Apr 23, 2009, 03:15 PM
Gold Sponsor
Personal Sales Rating: ( 175)
Drives: BCNR33, s13, S4, CT9A, GDB
Brake Pads $125 F&R Shipped-Stage1 Brake Package $250
Hey guys get ready for some great Brake Combos! With multiple pad options you can build your own combo to suit your needs! BBK also on sale so dont miss out before prices go up!
All Brake pad prices are for front and rear.
Endless Brake Pads
Vita Nuova
Endless has produced the Vita Nuova compound for entry-level users who are seeking improved performance while retaining maximum comfort. Designed for everyday street conditions, the Vita Nuova compound is most popular with drivers looking for affordable street performance. The Vita Nuova compound also functions at low temperature while producing minimal noise.
SSS
Endless produces the standard sporty street pads within the Super Street Series brake pads. Within our lineup, the Endless S-Sports compound is produced from various sources of feedback. Endless S-Sports pads are designed to maintain stable and consistent braking performance and feedback even as rotor temperatures change. With the high level of feedback and consistent braking performance, even novice drivers can take full advantage of their stopping power. Endless is proud to offer a large and comprehensive lineup of S-Sport pads for almost all Japanese car models.
MX72
"Ceramic\"� is known to be one of the most vital and essential compounds which influence braking capacity. Every material has been carefully chosen for the MX72 in order to produce minimal noise and dust while producing high brake capacity during lower temperatures. Braking stability was also improved under higher temperatures while decreasing rotor wear. Pedal feel, which is typically great in semi-metallic material pads, was further improved upon.
Vita Nuova
03-07 Evo 8-9 $190 Shipped
SSS
03-07 Evo 8-9 $330 Shipped
MX72( CCX Replacement)
03-07 Evo 8-9 $430 Shipped
Performance Friction Brake Pads
JGTC Approved
For those not familiar with Performance Friction, PFC discs have become the standard at the highest levels of professional motorsports. PFC discs are used throughout Nascar with this attachment system, which was developed specifically to eliminate vibration, pulsation, cracking, and excessive weight. They're used by many of the Cup, Nationwide, and Truck teams including Roush Racing, Yates Racing, Evernham, KHI, and many others. PFC discs are also used throughout the highest levels of road racing including by the majority of Daytona Prototype, Koni Challenge, Atlantic, Formula Nippon, JGTC, F3, Star Mazda, and former Cart competitors to name a few. Ganassi Racing has used them to win multiple DP Championships, and the 24 Hours of Daytona 3 years in a row. In GT500, 60% of the field ran PFC discs in 2008, while 93% were on PFC pads. As for F1, it is the only non carbon brake disc package on the track.....as they are used on the AMG Pace car!
It should also be noted that each and every component found around the globe bearing the Performance Friction name was produced in house at one production facility in Clover, South Carolina, and was manufactured under the most stringent quality standards in the industry.
03-07 Evo 8-9 $195 Shipped
Peak Performance HP-Pro
For the aggressive street car that will handle track temps.
Now Available at Gruppe-S. Don't confuse these pads with Standard HPS or HP+ Pads in a different box. These pads are a Brand New Special Compound Designed Exclusively for Peak Performance. Peak Performance HP-PRO™ Brake Pads. Using a secret compound blend formulated by Hawk Performance™, HP-PRO™ Brake Pads offer an extremely high coefficient of friction making these a perfect upgrade over stock for high performance streetcars used in Drifting, Autocross, Time Attack or drivers that experience repetitive, heavy braking. Peak Performance secret compound gives you uniquely controllable torque with smooth consistent feel and bite. This compounds allow for later and deeper brake use into the corners while requiring less pedal effort and shorter pedal reaction times. They do not require significant heat up or extensive bedding (break-in), and have exceptional wear characteristics allowing you to get more laps per set with no warm up required. HP-PRO™ provide superior release and torque control characteristics. HP-PRO™optimal temperature range is 95-1,250 degrees Fahrenheit.
MSRP $189 Front
MSRP $159 Rear
Peak Performance Street Plus Pads
Affordable OEM Replacement
Auto enthusiasts require brake pads that produce no dust, no noise, and stop in hot and cold situations. These are very demanding requirements for a street pad. “Street Plus” Disc Brake Pads provide the superior stopping power that drivers are looking for. Optimized for street performance, these pads work over a wide temperature range. They withstand high temperatures and resist fading with out compromising cold weather stopping.
Peak Performance Street Plus Disc Brake Pads, “low resin” formulation, is manufactured with a “Positive Mold” process insuring strength, quality and performance. Peak Performance Street Plus Disc Brake Pads advanced low dust formula provides excellent durability, quick recovery, and is rotor friendly compared to conventional brake pads.
03-07 EVO 8-9 $125 Shipped
Dont settle for those cheap Ebay rotors you see all day for $199. Gruppe-S offers only the best selection of brake rotors. If we wouldn't use them on our personal cars we wouldnt sell them!
Prices Listed are for Front & Rear Unless Specified
Peak Performance Slotted Rotors
Brembo Cores
100% American Made. Not the cheap China rotors you see on ebay.private labeled from a world-famous OEM rotor manufacturer and offer the best value in a high performance rotor system for your car. Manufactured to the same specifications as OEM components in an ISO certified production facility. The rotors are made using high quality casting techniques and precision machined to provide the maximum stopping and cooling efficiency. Rigorously tested on track and street cars these rotors offer long life, reduced brake fade, reduced pad wear, and improved wet / dry weather braking.
