Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Show & Shine
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old May 8, 2009, 08:40 PM   #1
Personal Sales Rating: (10)
vegasse's Avatar
Chargespeed Evo....then vs now
Figured this would be interesting, and I'll start with the after pics.
NOW!
When I bought the car.........
Exterior when I bought it.......
2004 Mitsubishi Evolution 8
Chassis has 36k on it. Mods have less than 2k.
Engine:
Fully Built 2.3L Stroker
Pro-Gram Billet Main Caps
Fresh Core
Fully Sleeved Block by Darton
Crower Forged Rods
Crower Billet Crank
CP Pistons
ARP Main Bolts
ARP Rod Bolts
Buschur Racing Stage 3+ race head
Fresh Core
Ferrea dual stainless steel valve springs
Ferrea titanium retainers, locators, and locks
New Valve Seals
Custom BR Bronze valve guides
Supertech Nitride Coated Intake Valves
Supertech Nitride Coated Exhaust Valves
Stainless O-ring around each combustion chamber
Complete port & polish
New Bronze Valve Guides
ARP L19 Head Studs
Fluidampr Harmonic Balancer
Virtual Works Racing Aluminum Intake Manifold
4 inch Virtual Works Intake
AMS front and side engine mounts
ARC Radiator Cooling Panel Powdercoated Black
Black Powdercoated Valve Covers
Billet Timing Tensioner
Power Enterprises Kevlar Timing Belt
Power Enterprises Kevlar Accessory Belt
818 Billet Power Steering Cap
Sparktech COP Pro CDI-12
HKS 280/280 Cams
HKS Adjustable Cam Gears
Fuel:
AMS Fuel Rail
Fuel Lab Fuel Pressure Regulator Black
Bosch Saturated 2000cc Injectors
AMS Surge Tank
Weldon 2035a Fuel Pump
Exhaust:
Greddy Ti-C Downpipe back Exhaust System
Virtual Works Racing Stainless Downpipe
Turbo + Cooling:
Virtual Works Racing Coated T4 Race Header
Tial Polished 44mm Wastegate
Precision 6262 Dual Ball Bearing Billet Wheel Turbo
DEI Titanium Turbo Heat Shield
Virtual Works FMIC
Virtual Works Custom Stainless 3.5 inch intercooler piping
Tial Q-Trim BOV
Virtual Works Stainless Pipe Strapping
Virtual Works Upper + Lower Radiator Hard Pipes
Fluidyne Aluminum Radiator
Mishimoto Race Thermostat
Virtual Works Custom Aluminum Overflow Can
Virtual Works Custom Aluminum Breather Can
STM Billet Radiator Tie Downs
Blitz 1.3 bar radiator cap
Spal 1630cfm Electric Fan
DEI Ny-Trex Nitrous Oxide System w/purge
DEI Bottle Heater
DEI Cryo-2 Intercooler Sprayer
Transmission:
Shepherd Racing Stage 2
New throwout bearing
New clutch fork, pin and return springs
New speedometer gear and sensor
New slave cylinder and line
REM ISF process (sliders)
REM ISF process (gearset assembly)
Double synchro 5th gear option
Billet Output Shaft
Shepherd Racing Stage 3 Transfer Case
Quaife LSD front differential
8mm to 10mm bolt upgrade
New seals and o-rings
Reshimming
Neodymium magnet
REM ISF Process
New ring and pinion with bearings
Shepherd Racing Rear Differential
Cusco LSD
REM ISF Process Ring + Pinion
Buschur Racing Rear Moustache Bar
Buschur Racing Rear Billet Side Diff Mounts
Drive Shaft Shop Stage 5 Rear Axle/Hub Kit
Exedy Triple Ceramic Clutch
AWD Motorsports Aluminum Driveshaft
Buschur Racing Driveshaft Loop
Works Short Shifter
ARC Titanium Shift Knob
Kartboy Shifter Base and Shifter Bushings
Suspension:
Tien Monoflex Coilovers
ARC Front Strut Tower Bar
Cusco Rear Strut Brace
Cusco Front + Rear Sway Bars
Wheels:
Volk Racing RE30 18x9 (black gloss powdercoated)
Volk Carbon GT High Center Caps
Advan Neova AD08 265/35/18
Volk Racing Duralumin Lugnuts (black)
Brakes:
Endless Racing 6 Piston Race Front Brake Kit
Endless Racing 4 Piston Race Rear Brake Kit
Endless Stainless Covered Teflon Swivel Brake Lines
Endless Brake Pads
Zeal Slotted Rotors
Interior:
Rexpeed Carbon Fiber Dash
Rexpeed Carbon Steering Wheel Gauge Pod
Rexpeed Carbon A-Pillars
Ralliart Aluminum Door Sills
Kenwood DNX8120 indash Nav/DVD
Mitsubishi JDM Double Din
Orbital HVAC conversion kit
Greddy EGT + Oil Temp gauges
AEM Boost + AFR Gauges
AEM Stand Alone EMS
AEM 5 Bar Map Sensor
Tyrant Carbon Armrest
EVO SE Leather/Suede Seats
ARC Shift Knob
Exterior:
Chargespeed Vented Carbon Hood
Chargespeed 20mm Fenders
Chargespeed Carbon Vortex Generator
Chargespeed Type 1 sideskirts
Chargespeed Type 1 front bumper
Chargespeed Type 1 rear bumper
Chargespeed Rear Carbon fiber diffuser
Rexpeed Carbon Fiber J-Panels
Rexpeed Winglet
Mitsubishi Carbon Fiber Evolution VIII Truck Emblem
Hyboost Performance Edged + Tinted headlights
Hyboost Performance Tinted taillights
Smoked Side Markers
Dafarmer LED License Plate Light
Rexpeed Carbon Mirror Covers
Custom Apex Silver w/ slight blue pearl in paint
Evo XI Wing
Online
Old May 8, 2009, 08:48 PM   #2
Personal Sales Rating: (13)
19DB794's Avatar
Drives: 2006 Mitsubishi Lancer Evolution IX MR
Send a message via AIM to 19DB794
looks much cleaner now. I really like how the ARC spark plug cover looks painted too.
