Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Apr 18, 2005, 11:59 AM   #31
Personal Sales Rating: (74)
TalonRcR's Avatar
Drives: 92 Twin Turbo Stealth/91 AWD Talon
Send a message via AIM to TalonRcR
Quote:
Originally Posted by Ev0ikon
I bought a set of GoodRidge *ReWork* version from a vendor on this forum. Here is the picture of the rear connector compare the the GoodRidge *G-Stop* version.
The problem is that the ReWork line will not mate tighly up to the stock Hard Line connector. Good thing we found this out while the car was on the lift.
Beside that, the *ReWork* parts are identical to the *G-Stop* version in quality and craftmenship.
Did you call goodridge yet?
Chris
__________________
RIP MARK (KK) WE WILL ALL MISS YOU
Offline
Old Apr 18, 2005, 12:11 PM   #32
Silver Sponsor
Personal Sales Rating: (80)
MitsuJoe's Avatar
Drives: 03 BBY EVO by PPI and 00 Civic SI
Send a message via AIM to MitsuJoe Send a message via MSN to MitsuJoe Send a message via Yahoo to MitsuJoe
Michael Klapp from Goodridge has told me to post this so others can call him directly if you have this problem. His # and direct extension is 310-533-1924 x36 and his e-mail is michael.klapp@goodridge.net
He will send you the proper fittings to fix the problem.
__________________
Paradigm Performance Innovation
http://www.paradigmperformance.net
Michigan's EVO Club @ www.miEVO.net
Offline
Old Apr 20, 2005, 11:35 AM   #33
Personal Sales Rating: (11)
Ev0ikon's Avatar
Drives: Evo803Yello
Doh!
I should have read this before sending the parts back to Chris.
No worry guys.
Chris is a good guy to deal with and he's taking care of me jsut fine.
__________________
He who said that there is no replacement for displacement didn't know pkZIP. :p
Offline
Old Apr 28, 2005, 07:56 AM   #34
Personal Sales Rating: (12)
silverghost's Avatar
Drives: 06 Evo MR, 02 Acura TL type S
Angry leaky Goodridge rear hardline fittings
I just installed the Goodridge lines that I got last week from an evolutionm Gold Vendor. Unfortunately, I have leaking rear hard line connections. So, vendors are still sending out these kits with the improper rear connectors. I've ordered Stoptech rear lines to remedy the problem.
__________________
06 Apex Silver Evo MR
Offline
Old Apr 28, 2005, 08:09 AM   #35
EvoM Super Moderator
Silver Vendor
Personal Sales Rating: (65)
Zeus's Avatar
Drives: Old Man with a 03' EVO VIII, 05' Subaru 2.5GT Limited, 06' Kawa Z1000, 02' Kawa ZR-7s, 07' GSXR 1000 (babysitting lil' brother's ride while he's in the sand box), 00' Integra Type R SOLD
Send a message via AIM to Zeus
Hey, did you not see post #32 above? Call them up and let them take care of you!
__________________
Contact me for parts -n- installs!
Best deals on All Megan products!! Megan Evo X turbobacks and O2 housings!!! OE TYPE replacement rotors-n-pads DEAL. I'm only available 8am-12pm Central Tues-Sat, available all day Sun/Mon. Currently only accepting PayPal, all sales final, customer warranty claims processed directly through the original manufacturer. All shipping quoted for the contiguous 48 states.
Offline
Old Apr 28, 2005, 08:14 AM   #36
Personal Sales Rating: (18)
Az3ar's Avatar
Drives: EVO IX , E30 M3 EVO2, 6R 636 and Spec E30
and I was about to order their lines. I am going with Works lines then
Offline
Old Apr 28, 2005, 08:44 AM   #37
Silver Sponsor
MitsuJoe's Avatar
Quote:
Even my research isn't enough for most people....
A call would at least be in order!!
__________________
Offline
Old May 9, 2005, 06:46 AM   #38
Yes, I wrote Michael and he was helpful. The problem seems to be a bit more insidious than what I have read. What I mean is this. The first issue that I ran into was the use of 19 mm diameter fittings on the rear lines. To use these you must grind off the 17 mm tabs that were design into the fitting mount. 17 mm is the size of the Mitsubishi OEM fitting and the tabs kept the OEM fitting from spinning when the hard line fitting is tightened to the flex line. When I got my Stop tech rear lines they were 17 mm and would have fit the OEM mount without the grinding.
Secondly, my rear hard line fitting leaks were not due to a grossly wrong fitting in the rear lines as reported in an earlier thread. The rear lines did have the raised center cone for sealing with the Evo rear double flaired hard line. The problem is that they did not seal. I progressively tightened these rear fittings with a 10 mm line wrench and a 19 mm open wrench. You can get thes fittings very tight with these tools. When they were so tight I was worried about shearing the head off of the male fitting I stopped. They still leaked.
