Oct 25, 2004, 04:48 PM
Personal Sales Rating: ( 6)
uneven tire wear...?
i looked at my front tires today and to my suprise the inside tread were all worn down to noting..the rest from the inside on out looks fine w. the miles on my car(14k) weird thing is both the left and right were the same..
1.could this be because of tire pressure...? i check it and it was @25 psi
2. alightment issues..?
3.whats the stock tire pressure anyways...? isnt it 32psi..?
well i have to buy new tires for the winter anyways..just wanna make sure theres no probs...for me next summer...
thanks..
Offline
Oct 25, 2004, 04:51 PM
Personal Sales Rating: ( 0)
Drives: '04 LanEvo (bby)
mainly a factor of alignment... but, pressure played small part...
Offline
Oct 25, 2004, 05:08 PM
Personal Sales Rating: ( 27)
Drives: 2006 CT9A SE
1. Have you ever rotated the tires?
2. Have you ever had your alignment checked including what the pre-inspection alignment specs were?
3. Factory tire pressures are listed in your owner's manual. 32 PSI for the front and 29 PSI for the rear.
Offline
Oct 25, 2004, 05:20 PM
Personal Sales Rating: ( 16)
Drives: Evolution VIII, 87 Mustang GT T-Top
coulda been unlucky like me... i lost my stockers & 6k miles
Offline
Oct 25, 2004, 05:23 PM
yeah ive rotated the tires 3 times now...
no ive never check the alightment..maybe i should now...would the dealer do this under warranty..? i have no suspension mods...
thanks
Offline
Oct 25, 2004, 05:46 PM
Personal Sales Rating: ( 3)
Drives: 111SM
your alignment is off. The top of the tires are pointing inside like / \ .
Get your alignment done and have your tires balanced.
They wont warranty something like tire wear due to mis-alignment. But it's worth a try. They'll tell you its normal wear and drivers fault.
Good luck.
My tires are wearing middle out, but that's how E100 yokos wear pattern is...
Offline
Oct 25, 2004, 06:30 PM
Personal Sales Rating: ( 2)
Drives: 2006 Subaru 2.5 GT
My tires were completly gone on the inner part of the tire at 4K. They replaced all four under warranty and gave me a free alignment. Your tire pressures are way too low!!!!!!
__________________
2006 Subaru 2.5 GT Limited
Offline
Oct 25, 2004, 07:26 PM
Personal Sales Rating: ( 4)
Drives: Z06 Vette(SOLD!!!), Civic, Evo VIII
The Evo is the only car I know of that comes with a bad alignment as a standard option  Seriously a lot of people on this board (myself included) had problems with tires wearing uneven. I had to get my car aligned at 2500 miles, and it was way off.
__________________
Attn Mitsubishi: Any and all modifications to my vehicle are equal or higher in quality and performance to those that were provided stock. As such under Title 15 Chapter 50 of U.S. Code (aka the Magnusson-Moss Warranty Act of 1975) particularly Section 2302(c) Mitsubishi must honor the warranty as provided with the car. Any refusal of service must be accompanied by absolute proof that an aftermarket component was the cause of any failure in the OEM materials. Failure to adhere to the letter and spirit of the law will result in prompt legal action against Mitsubishi and/or their authorized dealer.
Offline
Dec 6, 2004, 07:22 PM
Drives: 2003 Apex Silver Evo VIII
Good luck.
Not necessarily.....usually when it's the very inside of the tread wearing fast it's a toe-out condition.
Hey Q, what up bro? You like those 272 bumpsticks? Damn over 330whp. Sounds like I need to add those to my list. TTY soon. -Adam
Offline
Dec 6, 2004, 09:57 PM
Personal Sales Rating: ( 56)
i rotated my tires and now my alignment is off
Offline
Dec 6, 2004, 11:19 PM
Drives: '03 Lightning Yellow EVO VIII
Quote:
It might not be alignment, it might be the way your tires wore out. I had the same thing in my other car. Car was pulling badly to the left, I switched the fronts with the rears and it was normal again. If your alignment was bad it should do the same thing no matter which side you put on. In the EVO case only front with the back.
Offline
Dec 8, 2004, 11:31 PM
Quote:
that what i was thinking, guess i have to wear out the tires in their new position to get back to normal
Offline
Dec 9, 2004, 12:36 AM
Drives: 04 evo
i have the same problem, inside out tire wear. i gotta get this thing allingned.
Offline
Jul 19, 2009, 08:52 AM
bumping an old thread:
I am at 12k miles, no agressive driving to speak of (had the car about 20 months) and the inside tread block on the stock advans is worn almost all the way to the cord. I rotated them today and will be getting an alignment.
My car is 100% stock btw and has never seen a track of any kind
__________________
2006 GG Evo MR
SR22VE Sentra (project car)
Offline
Jul 19, 2009, 09:24 AM
A rifle doesn't come sighted in from the factory. Neither does the Evo.
Offline
Tags
back, car, evo, middle, mitsubishi, patterns, shepherd, side, stage, tire, tires, transfer, tread, uneven, wear, wearing  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