__________________
Graphite Gray Evolution IX MR
| AEM | Alpine | AMS | ARC | Defi | ETS | GReddy | Hallman | Megan Racing | Perrin | Ralliart | Walbro | Works |
Turco Tuned: 330 Whp 300 Ft/lbs Tq @ 25PSI On ESP's Mustang Dyno.
12.537@111MPH 1.944 60'
Offline
Old May 8, 2009, 08:50 PM   #3
vegasse's Avatar
Quote:
I agree. I wanted an "anti JDM" look. I don't like the bold mismatched colors, etc....I prefer it to be "muscle car clean" under the hood. The ARC cover is actually powdercoated black.
Online
Old May 8, 2009, 09:12 PM   #4
Personal Sales Rating: (43)
hks03evo8's Avatar
looks very good. almost hurts your eye on those 2 last pictures haha
Offline
Old May 9, 2009, 02:32 AM   #5
Personal Sales Rating: (3)
sinpul's Avatar
Drives: 04 evo
what did you do with the old setup? nice!!!
Offline
Old May 9, 2009, 04:24 AM   #6
Personal Sales Rating: (4)
whitepwr's Avatar
Drives: 04 WW SSL Evo/BlkonBlk single 2jz Lexus SC400
Looks good! Whats the rest of the car look like?
__________________
2004 WW Evo8 SSL - OUT-OF-ORDER: Built Motor, Big Turbo, Big Power.. coming soon.
Offline
Old May 9, 2009, 04:31 AM   #7
Personal Sales Rating: (0)
Drives: EVO VIII
very clean
Offline
Old May 9, 2009, 08:04 AM   #8
Personal Sales Rating: (6)
2008 Mitsubishi Lancer Evolution
My Garage
joowick's Avatar
Drives: 2008 PB Evo X GSR, 2009 OB C63
Send a message via AIM to joowick
Looks alot cleaner with the powder coated ARC cover.
__________________
K.
AMS PERFORMANCE | E AUTO | HB SPEED
AMS Downpipe | AMS Intercooler | AMS Upper & Lower Intercooler Pipes | AMS CAI | AMS Delrin Shift Knob | KW V3 | HKS 4Pt Rear Strut Brace | AMS High Flow Cat | Bride Zeta 3 | Invidia N1 Exhaust | Tuned by HB Speed
Offline
Old May 9, 2009, 08:25 AM   #9
evosam726's Avatar
Drives: WW IX,07 white Rav4, sold my teggy type-r
Send a message via AIM to evosam726
looking good bro keep it up
__________________
EvoSam
stuff wit some more stuff um
tanabe gf210 springs
jdm rear
apr lip
braille in-cabin brace
gt-spec rear trunk cage
uk cf evolution ix trunk badge
eclipse head unit w/ ipod adapter:D
stockturbo
4 sale
stock uicp w/ tial flange
stock radiator
stock evo ix cam's
stock fuel pump
:::just >726< here:::
Offline
Old May 9, 2009, 08:30 AM   #10
Personal Sales Rating: (21)
edardnaekim's Avatar
Drives: yes
Send a message via AIM to edardnaekim
Looks awesome! What kinda rad is that? Love the rad hard pipes too
Offline
Old May 9, 2009, 09:19 AM   #11
Personal Sales Rating: (1)
veilside prius's Avatar
Drives: IX TB GSR, 96 Integ GSR(ultimate DD)
that is clean .. I would kill for your rides
Offline
Old May 9, 2009, 09:27 AM   #12
Personal Sales Rating: (18)
SOEuro's Avatar
Drives: BBY 03 Evo VIII,06 GG IX MR,01 VW GTi,95 Eclipse GST(sold)
what intake mani is that?
__________________
I.Y.A.A.Y.A.S. US Air Force
A.K.A. Evo_Stone
BPU +++ Evo
Quote:
Originally Posted by Dynoflash View Post
Ok, this is what is going on
All the Evo vendors are realizing what total crap boxes Evos and and how badly they suck. Now that they are seeing what kind of great results are being obtained with Subarus - of course everyone wants to jumop ship and drive a real car. LOL
How can you blame them? Subaru is the best, everyone knows that.
Al
Offline
Old May 9, 2009, 10:27 AM   #13
vegasse's Avatar
Quote:
Sold it to my buddy with an Evo. All except the Full Race header which I'm going to sell.
Quote:
I'll post those pictures in a few days when the brakes are done.
Quote:
PWR radiator. The hard pipes are Virtual Works. The lower one is pretty extreme. I'll take some more detailed pics next week.
Quote:
Virtual Works Racing one of a kind prototype intake manifold. I think VWR is going to start making parts for the Evo. They did, on this car.....
Intake Manifold
Turbo Manifold
Intercooler
Intake Piping
Upper and Lower Radiator Hard Pipes
Custom Overflow and Breather Can Set up
Online
Old May 9, 2009, 11:05 AM   #14
Personal Sales Rating: (15)
Drives: viii mr
Send a message via AIM to jxs1984
what oil catch can is that?
Offline
Old May 9, 2009, 12:26 PM   #15
vegasse's Avatar
Quote:
Also a Virtual Works Racing custom piece.
Online
Tags
amsperformance, bby, black, chargespeed, cover, diffuser, evo, hyboost, las, performance, plug, spark, tyrant, vegas, vortex, white
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
