2006 Galant GTS
Moved.
http://evomoto.com/tech_info.php?tPa...3c6033ef9c93c5
Incorrect install. You must make sure the hole in the top perch lines up with the hole in the lower perch. See #13 in link above.
Offline
Mar 14, 2009, 07:36 PM
Drives: evo 9 rs
yeah i think the top and bottom perches are in line gonna check that tomorrow thanks.
__________________
06 evo IX rs
04 yamaha r6
Offline
Mar 15, 2009, 02:07 PM
Drives: evo 9 rs
lined up the holes and it fixed the problem thanks!
__________________
06 evo IX rs
04 yamaha r6
Offline
Mar 15, 2009, 04:03 PM
2002 Ford Focus
Welcome
Offline
Mar 20, 2009, 08:35 PM
Personal Sales Rating: ( 0)
Drives: 2004 evo8 rs
Quote:
Originally Posted by SmikeEvo
hey thank you too. i had the same problem with my evo 8 when i installed my swift springs. i was sure i installed them ok. i took the strut back out and i used hand tools on the top 17mm strut bolt and lined up the middle hole on the upper perch with the hole on the bottom perch. it worked.
Offline
Mar 21, 2009, 03:25 AM
2002 Ford Focus
Welcome too
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
