Need some help on wheels....
Old Nov 27, 2006, 09:28 PM
eggbread's Avatar
I wanted to know the evo 9 wheel pattern???? Is it 5x114.3...???????
Im looking to get some 17/8 and 17/9 in the back....
What kind of off set's for the both??????????
Old Nov 27, 2006, 09:30 PM
Blue By You Evo's Avatar
yes it is 5X114.3. you should do the 9 inch wide rim in the front. This isnt a camaro. The reverse stagger helps with the understeer from factory. Or just go 17X9 all around.
Old Nov 28, 2006, 08:05 AM
eggbread's Avatar
I see, so as far as 9" wide wheels they fit no problem...
I'm also interested in some 18x8.5 and 18x9.5......will a 9.5"fit the back??????
I need the offset numbers......for both....
Old Nov 28, 2006, 08:10 AM
Smike's Avatar
Location: somewhere testing various tires, brakes, and suspensions.
Maybe you didnt understand?
You dont need 2 different widths. The set of 4 should all be the same.
Search - there is a mega thread with what wheels fit and whatnot...
https://www.evolutionm.net/forums/sh...ad.php?t=53487
^^ there you go...search wheel fitment, took 2 secs - and your welcome.
Old Nov 28, 2006, 09:19 AM
eggbread's Avatar
Aight thanx, i did understand that....but i really dont care about the underster....
Old Nov 28, 2006, 09:30 AM
Smike's Avatar
Then you dont car about how this car drives.
If you want to stagger get a 350z or Camaro or Mustang (hint RWD platforms).
You will get more help if you actually are doing something correctly. When you do something that does not help or makes more problems (in this case - causes more understeer for the sake of looks) then people will be less apt to help you.
Old Nov 28, 2006, 11:51 AM
eggbread's Avatar
Yeah i hear ya....So 18X8.5 all the way around would make more sence then...
I found a set of 4 and i wanna order them...is just i dont know what offset to get since all wheels are lill diff....I have to make sure it will clear the calipers...
Old Nov 28, 2006, 12:06 PM
Smike's Avatar
Were you able to find them in the wheel fitment thread? What kinda are they? Maker, from where, etc?
Old Nov 28, 2006, 12:49 PM
eggbread's Avatar
No they are not in the thread, they are not expensive wheels..I found them in some tuner mag.....
Its sportmax's 962
Old Nov 28, 2006, 12:55 PM
Smike's Avatar
These?
This might be helpful:
http://www.rims-n-tires.com/info_specs.jsp
Stock rims are:
17 x 8JJ OFFSET +38mm
(http://64.233.187.104/search?q=cache...s&ct=clnk&cd=2)
Old Nov 28, 2006, 01:00 PM
eggbread's Avatar
yes those....in 18x8.5....
Old Nov 28, 2006, 01:09 PM
Smike's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=195153
+35
Clearance: Package 2
Package is 2 mm (0.1'') closer to suspension/brakes components.
Fenders Package will stick out 8 mm (0.3'') farther.
Wheelwells Will fill out the wheelwell by extra 5 mm.
Old Nov 28, 2006, 01:31 PM
eggbread's Avatar
thanx bro....
Old Nov 28, 2006, 01:32 PM
Smike's Avatar
Old Nov 28, 2006, 01:58 PM
evo150's Avatar
here is a link to them on a evo......https://www.evolutionm.net/forums/sh...d.php?t=193264
Quick Reply: Need some help on wheels....
