Jan 27, 2009, 08:55 PM
#61
Personal Sales Rating: ( 8)
Drives: 2006 GG MR :)
Quote:
Originally Posted by GTWORX.com
Sort of. In practice that's what I look at with cars that I know and measure from stock as a baseline. So yes I would say the Swifts have 15mm more rake than stock for example (from the 35mm front 20mm rear drop).
But really it's the roll axis. That's just a bit tougher to measure.
- Andrew
OK so what I was saying is correct then...Which is why I was a bit concerned with the swifts in the first place, the other reason being the reduced suspension travel (in the front)....
I really enjoy the feel of the stock setup on the street and am just hesitant to do anything that will make the ride quality worse, not to mention decrease performance. I would like the setup to be a tad closer to the GT3  ...
__________________
3" Modified Megan Racing TBE & UR Cat.
Buschur O2 & Buschur Exhaust Manifold
Nisei LICP
DC2 oil catch can
Walbro Fuel Pump
Injen intake and UICP (w/ Perrin Filter)
ETS 3.5" FMIC
Zeitronix ZT2, ZAVT1, and Boost solenoid Failsafe
SMC Kit (50% Meth / 50% h2o )
GM 3 port BCS (28psi tapering to 22psi)
Enkei 17 x 9.5 NT03M 275/40 Azenis
Offline
Mar 27, 2009, 06:37 PM
#62
Personal Sales Rating: ( 16)
Drives: '04 EVO VIII, '06 EVO IX RS, '90 1JZ-TT Supra
Don't "RAKE" me over the coals for bringing this back!
I kid, I kid!
So is there anyone else out there who runs the rear lower than the front??
__________________
Many thanks to:
Andy @ Showcase Mitsubishi
Keith @ Pure Tuning
David @ DHP Composites
Jon @ TRE
Wayne @ Paradigm Performance
Evan @Exedy Clutch
for your contributions to the EVOlutionary EVO9 Project:
2008 - one car - 20+ wins
2008 - Solo2 XPL National Champ
2008 - Solo2 SM National Champ
2009 - the sky's the limit!
Offline
Mar 27, 2009, 09:00 PM
#63
Silver Sponsor
Personal Sales Rating: ( 20)
Drives: 2004 STi
^ that was terrible! haha.
on subarus we used to run the rear slightly lower....but we've been experimenting. For EVO's we generally do not, but don't take that to mean too much.
- andrew
Offline
Mar 27, 2009, 09:37 PM
#64
Personal Sales Rating: ( 0)
Drives: Honda Civic
""So is there anyone else out there who runs the rear lower than the front?? ""
""on subarus we used to run the rear slightly lower""
For aerodynamics you don't want the rear lower than the front, you want some rake. Maybe not on autocross but any track with a high top speed. Especially if you have a full pan.
__________________
Mitsubishi dealer tech
Pacific Northwest
the funniest thing about this message is that by the time you realize it doesn't say anything it's too late to stop reading it.
Offline
Mar 27, 2009, 09:53 PM
#65
Silver Sponsor
Drives: 2004 STi
Well...used to.  The rear slightly lower was a very popular thing for Subarus (and still is).
And yes for aerodynamics it's not the best thing.
- andrew
Offline
Mar 27, 2009, 09:55 PM
#66
Not always this low - accel in while hitting a g-out. . .
Offline
Mar 29, 2009, 05:46 PM
#67
Personal Sales Rating: ( 3)
Drives: 98 Saturn , 05 evo
Great thread (thanks Andrew for pointing it out),
Most evo owners talk about rake judging from the fender gap difference front and rear, but the rake should really be a difference from the front roll center height when compared to the rear's. Also, in the evo platform a somewhat level roll axis would result in the rear fender gap being significantly less than the front.
For high speed stuff it is always recommended to run some rake to help airflow around the car's mass, but for solo I found a level car(roll axis parallel to the ground plane) to be faster. like in evolutionary's picture my car's static rear fender gap is lower than the front but my roll axis is not negatively raked.
I think the real reason people ask about rake is because they want to know how low they should drop the car front vs rear without hurting the handling. In theory, regardless of what rake you end up with, you want the lowest center of gravity, and roll centers as close as possible to that CG height. However, in real life that is practically impossible in the evo because of the car's design(unless somone alters suspension pick up points etc). Once you start droping the car for a better CG(effectively reducing weight transfer wich is btw different from body roll) you also lower the roll center at a much higher rate, increasing the roll couple and making the car more prone to roll.
I believe it's far more important to properly lower the evo(lowest possible CG while still maintening the smallest roll couple) than having a rake or not. I'd take a car at any rake angle if that meant a low CG with and virtually zero roll couple.
In this pic I'm lowered as much as I think possible without negatively affecting the roll couple and the LCA are slightly angled down at the outer mounting points.
(I should mention that I run a RC correction kit and the fenders are cut or they'd be sitting on the tires  )
Offline
Mar 29, 2009, 08:25 PM
#68
Personal Sales Rating: ( 4)
Drives: Your Little Sister Wild
Also, Rake can increase downforce, even without an undertray. As viewed from the front, any extra "square footage" the car has increases downforce. Our Motorsports Engineering director preeches that, compared to a larger wing or other aero aid, extra rake increases DF/decreases lift more than anything else.