When the Stoptech lines came in I compared them. The difference is not very obvious. In fact, I was pretty sure that they would leak because of all the force I put on the Goodridge fittings. But the Stoptech fittings went on without a hitch. They are not leaking. I checked them this weekend. They were dry. Also, the master cylinder reservoir is staying full. This is always a good sign.
Goodridge is sending me updated fittings. If I can discern a difference I will take picts.
__________________
Offline
Old Jun 2, 2005, 02:18 AM   #39
Personal Sales Rating: (1)
machron1's Avatar
Drives: 2003 Rally Red EVO
Send a message via ICQ to machron1 Send a message via AIM to machron1 Send a message via MSN to machron1 Send a message via Yahoo to machron1
Quote:
I know of someone that had an off at the track because a Works brake line busted. If there is a name I trust it's Stop Tech or Goodrige, but any company can screw up once in a while.
Offline
Old Aug 4, 2005, 10:45 PM   #40
Personal Sales Rating: (0)
Impulsoren's Avatar
Drives: 05 Evo RS, 1989 Impulse 2.6 turbo 397/414, 1991 Impulse RS turbo, looking for 1 ton 4x4 cargo van
I know this is kinda an old thread, but doesn't anyone make their own fluid lines any more? It only ends up costing about $75 for all the lines, and you can do it right and not have to worry about things being crappy.
Offline
Old Jan 14, 2006, 04:52 PM   #41
Personal Sales Rating: (48)
2003 Mitsubishi Lancer Evolution
jid2's Avatar
Drives: 03 EVO VIII White
Well it's January of 2006 and I just got a set of Goodridge lines from Tirerack and the bastards won't seal on the rear hardlines. I guess this is still a problem. That is CRAP. How long does it take to fix a seriously dangerous issue?
I'll call and see what they say. I should have bought Technafit.
__________________
jid2 Built: Now featuring E85 super fuel
2.3L - GT3076R .63A/R, ETS equal length, Kelford 272's, BC valve springs, 1mm O/S valves, FIC BM 1450's, Full-Blown dual Walbros, Buschur IC, jid2 intake, airbox, IC pipes, APS BOV, TBE, ACT HDSS, Stock ECU, 28 psi 466hp/420 ft-lb...
Build Thread
Binary Lowered Recaro Seats, Girodisc 2-Piece, brake ducting, ST43's, SS lines and ATE Superblue, KW V3's 8K/10K, jid2 flat-bottom, adjustable splitter and aero, 18x9.5 +40 NT03's 265/18/35 BFG R1's
Offline
Old Jan 14, 2006, 05:30 PM   #42
Silver Sponsor
MitsuJoe's Avatar
Relax, chances are Tirerack still had old stock and that was what you got. Call Goodridge and you should have fittings within 3-5 days. I know this does not make up your time for doing it once and such although every modification does not always go as planned. Good Luck!
__________________
Offline
Old Jan 14, 2006, 08:49 PM   #43
jid2's Avatar
Yes it does suck that I spent a fair amount of time trying to get them to work, and ended up putting the stock rear lines on so I could drive home.
What is stupid is that Goodridge didn't either recall the falty parts, or simply send the correct parts to their distributors. Back in the day I wouldn't have cared. But now I'm the lead engineer for a legit company. Now I understand that when you discover a serious problem you get it fixed - fast.
At least I found this thread or I would be really bitter and trying to re-flange the steel lines. Now I can just wait.
__________________
Build Thread
Offline
Old Mar 24, 2006, 04:52 PM   #44
jid2's Avatar
Got the correct parts. Problem fixed. But seriously, recall all the bad ones.
__________________
Build Thread
Offline
Old Apr 3, 2006, 02:45 AM   #45
Personal Sales Rating: (116)
elhalisf's Avatar
Drives: 04 Evo 8
Send a message via MSN to elhalisf
had the very same problem. called up goodridge, and they told me to send them back. about a week later, i got the new ones. however, i havent installed them yet. hopefully the new fittings wont leak.
__________________
9.0 wiseco/crower motor, FP green, PPI ported 10.5 hotside/exhaust/intake manifolds, PPI 65mm TB, S2 cams, SMC meth, intake, exhaust, ETS FMIC, O2 housing, Forge MBC.
Tons of suspension mods!!
Faisal (586) 610-2830
Offline
Tags
308888, bf, brake, evo, failure, goodridge, install, ix, leak, leaking, line, lines, seal, subaru, wrong
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
