Brembo rebuild kit + diagram
I need a exploded diagram of the brembo brake calipers (like the pic) and does anybody know if rebuild kits are available for the Brembos yet?
All that's required for a usual caliper rebuild are just the piston seals and maybe the dust boots - I say maybe because these usually burn out if you're a racer. In the rare occasion that the piston would get stuck out sideways, you might end up needing new pistons and maybe some slight honing of the caliper piston walls. I've purchased at the dealer a rebuid kit that consists of seals and boots. Hope this helps.
I normally drop these off at my local caliper rebuilder. I have him sell me the seals and boots, and I finish the r&r myself. Make friends with your local auto parts guy, he (or she) should be able to hook you up, without having to go to Mitsu.
Darin
PM me if you need more help with this.
Darin
Originally Posted by jdm4g63tgalant
how much did you pay for this kit? was it just seals and boots? my dealer said they only had a kit with pistons and all and that was way too expensive.
I originally asked this question in reference to tearing down the calipers, repowdercoating them, then rebuilding them. I wanted to be sure that I could get them apart and back together without damaging or destroying them.
I bought one (1) front caliper from someone on ebay and took it apart. I am having a serious time trying to get the boots back in. Maybe I am doing something wrong.
I put the project on the back burner until I saw the thread had been revived. maybe Ill try again this weekend.
Is it leaking fluid out of a piston seal?
As for the calipers.....mine are pretty much gloss dark brown. The paint hasn't come off its just changed color (a few times - darker and darker).
