Dec 31, 2008, 01:59 PM
#31
Personal Sales Rating: ( 2)
Drives: '06 WW IX MR
Mike, can you please update the specs for the GiroDisc Magic Pads?
Quote:
Originally Posted by Girodisc Martin
They have good cold bite but their optimal temp range is 150-850 deg.
Johann @ Girodisc
Thanks!
-Jalal
__________________
TeamXXXRacing|Northeast Motorsports Club|Online Store
TriStateEvo|http://forums.tristateevo.com/index.php
XBOX Live Gamer Tag: MJ23FE
THE WANT LIST
POWER
Full Re-Tune
BRAKES
SmikeEvo Pad Combo
Performance Friction 2-piece Front Rotors
SUSPENSION/CHASSIS
Whiteline Sway Bar Set - 26mm Fixed Front/24mm Adjustable Rear
Perrin Stout Mounts
Perrin Positive Steering Response System
Online
Dec 31, 2008, 03:28 PM
#32
Personal Sales Rating: ( 3)
Quote:
Originally Posted by chu
On the SS lines, you want to start with something that has DOT approval, as mentioned in the thread. I would recommend something that has a coating on the outside, which serves to protect the stainless lines from rust and so on. I'm using the techna-fits, and they are dot approved and has that protective coating.
Actually, those SS lines are coated to protect the metal braid from abrasion as the suspension strokes.
It's important that attention is paid to the lines so they don't rub on anything - suspension, tires, arms, etc. If the metal braided outer sheath breaks, the sharp edges could cut the inner hose, leading to a line failure. The outer sheath is already stainless, i.e. it's rust resistant inherently.
Offline
Dec 31, 2008, 04:38 PM
#33
2002 Ford Focus
Drives: 2002 SVTF, 2006 Honda Aero, 2008 Lancer GTS, 2006 Galant GTS
Updated! Thanks Jalal.
Offline
Jan 2, 2009, 06:19 AM
#34
Personal Sales Rating: ( 67)
Drives: IX
Actual 2-piece stock replacement size rotor weights are listed below if you want to add:
FRONT ROTOR WEIGHT (each, lbs)
Stock Brembo 21.35
StopTech 19.35
Racing Brake 19.0
DBA 5000 18.5
Project Mu SCR 18.0
Performance Friction dimpled 17.7
Girodisc slotted 17.4
Girodisc slotted/drilled 17.25
Bear Eradispeed 15.8
REAR ROTOR WEIGHT (each, lbs)
Stock Brembo 14.6
Racing Brake 14.0
StopTech 12.9
Baer Eradispeed 11.66
Girodisc slotted 11.1
__________________
TTP-Engineering
Offline
Jan 2, 2009, 06:31 AM
#35
2002 Ford Focus
Awesome!!! Done!
Offline
Jan 2, 2009, 07:11 AM
#36
Personal Sales Rating: ( 91)
Drives: ix mr
sticky time
Online
Jan 2, 2009, 07:44 AM
#37
2002 Ford Focus
Thank you.
Offline
Jan 2, 2009, 08:56 AM
#38
Personal Sales Rating: ( 6)
Drives: GG Evo IX SE & 1990 Buick Century aka GPC
Awesome write-up. Definately should be a good sticky!
Offline
Jan 2, 2009, 03:06 PM
#39
Personal Sales Rating: ( 4)
Drives: 2006 Mitsubishi Evolution SE, 1970 Porsche 911T
Even if you dont like the idea of 75$ for a liter of fluid, Castrol SRF fluid is THE best brake fluid out there. 590F/518F Dry/Wet.
Also, the ACD makes life difficult for an installer of a ducting kit, but it can be done, I have the AMS kit on my 06.
Here's my write up:
AMS Duct Kit Install (Evo IX)
Yes, unnecessarily complicated and I partially block my oil cooler for the explicit purpose of symmetry BUUUUT there are a lot of pictures, take it for what its worth
__________________
350 awhp 321 awtq @ 24.5psi on 93oct (SAE Correction)- AMS Tuned
- ETS 4" IC - ETS LICP - ETS UICP - ETS Intake - Perrin Filter -
- BR 3" TBE w/ test pipe - Buschur o2 Housing -
- AMS MBC -
- ETS Battery - Walbro 255 - S-M DC3 - ETS Radiator Hose -
- EnduraTech Coilovers (7k/9k)-
- AMS Brake Ducts - Hawk HT10/ PF Metallic Z - Technafit SS lines -
- Enkei RPF1 - Nitto NT05 -
- APR Splitter -
- Motul RBF600 - AMSoil -
- Stri Gauge -
Offline
Jan 2, 2009, 03:08 PM
#40
Oh and 'moderator' SmikeEvo? la di da
__________________
- AMS MBC -
- APR Splitter -
- Stri Gauge -
Offline
Jan 23, 2009, 09:22 AM
#41
Drives: 2.slow Evo IX
SmikeEvo,
you should add a link for the installs of pads, rotors and the like...
__________________
-MattDennison-
TuningTechnologies ROBISPEC /// MISHIMOTO PROSPORTGAUGES MIL.SPEC SPYOPTICS+
2009 Redline Time Attack - Stock-AWD - Champion
ahh...ocean life
Offline
Jan 23, 2009, 10:20 AM
#42
2002 Ford Focus
I thought about it. But members can find those in the How-To forum. Unless you have some stellar examples that can be used here.
Offline
Jan 24, 2009, 07:22 PM
#43
Personal Sales Rating: ( 33)
Drives: EVOLUTION IX MR - K7 GSX-R 600
Awesome thread man... thanks
__________________
EVOLUTION IX MR
Tuned by iA Performance
Online
Feb 10, 2009, 04:50 AM
#44
2008 Mitsubishi Lancer Evolution
Drives: 2008 Evolution X GSR, 2009 Mini Cooper JCW
Anyone run Carbotech XP8s for HPDE use?
Offline
Feb 10, 2009, 10:49 AM
#45
Drives: 06 IX
Quote:
I've run on the 10's not the 8's at Sebring. Definitely need cooling ducts there. Boiled fluid first run, then bled the brakes, worked for 2 more sessions also using Motul 600.
__________________
- 426 hp 320 tq on 93
- FP Green and JUN 272's
A concrete fascination, scraping the edge of nothing!
Offline
Tags
blank, braided, brake, clutch, construction, duct, et800, fit, gransport, line, pad, problems, raybestos, rotor, satisfied, smikeevo for president, ss, st43, techna  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