03-07 EVO 8-9 $425 Shipped
Endless Race Rotors
Used In Super Takiyu
Used in Japan\'s top motorsports venues such as the Super GT, our research and development has led to the development of our 2-piece racing brake rotors. The rotor and bell housing are separate units. The bell housing is a strong duralumin material that withstands high temperatures. The rotor material is created using proprietary Endless technology which combines a special carbon blend in the rotor material. This process lowers the possibility of heat cracks while keeping a consistent level of friction with the brake pad, thereby maximizing performance.
03-07 EVO 8-9 $1375 Shipped
***Fronts Only Available***
Performance Friction 2pc Rotors
Used in JGTC
These rotors allow you to retain the Stock Evo Brembo Calipers (which are excellent pieces) while reaping all the benefits of a 2-piece rotor. They are 4.4 lbs. lighter per rotor than the stock pieces meaning that unsprung and rotational mass are dramatically decreased. This will create better feedback and improved handling. These rotors are also vaned to improve cooling over the stock pillared units. Finally, dimples ensure that your pads are adequately refreshed while maximizing surface of the rotor and preventing cracking (as compared to crossdrilled rotors).
-2-piece design allows aluminum hat for lightweight rotors.
-Full floating design allows expansion of rotor and hat at different rates to prevent pad coning.
-Lightweight - 17.6 lbs per rotor (stock rotors are 22 lbs.).
-Dimpled to increase surface area of rotor (promotes cooling), refresh pads, and less prone to cracking than cross drilled rotors.
-Vaned to promote cooling.
-Allows you to retain stock Brembo calipers.
03-07 EVO 8-9 $725 Shipped
Rebuild Kits Also Available. PM For Price
Complete Brake Upgrades
Complete Solution Front & Rear
Stage 1 Combo
Gruppe-S Steel Braided Brake Lines
ATE Super Blue Brake Fluid
$250 Shipped
Stage 2 Combo
Peak Perfromance Slotted 1pc Rotors
$665 Shipped
Stage 2 Plus Combo
Peak Performance Slotted 1pc Rotors
Performance Friction Z pads
$725 Shipped
Stage 2 Race Combo
PF 2pc Front Rotors
Peak Performance Slotted 1pc Rear Rotors
Endless MX72 Pads
$1495 Shipped
Need More Stopping Power. Check out our BBK
Endless 6 Piston BBK
PM for Price
Brembo 6 Piston BBK
PM For Price
Willwood 6 Piston BBK
Super Affordable
PM For Unbelievable Price
Project Mu 6 Piston BBK
Pm For Price
__________________
Gruppe-S
20521 Teresita Way
Lake Forest CA 92630
949-457-1234
email: sales@gruppe-s.com
paypal: payments@gruppe-s.com
Please Note:
- All Items Are Shipped Via UPS.
- All Orders Are Repackaged To Help Prevent Any Damage Which May Occur During Transit.
- Any Order Cancellation Will Result In A 25% Processing Fee.
- Local Pick-Ups Available. Please Call For Details.
- No Cancellation on JDM Or Special Orders. No Exceptions!
Offline
Apr 24, 2009, 01:02 PM
Gold Sponsor
__________________
Gruppe-S
20521 Teresita Way
949-457-1234
Please Note:
Offline
Apr 27, 2009, 12:05 PM
Gold Sponsor
__________________
Gruppe-S
20521 Teresita Way
949-457-1234
Please Note:
Offline
Apr 28, 2009, 11:32 AM
Gold Sponsor
__________________
Gruppe-S
20521 Teresita Way
949-457-1234
Please Note:
Offline
Apr 29, 2009, 11:59 AM
Gold Sponsor
__________________
Gruppe-S
20521 Teresita Way
949-457-1234
Please Note:
Offline
Apr 30, 2009, 11:30 AM
Gold Sponsor
__________________
Gruppe-S
20521 Teresita Way
949-457-1234
Please Note:
Offline
May 1, 2009, 11:18 AM
Gold Sponsor
__________________
Gruppe-S
20521 Teresita Way
949-457-1234
Please Note:
Offline
May 4, 2009, 11:15 AM
Gold Sponsor
__________________
Gruppe-S
20521 Teresita Way
949-457-1234
Please Note:
Offline
May 5, 2009, 12:58 PM
Gold Sponsor
__________________
Gruppe-S
20521 Teresita Way
949-457-1234
Please Note:
Offline
May 6, 2009, 11:24 AM
Gold Sponsor
__________________
Gruppe-S
20521 Teresita Way
949-457-1234
Please Note:
Offline
May 7, 2009, 11:08 AM
Gold Sponsor
__________________
Gruppe-S
20521 Teresita Way
949-457-1234
Please Note:
Offline
May 8, 2009, 12:59 PM
Gold Sponsor
__________________
Gruppe-S
20521 Teresita Way
949-457-1234
Please Note:
Offline
May 11, 2009, 12:24 PM
Gold Sponsor
__________________
Gruppe-S
20521 Teresita Way
949-457-1234
Please Note:
Offline
May 12, 2009, 11:36 AM
Gold Sponsor
__________________
Gruppe-S
20521 Teresita Way
949-457-1234
Please Note:
Offline
May 12, 2009, 12:03 PM
Gold Sponsor
__________________
Gruppe-S
20521 Teresita Way
949-457-1234
Please Note:
Offline
Tags
bell, blend, brake, carbon, endless, evo, evolution, friction, housing, lancer, oem, packages, pads, performance, rated, rotors, vida  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
