Relocating rear bumper bolts to fit agressive wheels
Old Nov 13, 2010, 08:40 PM
SSSLOW's Avatar
Hi all, I'm currently attempting to fit my 18x9.5 +15's onto my Evo. As most would know this requires removing/relocating the bolts and tabs that hold the rear bumper onto the rear guard panel.
Can everyone that has had to do this mod please post up your experiences and exactly what you did? I know a few people have just moved the tabs back about an inch but I wanted to find out what is involved exactly?
Even better, if other people have come up with other solutions please share them. Pictures would help too!
Old Nov 13, 2010, 10:12 PM
compscibOi's Avatar
I just finished fitting 18 x 10.5 + 30 Enkei NT03+M wheels on my Evo IX and did no such thing... Where are you getting your information from?
Old Nov 13, 2010, 10:20 PM
dtrackstar's Avatar
https://www.evolutionm.net/forums/ev...ve-stance.html
get in touch with this guy OP and from the looks of your wheel specs. you're probably running the same rims as the guy in the link
Old Nov 13, 2010, 11:05 PM
chaotichoax's Avatar
larger wheels with low offers (below 25'ish) will require you to relocated the fender well rear bumper bolt more towards the rear of the car
Old Nov 13, 2010, 11:35 PM
SSSLOW's Avatar
Experience! I test fitted them and while it's fine on a flat surface once I need to go up incline (e.g driveway) I can very much hear the tabs going over the tread. Pretty much like when kids put a playing card in between the bike spokes - That type of sound
I have no idea how you are getting away with those wheels specs and not relocating the bolts? Unless your rear is sitting quite high or you have some serious camber going on?
Thanks, I was going to do that first but thought I'd make a thread as no doubt there will be many others in the future that will want some info on this topic aswell.
Old Nov 14, 2010, 12:19 AM
check this link op
https://www.evolutionm.net/forums/4429383-post9.html
Old Nov 14, 2010, 12:27 AM
idrink_v8's Avatar
Your +15 offset is, too low. You need a offset of +22 to +30 with 18x9.5 245 series tires so you won't have that problem. Also rear fender roll, depends on how low you wanna go.
Old Nov 14, 2010, 06:18 PM
SSSLOW's Avatar
Originally Posted by chaotichoax
Thanks for that! Very helpful!
Old Nov 14, 2010, 07:43 PM
glad I could help
Old Nov 14, 2010, 08:52 PM
compscibOi's Avatar
This.
Increase your offset and you won't have to deal with such nonsense as "relocating a bolt..."
I have camber and a few other tricks but did NOT require relocating any bolt...
Old Nov 14, 2010, 09:57 PM
SSSLOW's Avatar
This.
Figures below based on standard Evo 8 5 spokes - 17x8 +38
18x9.5 +15
The clearance from strut housing to the inside of the wheel will be 4mm MORE
The outside edge of the wheel will EXTEND an extra 42mm
18x10.5 +30
The clearance from strut housing to the inside of the wheel will be 24mm LESS
The outside edge of the wheel will EXTEND an extra 40mm
I've got an extra 2 millimeters on you . I stand by what I said you are either running serious camber or 4WD suspension. Eitherway you don't require the bolt mod so props to you
Old Nov 15, 2010, 03:37 AM
compscibOi's Avatar
Did you already buy the wheels? I also run a 265 tire. Just because other people can't does not mean it doesn't mean it can't be done. I love when people say that. Then I prove them wrong.
Old Nov 15, 2010, 07:07 AM
Received 1,384 Likes on 1,317 Posts
If your anticipated / current wheel & tire set-up cant do this, then they dont fit.
The pic shows the rear strut removed, fully stroking the travel & making the proper clearances. Any track day or even aggressive street driven Lancer can see this type of suspension articulation
(Adding aggressive camber or raising CoilOver height is not the way to get your wheels to fit)
(Rear bumper bolt relocated / fender roll & pull (275/40/17 tire +29 offset -1.0 rear camber)
Peace
Old Nov 15, 2010, 01:01 PM
NocturnalEVO's Avatar
+1 for an answer to OP's question. I'm about to tackle this myself this coming weekend as my tires are getting chewed away from that bolt hah
i'm also on 18x9.5" +15
Old Nov 15, 2010, 01:56 PM
ajstefanacci's Avatar
I had the same problem with 18x9.5 +30 275/35 tires on them. I had to relocate the bolt. I just drilled two holes after the bolt, closer to the back of the car and used some nuts, bolts and washers to secure it and then cut off the tab. It holds just fine and doesn't hit any more.
Quick Reply: Relocating rear bumper bolts to fit agressive wheels
