Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Feb 20, 2009, 09:34 AM   #31
Personal Sales Rating: (33)
EVO8LTW's Avatar
Drives: 04 RS and 08 GSR
Quote:
Originally Posted by EVOlutionary View Post
I do believe that there are times when spring rates can be significantly higher than 10K even for street tires - for some people. On my '04 daily driver (25000 miles per year) I ran somewhere around 13k/15K and they were awesome. BUT - I had a perfectly valved set of Ohlins and was on 285/30/18 Advan Neovas . . . .
If you throw that high of spring rate on your average cheap set of coilovers it would probably destroy them before too long. . . so it is definitely NOT for everyone. But with a good set of coilovers and proper dampening . . . I don't think spring rates in the teens are out of the question. . .
EVOlutionary
I agree with this. My Summit Point Redline street tire record was set with 12K+ rates and a huge rear bar on top of that (in addition to stiffer springs in the rear), but I have Ohlins coilovers and like the car to be on the loose side.
Offline
Old Feb 20, 2009, 09:35 AM   #32
Personal Sales Rating: (4)
RaNGVR-4's Avatar
Drives: Your Little Sister Wild
Not in the rear as long as you don't change ride height. . . . but front - yes. . .
Although this is taking things off topic - I just want to touch on it real quick. Maybe we'll start a new thread. Personally I don't think there is anything wrong with lifting the inside rear wheel off the ground, as long as your car handles fine. All autocross EVOs I know do it at some point. And there have been a lot of EVOs that have won a lot of championships. . . . heck my old silver daily driver did it to the point where even turning a tight corner while decellerating it would do it. . . . and it handled beautifully on the streets as well as the track. . .
There are two different tuning ideas when it comes to this. To lift a wheel or not to lift a wheel, lol. The only reason the evo lifts a wheel is the strange roll center out back. but the suspension design works better with both on the ground. adding a sway bar makes things worse. since the front of the car has mac struts with inherently bad camber curves, a bigger bar would work better up front. it will keep the whole car flat, keep the front camber under control, and if you raise yor rear spring rates accordingly; will turn quite amazingly.
__________________
1991 Galant VR-4 #1951/2000- Sold
1991 Talon TSi AWD - 100$ DD beater- Sold
1994 Eclipse GSX - Sold
1995 Eclipse GSX - Sold
1995 Talon TSi AWD - sold
1969 Chevy Camaro - In a box
1998 Version 5 STi swap GC8 - Sold
2000 Version 3 STi swap GC8- Sold
1990 Legacy Auto-x/Rally-x Project
1998 Yo' Momma V
www.AST-USA.com
Offline
Old Feb 20, 2009, 09:35 AM   #33
Personal Sales Rating: (25)
Mike01gsr's Avatar
Drives: 2006 AS EVO MR
Quote:
Originally Posted by Mike01gsr View Post
Very good thread andrew, I have a question I have the KW's and when I bought them I bought a set of 8k springs to replace the 6k. So right now I have 9k front and 8k rear do you
think it's worth the time and effort to swap them around?
Great thread!!, anyone have any feed back to my questions above^^
__________________
"Never drive faster then your guardian angel can fly"
Offline
Old Feb 20, 2009, 10:06 AM   #34
Personal Sales Rating: (10)
kekek's Avatar
Drives: '96 Ford Taurus Wagon
Send a message via AIM to kekek
Somewhat true on the alignment after spring swap, but you need to nail your ride height.
As for having rear lift and it being a problem, you are correct. It's extremely difficult to completely tune it out and not worth jacking front rates to elleventy billion to do so. How much of it you get and where it occurs in the corner will have a big effect on how detrimental it really is. A bit on entry or mid corner is fine, if it's present on corner exit that is not good. At that point you want both tires on the ground to get in the throttle nice and early, otherwise you give away the AWD advantage and effectively shorten the upcoming straight.
There are some decent discussions floating around right now, cool stuff.
__________________
BSP prepped '03 Evo VIII
http://holunfie.blogspot.com/
Offline
Old Feb 20, 2009, 11:11 AM   #35
Silver Sponsor
Personal Sales Rating: (20)
Drives: 2004 STi
Yes, i think it's worth it. You will need an alignment, but the car will really feel better this way.
- Andrew
__________________
JRZ Suspension
KW Ohlins Bilstein Swift Whiteline
GTWorx Springs - Group Buy going on!
Click here!
AIM - gtworx Phone: 410-579-1501
www.GTWORX.com
www.racecompengineering.com
Offline
Old Feb 20, 2009, 11:13 AM   #36
Silver Sponsor
Drives: 2004 STi
This is one reason a lot of droop travel is a nice thing to have.
- Andrew
__________________
JRZ Suspension
Click here!
www.GTWORX.com
Offline
Old Feb 20, 2009, 11:20 AM   #37
kekek's Avatar
Quote:
- Andrew
True, but if the load is already transferred off the inside tire and all it's merely doing is sitting there with no load it is effectively the same thing mid corner.
