Staggered wheels
Old Aug 15, 2007, 01:03 PM
bradc's Avatar
Staggered wheels
I have a Legnum VR-4 which has a very similar drivetrain to an evo, AYC diff at the back, W5M51 transmission but a bigger V6 2.5 TT engine.
I'm looking to run 235/45/17 at the front and 265/40/17 at the rear. Tyre calculators say that this is very close in ratio and less than 1mm difference in rolling radius which is surely less than a lot of Evo's out there with same sized tyres that haven't been rotated for a while.
Will this work ok or will it cause problems with the transfer case?
Old Aug 15, 2007, 06:55 PM
evodrivesme's Avatar
its could but if its saying a 1mm difference i would assume you would be ok.
Old Aug 15, 2007, 06:56 PM
im running 255/45 on both front and rear but i have 17x9 in the front and 17x8 in the rear
Old Aug 15, 2007, 08:04 PM
bradc's Avatar
The circumference is 2020.3mm versus 2021.8mm, so a very small difference.
Don't you find that 255 wide tyres on 8" rims make the front wallow around a bit?
Old Aug 16, 2007, 02:10 AM
freeride's Avatar
off topic is know, but post up pics of your ride....
Old Aug 16, 2007, 02:41 AM
bradc's Avatar
(old pic)
(old pic)
I'm never really too sure where to start with the spec list! It's got Tanabe springs, Autronic SM4 ECU running on MAP, custom piping throughout, cold air box mostly 2.5 and 3", custom downpipes, 600x300x100mm intercooler, EVO 6.5 TME Seats, 255lph fuel pump, EVO 7 Brembos, Wedsport TC-005 17x9.5" 35mm wheels, Exedy heavy duty clutch, stock 3.333/2.105/1.407/1.031/0.761 gears with 4.111 final drive - I'm after a 0.721 5th and 3.73 final drive When I got it it was completely stock, even the wheels, exhaust and ride height were stock! It made 159kw at the wheels, now it makes 225kw, still on stock turbos and internals. Next step will be a pair of GT2554R's, or VF29's or TD05's and I will be shooting for 300kw atw.
Old Aug 16, 2007, 02:49 AM
moreryce's Avatar
nice ride...
as for the tires.. the ayc and the acd have a tolerance level just due to the fact that the fronts will wear out faster than the rears will... when you have a 1 mm difference right now it might be fine... but when others wear out..it will cause it to be more uneven... so in the long run you might have some problems with over heating the diff... i would just run the same tires all around.. that way when the fronts wear.. you can just rotate them... just my 2 cents though
Old Aug 16, 2007, 04:48 AM
freeride's Avatar
that's one insane wagon!!!
yet another awesome ride we can't get in the states...
Old Aug 16, 2007, 05:25 AM
hylomar's Avatar
Running a larger tire in the rear could amplify your understeer. (I am assuming that VR4's are AWD).
Old Aug 16, 2007, 12:44 PM
bradc's Avatar
It doesn't have an ACD, it has a similar drivetrain to an evo4-7, and not an evo8 or 9.
Yes it is 4wd and I am a bit concerned about increasing the understeer, but with AYC at the back and the suspension setup that I have it is very well planted at the front anyway.
Moreryce - good point about the fronts wearing faster. On VR-4's the rear camber isn't adjustable and the inside of the rear tyres wears out quickly, so what we normally do with them it unmount the rear tyres and swap them to the other side, and leave the fronts for the duration of their life. The tyres wear down fairly evenly this way. The sidewall height on the 265/40's would be 106mm, while the 235/45's would be 105.75mm which is very close, but ultimately the rears will wear a bit quicker than the fronts anyway.
GregM
Sep 5, 2016 11:52 PM
aml15
Feb 8, 2012 05:55 AM
koullis
Feb 22, 2009 01:40 PM
Prodigal
Jul 18, 2008 11:30 AM
ra_lancer
Mar 16, 2006 01:34 AM
Quick Reply: Staggered wheels
