Review: Autozone Duralast Gold CMax Pads (Ceramic Brakes) for the Daily Driver
#31
Did you go Duralast Semi-Metallic Front and Rear? Or are you running Duralast CMAX up front, coupled w/ Duralast Gold Semi-Metallic's on the rear?
If you have the combo above then it's most likely the rears that's making the squealing noise (Semi-Metallic). The best way to figure out if it's the rears is to put your stock rear pads on temporarily and see if the noise goes away. If it does, return the Semi-Metallic rears (they will give you a full refund), head to Kragen and get the Satisfied Pro Ceramic VS (PR-961C) on the rears and your noise will go away.
That's the setup I'm now running and it has seen a couple of SoCal mountain runs already and and no noise.
#34
Idk I had veryyy bad experiences with duralast...I mean If they work fine, I prolly use it, but idk I really hate duralast anything. But I'm thinking of doing a brake upgrade and get a 2-piece design like u did...I'll post when I get up the money...
#35
I put these on last weekend and they feel pretty good to me. They have good stopping power and I can't hear them at all. I can't comment on the dust because my rims are pretty dirty from the last set I had on and I haven't been able to really clean my rims in this weather.
#37
hey guys i'm thinking of swapping my front pads to something a little more aggressive. i have centric posi quiet ceramic pads in all four corners but it doesnt have the bite intially like the stockers did. and i knew that since they are not track pads. now i just like to get something with a good initial bite and that will defintely stop the car without to much pedal.
how are these pads holding up? how is the pedal feel with these. i also plan on changing the brake lines and fluid to AMSoil brake fluid or Motul
#38
If you want something more aggressive then you'll probably have to check out the Ferrodo DS2500's.. I'm not sure how the Satisfied GSS6, or the GSS5's perform, might want to ask smikeevo as he runs the GSS5 on the street.
#40
I'm running DURALAST CMAX GOLD on the FRONT, and Satisfied Pro-Ceramic VS (PR-961C) on the REAR. Both ceramics. Won't be changing the front pads to Satisfied ones though because my fronts wear quite a bit more than the rear hence the lifetime replacement will pay dividends down the line :]
#42
BTW, for those people wanting to go with different brand instead.. The Satisfied GS6 pads are back in stock @ amazon.com
Fronts = GS6-D1001 (57$)
Rears = GS6-D961 (40$)
w/ free shipping.
w/ free shipping.
#45
I forget what I have in the back; have to check my records. Actually I think they are Wagner Thermo Quiet.
