Go Back   evolutionm.net > Market Place > Evo Vendor 'For Sale' Classifieds > Evo 'For Sale' External Engine / Power
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Nov 17, 2008, 06:38 PM   #1
Gold Sponsor
Personal Sales Rating: (175)
Gruppe-S's Avatar
Drives: BCNR33, s13, S4, CT9A, GDB
JDM MR BOV $125-Helix Catback$325-HKS Carbon Ti$649-RSR GT2$425
Super cheap prices on in stock items. Dont miss out limited quantities in stock.
JDM EVO MR BOV
$125 Shipped
RS*R GT-2 Exhaust
$425 Shipped
HKS Carbon TI
Open Box Display Model
PM FOR BEST PRICE!
HKS Hiper
30th Anniversary Full Stainless
PM FOR BEST PRICE!
Greddy TI-C
PM FOR BEST PRICE!
Greddy Comp TI-C
80mm turbo-back, w/80mm downpipe & O2 extension
$PM For Price
Tanabe Concept Blue Turboback System
$1099 Shipped
Tanabe Downpipe
$225 Shipped
DME Turbo Outlet
$145 Shipped
Gruppe-S Lightweight Crank Pulley
.8 LBS!
$49 Shipped
Helix Evo Intake System
$99 Shipped
Gruppe-S 3 - Port Boost Control Solenoid
Free Harness
Not a cheap Chinese piece like some of the other guys.
Similar to the popular Prodrive un it that is no longer available in the USA. The Gruppe-S 3-Port Boost Control Solenoid, made in Germany, is a direct replacement on Subaru, Mitsubishi and other turbo vehicles and it does not place additional load on the ECU electronics.
Unlike the factory solenoid, the Gruppe-S 3-Port Solenoid allows you to raise the factory boost levels with more response and adding more control.
With this solenoid no boost pressure is allowed through to the actuator so no premature boost can occur. The Gruppe-S 3-Port Solenoid allows lower wastgate duty cycle to produce higher boost pressures with much greater control, thereby allowing tuners more "headroom" and "space" when modifying high horsepower turbo vehicles.
The kit includes the Gruppe-S 3-Port Boost Control Solenoid and harness for plug and play install with
$99 Shipped
Helix Lower Intercooler Hose
Replace the Cheap OEM Rubber
Helix Lower Intercooler Hoses are manufactured from extremely durable 5-ply multilayer hose. The materials are sourced directly from the UK, and only premium silicon is employed. These hoses are built to handle extreme heat and cold other hoses cannot. Specially manufactured to insure OEM fitment while also having the ability to hold extreme PSi standard rubber hoses cannot.
Designed for use on stock EVO VIII / IX intercooler
$50 Shipped
EVO 9 Turbo
The EVO IX Turbocharger features a revised 10.5 hotside, and the brand new EVO IX compressor housing. This compressor housing was designed to address issues with compressor surge as well as flow limitations found in the EVO VIII. What this means is that this turbo is far more efficient than the smaller EVO VIII, which translates to more power up top, and is especially advantages to us poor Californians who suffer from 91 octane. EVO VIII owners should expect an additional 20+ HP with the addition of this turbo on pump gas, and 30-40HP increase on race gas.
Evo 9 Turbo Combo
Evo 9 Turbo
Evo 8 to 9 Set-Up Kit
Helix 720cc Injectors
Walbro 255 Fuel Pump
$1425 Shipped
Evo 9 Turbo (Evo 8 to 9 Set-Up Kit Included)
$799 Shipped
JDM EVO 9 20G TURBOCHARGER 450HP
Rated at 450HP, the Mitsubishi EVO 20G is the largest turbocharger to fit the stock manifold of an EVO.It features a 10.5 hot side and utilizes a stock O2 outlet. While the compressor housing on the 20G is the same as that on the EVO iX turbo, the compressor itself is significantly larger, allowing more potential power increases. Compared to the EVO VIII turbo, the 20G is designed to optimize airflow and has less issues with compressor surge than its predecessors.
Evo 9 20G Turbo Combo
Evo 9 Turbo
$1799 Shipped
Evo 9 20G Turbo (Evo 8 to 9 Set-Up Kit Included)
$1049 Shipped
FP Green 20G Turbo 450HP
The EVOGreen Model turbocharger is a direct bolt-in upgrade for 2006 Lancer Evolution cars and can also be used on earlier EVO4-8 models with the EVO8 turbo installation kit (required to avoid contact with the starter). The installation kit is required for 2003-2005 year model EVO8 and includes the compressor outlet pipe, oil lines, water lines, and all required gaskets.