__________________
Offline
Old Feb 20, 2009, 03:27 PM   #38
Personal Sales Rating: (6)
V.8MR's Avatar
Drives: 05AS MR
Great Thread!
__________________
"Somewhere between an excuse and a lie, you've found something to believe." -Lamb of God
"If you can't dazzle them with your brilliance, then baffle them with your bull****. " -Some guy
"Dont fake your life inhale it" -Pantera
"I smoke all day, i drink all day, I took the Devils breath away" -Pantera
"It's Allah's job to forgive them (insurgents), it's ours to arrange the meeting"- U.S. Army Special Forces Operative
Offline
Old Mar 2, 2009, 06:22 PM   #39
18bora's Avatar
Drives: 01 Jetta 1.8T
Quote:
Originally Posted by Yogi_B View Post
Those look to be metric eibachs.
H200 = 200mm long
065 = 65mm ID
T100 = 100 N/mm (10.2kg/mm)
Don't know what that last one is, could be date of manufacture, possibly 25th week 2006 for fronts 43rd week 2006 rears.
Thanks,
After a closer inspection, I realized that the front springs were actually 12K (T120) and the backs were 10K (T100). Luckily, I haven’t had the time to install them yet. So I decided to listen to Andrew and swapped the springs around.
After the swap:
Front
Back
__________________
06 EB IX 13.0@102.7 Bone Stock.
Track Videos NJMP, WGI, Pocono
Offline
Old Mar 2, 2009, 06:25 PM   #40
Personal Sales Rating: (16)
EVOlutionary's Avatar
Drives: '04 EVO VIII, '06 EVO IX RS, '90 1JZ-TT Supra
NICE SHOCKS! Once you get them dialed in you will be in LOVE!
__________________
Many thanks to:
Andy @ Showcase Mitsubishi
Keith @ Pure Tuning
David @ DHP Composites
Jon @ TRE
Wayne @ Paradigm Performance
Evan @Exedy Clutch
for your contributions to the EVOlutionary EVO9 Project:
2008 - one car - 20+ wins
2008 - Solo2 XPL National Champ
2008 - Solo2 SM National Champ
2009 - the sky's the limit!
Offline
Old Mar 3, 2009, 11:04 PM   #41
Personal Sales Rating: (9)
mchuang's Avatar
Drives: 2000 honda si turbo..sold 03' Rally Red BPU+
I currently have the HKS Hipermax RS and I am looking to upgrade the springs to some swift. The current spring rate is Front Spring rate 6kg Rear Spring rate 5kg. I mainly drive this car on the street with the occasional track appearance but I noticed the rear spring rate is softer than stock. I was thinking of going with 7 up front and 9 in the rear? What do you suspension gurus suggest?
__________________
Quote:
Originally Posted by DynoFlash
Anyone buying a $30,000 car is a fool if they dont have it custom tuned by a good tuner
www.houston-imports.com
Offline
Old Mar 4, 2009, 08:38 AM   #42
Silver Sponsor
Drives: 2004 STi
I would be worried the rear coilover can't take a jump from 5kg to 9kg without a revalve.
- Andrew
__________________
JRZ Suspension
Click here!
www.GTWORX.com
Offline
Old Mar 4, 2009, 10:04 AM   #43
Personal Sales Rating: (2)
timmiii's Avatar
Drives: Evo IX MR
Send a message via AIM to timmiii
Sorry a bit noobish question but I'm curious to know which coilovers out there can be revalved and would actually be worth the cost of revalving?
__________________
Evo-NY #288
TriStateEvo
Offline
Old Mar 4, 2009, 10:24 AM   #44
Personal Sales Rating: (29)
DaWorstPlaya's Avatar
Drives: Thats MR to U!
Quote:
Originally Posted by timmiii View Post
I <3 gtworx
That says it all right there ... As always good job Drew.
I have to agree with this statement, jack up the rates on the front too much and you just end up with a car that understeers even worse and looses total grip. Suspension system is all about balance, sometime you have to compromise in one area to gain in another.
__________________
GTWorx-www.GTWorx.com
Jestrtuning-www.jestrtuning.com
Better slow in fast out, than fast in dead out!
Forza 3 Discussion: Click here
Forza 3 Racing League:Click here
FS: Misc suspension bushings: Click here
Offline
Old Mar 4, 2009, 10:28 AM   #45
Most manufacturer coilovers can be revalved (eg: Ohlins, KW V3, Bilsteins, Konis, AST), I think the exception are Cusco that use Showa shocks. Whether your coilover will need a revalve or not will totally depend on the range of the shock and the change in spring rate you are seeking. Cost usually ranges from $100 - $150 depending on the shock manufacturer and the shop that does the revalve.
__________________
Offline
Tags
02, car, choosing, coil, coilover, coilovers, evo, galant, green, mr, rate, rates, selecting, spring, sti
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
