EVO bolt pattern & offset?
Ok.. I need to find some new wheels for rallycross and winter.. But i don't know the offset or bolt pattern. anyone know this?
Thanks,
-Zach
Thanks,
-Zach
Originally posted by zyounker
Thanks.. What is the recommended offset?
And sorry not familiar with H-P.C.D.. what does that mean?
Guest
Posts: n/a
Offset is the distance between the mounting face of the wheel (the center part with the holes in it that touches the disc) and the imaginary center section of the wheel.
Imagine you have a wheel that is 8 inches wide "standing" in front of you. The "middle section" would be the imaginary vertical line 4 inches from each end. The distance between that and the mounting face is the offset.
Guest
Posts: n/a
Re: EVO bolt pattern & offset?
Watch spoke design for caliper clearance!
(If you choose a wider wheel, the offset will need to be different if you want to keep the same track.)
Yeah, i know what offset is.. didn't know what the letters ment.. Thanks though..
-Zach
Icecube79
Apr 12, 2008 12:45 PM
evilution8
Dec 30, 2004 12:24 PM
Greyman09
Jul 12, 2004 04:21 AM