__________________
1991 Galant VR-4 #1951/2000- Sold
1991 Talon TSi AWD - 100$ DD beater- Sold
1994 Eclipse GSX - Sold
1995 Eclipse GSX - Sold
1995 Talon TSi AWD - sold
1969 Chevy Camaro - In a box
1998 Version 5 STi swap GC8 - Sold
2000 Version 3 STi swap GC8- Sold
1990 Legacy Auto-x/Rally-x Project
1998 Yo' Momma V
www.AST-USA.com
Offline
Apr 1, 2009, 06:38 AM
#69
Drives: Alot.
There is no front Cg and rear CG unless you have a extremely soft chassis or a tractor-trailer. Either way the analysis doesnt apply here. In a decent racing car, there is only one CG.
Read it, love it:
http://www.neohio-scca.org/comp_clin...Center2007.pdf
Pick up the recent issues of racecar engineering and listen to what Danny Nowlan has to say. He's math heavy, the way it should be. There is too much conjecture in racecar "engineering". If we don't have the data, go and test it.
Good to see everyone having a good tech discussion. A good thing to mind with rake, roll centers, pitch centers, springs, bars and the rest of the "static" adjustments: the "static" balance is the sum of its parts. People may run a high rake with soft rear springs to affect their balance through the corner. Mathematically and otherwise, its useful to view the mechanical balance "map" as various combinations of accelerations are applied to the car.This includes vertical, since the whoop-de-doos have their own considerations. Tire sensitivities aside of course.
Offline
Apr 1, 2009, 09:39 AM
#70
Silver Sponsor
Drives: 2004 STi
I had read that before and i was still guilty of a couple of those myths.
thanks for the link....i need to keep up with this stuff more.
- andrew
Offline
Aug 31, 2009, 09:51 AM
#71
2005 Mitsubishi Lancer Evolution
Drives: 2005 RR EVOVIII RS
Rake and corner balancing
After reading this great thread, I wonder why no one has mentioned corner balancing as part of the adjustment/measurment/compromise "zen" that is EVO
If you add rake to a car, you are shifting weight forward and can measure it with racing scales. Has anyone measured their car weight at each wheel when adjusting rake?
When sitting in the car I have LF=1020; RF=1052, LR=752, RR =604
total = 3420, cross = 1813 52.8%
With my current setup, adjusting the weight back, lowers the rear springs and reduces rake. This is where the compromise part comes in.
What is a good corner balance for an EVO and what is the resulting rake? I'm interested to hear what choice people have made from experience.
This is probably a complex equation that factors in speed and aerodynamics. Loosely you can say lower speed favors optimal balance where aerodynamics are not a big factor versus higher average speed which must factor in changes in aerodynamics
I haven't found much info on rake vs cornerbalance and this thread seems like a decent place to have "coffee talk"
Here's a thread on corner balancing:
corner balance - yeah but what numbers
__________________
Tuned by MidgetSpec& English Racing
EVO VIII RS Rally Red 366WHP 338TQ 93 oct 25psi
English Racing Tuned, GSC S1 Cam, Walbro 255, TBE, Hallman MBC ,EVO9MR BOV, AMS Intercooler & LICP, Perrin UICP, TBE
JIC FLT-TAR Coilovers, Swift Sway Bars, RMR K Brace, Whiteline rollcenter & bumpsteer kits
R1 Concept Rotors, SS brakelines, Motul 600, Girodisk Titanium shims, Axxis ULTs, Kosei K1 TS, Advan AD08s
Reason: adding corner balancing thread
Offline
Aug 31, 2009, 01:13 PM
#72
After giving this more thought, I believe the best approach is to set desired ride height (correcting for steering geometry if going much lower). Adjust for desired rake, then fix any wedge by balancing. Sorry to bring the CBword into the rake thread...
__________________
Offline
Sep 10, 2009, 08:24 AM
#73
Silver Sponsor
Drives: 2004 STi
Quote:
Read it, love it:
i read this again. it's really good.
- drew
Offline
Sep 21, 2009, 01:24 PM
#74
Personal Sales Rating: ( 14)
Drives: 03 Evo VIII, 04 A8L, 00 A4 1.8T, 08 R32, 82 YF750
Just as an FYI,
I just measured the ground clearance on my sideskirts (I know, I know there's probably a better way to measure this but...) after installing a set of Swift Spec-R springs:
Ground clearance @ front of sideskirt = 6.125"
Ground clearance @ rear of sideskirt = 7.125"
I also measured the front crossbar mounting points, which were:
Ground clearance @ front crossbar mount, driver's side = 5.25"
Ground clearance @ rear crossbar mount, driver's side = 5.3125" (5/16)
Figure the accuracy to be about +/- 1/16th of an inch; a.k.a. me lying on my back in my garage with a tape measure.
l8r)
__________________
"Learning is the beginning of knowledge ...
knowledge is the beginning of understanding ...
understanding is the beginning of wisdom."
Suspension book for sale, NEW
Quote:
Any society that would give up a little bit of liberty to gain a little bit of security will deserve neither and lose both.
- Ben Franklin, Thomas Jefferson -
Offline
Tags
affect, car, cars, change, correlation, effect, handling, lower, modifying, rake, raked, rear, suspension, transfer, tuning, understeer, weight  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
