Large Sway and Strut Bar Sale (Cusco, Mines, etc.) - F+R CF Strutbars - $299 shipped!
Aerosync Carbon Fiber Strut Tower Bars
The Aerosync Carbon Fiber Strut Braces are the perfect compliment to a set of coilovers or even springs, as they offer an increase in rigidity as well as a significant improvement in vehicle handling. These particular pieces are made of real dry carbon fiber, and feature an adjustable length for personal stiffness adjustment. The Front weighs in at a feather-light 2 lbs. and 7 oz. while the rear is an ounce over 2 lbs. If weight is a concern when considering suspension components, the Aerosync Strut Braces are a certain contender.
$149 Shipped for Front!! - $179 INSTALLED!!
$199 Shipped for Rear!! - $229 INSTALLED!!
$299 Shipped for Both!! - $359 INSTALLED!!
Cusco OS Front
Lightweight aluminum and high rigidity oval sectioned pipe used.
- Hollow core aluminum shafts for lightweight
$185 Shipped!! - $215 INSTALLED!!
Cusco Ti Front
Improves chassis rigidity and reduces flex and weight by 60% lighter compared to most other bars.
- Full 100% titanium construction with TIG welds
$299 Shipped!! - $319 INSTALLED!!
Cusco OS Rear
$149 Shipped!! $175 INSTALLED!!
CUSCO Ti Front and Cusco OS Rear Strut Bar - $439 Shipped!! $489 INSTALLED!!
Cusco OS-T V-Brace
Cusco V-Brace works in conjunction with a Cusco Type-OS or Type-CB strubar to improve chassis rigidity and reduce this flex.
$99 Shipped!! $139 INSTALLED!!
Cusco Rear Sway Bar
Stiffer swaybars properly distributes cornering forces by reducing lateral sway, and will ultimately increase vehicle turning characteristics.
- The rear sway bar will increase oversteer and allow the car to turn tighter
$245 Shipped!! $275 INSTALLED!!
Cusco V1 Lower Arm Bar
The purpose of the Cusco lower arm bar is to reduce alignment flexing and improve body rigidity.
$69 Shipped!! - $119 INSTALLED!!
Cusco V2 Lower Arm Bar
The Version II Bar mounts by multiple bolts and rigidity is greatly increased over Version I.
$149 Shipped!! - $199 INSTALLED!!
CUSCO V1 and V2 LAB$199 Shipped!! $259 INSTALLED!!
Mines 6-Point Lower Arm Bar
This lower arm brace mounts onto multiple points on the front supsension/chassis to greatly increase overall chassis dynamics, and reduces alignment flexing and increases body rigidity.
- High tension lightweight aluminum
- Finished in bright silver color
$299 Shipped!! - $325 INSTALLED!!
Regards,
Mark
Cusco OS Front
Cusco Ti Front
Cusco OS Rear
Cusco OS-T V-Brace
Cusco Rear Sway Bar
Regards,
Mark
Gruppe-S
Evo 'For Sale' Suspension / Brakes / Handling
44
Feb 28, 2007 02:08 PM
Gruppe-S
Dec 12, 2006 11:24 AM
Gruppe-S
17
Nov 30, 2006 06:06 PM
Gruppe-S
Jul 11, 2006 01:16 PM
Gruppe-S
Jul 7, 2006 08:31 PM
