Shining Monkey SUCKS!!! DONT BUY
Old Sep 20, 2004, 03:55 PM
Handmemyarms's Avatar
ive had a lot of good looks from that new maguires hot shot spray, the one with the adjustable nozzle depending on your tires wall size, really spits out an even amount with no foam, just straight up clean
Old Sep 20, 2004, 03:57 PM
FDMH27's Avatar
yeah, eagle one all the way...works perfect!
Old Sep 20, 2004, 04:33 PM
evo81's Avatar
i was gonna try this stuff .anyways,i use blackmagic tire spray.it looks ****
Old Sep 20, 2004, 05:50 PM
Originally Posted by evo81
.it looks ****
ah god, my dad says that
Old Sep 20, 2004, 06:10 PM
Z1 Performance's Avatar
wow this is surprising. I had exactly the opposite experience with the can I got....and i did mine with the tires both wet and dry so far, both with the same results. No splatter, and a very even satin finish (not overly glossy which is what I wanted)
Old Sep 20, 2004, 06:49 PM
mrdecibel's Avatar
Shining monkey works great on "Clean" rubber. Did not work too well on rubber that looked "Clean", but held up on actual "Clean" rubber. Only problem I have is that the stuff lasts so long, it doesn't wash off when you want it to. Also, no way to control overspray from aerosol can. My polished lip on my wheels doesn't care too much for that monkey. It wants to spank it.
Old Sep 20, 2004, 06:53 PM
purecoda's Avatar
eagle one with their foam applicators. great shine, long lasting. never tried the monkey though.
Old Sep 20, 2004, 06:56 PM
WannaRace's Avatar
IMHO this stuff is awesome. It does take maybe a 1/3 the can to get the desired results that I'm sure everyone buys it for, but it leaves it there for I dunno how long, I've had it on for about 3-4 weeks now, no joke, and it hasn't changed much. Great stuff..
Old Sep 20, 2004, 07:42 PM
lil'evil_evo's Avatar
good review. You should contact them to see if they will give you a new can?
Old Sep 20, 2004, 08:19 PM
vegasboy301's Avatar
this guy is old enough to be your dad. "damn broads"
Old Sep 20, 2004, 08:27 PM
gonzo's Avatar
Good one son.
Old Sep 21, 2004, 01:47 AM
evo81's Avatar
i love using old slang like ****,broads,and square
Old Sep 21, 2004, 01:52 AM
petey pab's Avatar
you did CLEAN your tires before you put it on right???
Old Sep 21, 2004, 02:10 AM
SinCityEvo's Avatar
Cleaning the rubber is very important for any tire shine. I use Westley's Bleach White. Spray it on, then take a bristle brush and scrub the sidewall. It removes that brown grime and old tire dressing and leaves a squeaky clean sidewall perfect for applying the tire shine. Westley's is the first thing I grab when I'm readly to wash the car. Using it for years.
Old Sep 21, 2004, 05:23 AM
stevEVO8's Avatar
Yep I cleaned my tires before I put it on. and the rest of the car and then waited for the tires to Dry before I put it on.
Either way, if its that much of a pain in the *** its not worth it in the long run. I dont have the need to contact them since I really dont think that there is a way for them to improve on what they currently have. Maybee in a couple of years or so it might me worth another try, but this stuff really aint all its cracked up to be.
Quick Reply: Shining Monkey SUCKS!!! DONT BUY
