Need a garage? check this crazy thing out
yeah, this is not for a stand alone garage, it will fail if left outside in the elements. its a huge PITA to put a car in and out of one on a daily basis. car must be perfectly clean top to bottom before entering one or it gets gunked up really quick. its for circulating air in side the capsule so that dust cannot "settle" on the car for LONG TERM storage. as pointed out in this thread by another member i have one and am speaking from experience. and its called a "CARKUNE" (spelling)
i almost pissed my pants after i read that. OMG i would just die if i was cruzing around and saw someone struggling to get there car in it and inflated. off to the side of a parking lot with a orange extension cord running to the building and up through a window.
well i see you and that guy went to the same school because your thought patterns seem to be just as jacked up. for one, it would be hard to make anything fly with nitrogen because it's heavier than air. the second part of that is also stupid because nitrogen is an inert gas. it won't burn. it's actually used to snuff out fires. i believe the element you're looking for is HELIUM...slightly different than nitrogen.
Edit...Nitrogen's technically not an inert gas, either... only the Noble elements are... but it's "inert enough" to make your point...mostly...