This turbo appears externally to be a 2006 EVO9 turbocharger. It uses the larger diameter EVO9 compressor housing and bearing housing found in the 2006 models. It uses our 700cfm 69-5 billet compressor wheel and our enlarged 11 blade turbine wheel. This combination of increased compressor and turbine flow results in a very broad powerband and stock like boost response while still being capable of well over 400whp.
FP Green 20G Turbo Combo
Evo 9 Turbo
$2145 Shipped
FP Green 20G Turbo (Evo 8 to 9 Set-Up Kit Included)
$1695 Shipped
ATP GT30/ GT35 Stealth Turbo Kits
After months of testing and development with the EVO8 engine combination, ATP has devised an upgrade system that is both elegant and simplistic while accepting no compromises in power potential or reliability. With POWER and RELIABILITY being the two key criteria for the development of the EVO8 turbo upgrade kit, ATP set out to test every possible hardware combination available. In the ATP kit, you will find a system that integrates a plethora of unique but well designed components that compliment each other to achieve those two things that you care about most. In addition, in an attempt to exceed the customers' expections ATP has added other features such as a "direct-bolt-up" housing that overcomes the "reverse-rotation" issue, v-band downpipe discharge, bolt-up oil/coolant kits, etc. in order to make the installation process as simple as possible. All this while retaining the appearance of a completely stock engine bay.
The kit hardware will consist of the following:
-Garrett Prototype GT Ball Bearing turbo w/ATP Proprietary Housing with GT inspired High-Flowing Valute
-Bolt-in design retains stock manifold - Retains stock heatshield for OEM appearance
-Steel braided lines and fittings for oil/coolant connections
-Tial 38mm External Wastegate
-Stainless wastegate discharge tube with downpipe re-route
-Silicone connectors and clamps
-All mounting hardware, gaskets and CNC machined fittings
-450 crank HP utilizing the ultra efficient GT3071R
-3.0" Stainless steel downpipe w/stainless O2 housing
-100% bolt-on design. No welding, cutting, or fabrication
ATP GT3071R (.63 or .82 A/R)
$2199 Shipped
ATP GT3071R (.63 or .82 A/R)/ Helix 720cc Injectors w/ Walbro 255
$2699 Shipped
ATP GT3571R (.63 or .82 A/R)
PM For Price
ATP GT3571R (.63 or .82 A/R)/ Helix 720cc Injectors w/ Walbro 255
PM For Price
__________________
Gruppe-S
20521 Teresita Way
Lake Forest CA 92630
949-457-1234
email: sales@gruppe-s.com
paypal: payments@gruppe-s.com
Please Note:
- All Items Are Shipped Via UPS.
- All Orders Are Repackaged To Help Prevent Any Damage Which May Occur During Transit.
- Any Order Cancellation Will Result In A 25% Processing Fee.
- Local Pick-Ups Available. Please Call For Details.
- No Cancellation on JDM Or Special Orders. No Exceptions!
Online
Old Nov 18, 2008, 11:35 AM   #2
Gold Sponsor
Gruppe-S's Avatar
Bump!
__________________
Gruppe-S
20521 Teresita Way
949-457-1234
Please Note:
Online
Old Nov 18, 2008, 02:16 PM   #3
Gold Sponsor
Gruppe-S's Avatar
Great News!! Air shipment of JDM Mitsubishi and Ralliart items just came in!!!!
JDM Evo MR BOV
$125 Shipped
Ralliart EVO Thermostat
$99 Shipped
Ralliart Radiator Caps
$55 Shipped
Ralliart Engine Mount Sets
$189 Shipped
__________________
Gruppe-S
20521 Teresita Way
949-457-1234
Please Note:
Online
Old Nov 18, 2008, 06:42 PM   #4
Personal Sales Rating: (30)
dbsears's Avatar
Drives: AS IX MR gripbox
Would you guys be willing to sell the TI-C comp in just a catback? Let me know please.
Offline
Old Nov 19, 2008, 11:55 AM   #5
Gold Sponsor
Gruppe-S's Avatar
PM'd!
__________________
Gruppe-S
20521 Teresita Way
949-457-1234
Please Note:
Online
Old Nov 20, 2008, 11:43 AM   #6
Gold Sponsor
Gruppe-S's Avatar
Bump!
__________________
Gruppe-S
20521 Teresita Way
949-457-1234
Please Note:
Online
Old Nov 21, 2008, 03:11 PM   #7
Gold Sponsor
Gruppe-S's Avatar
Bump!
__________________
Gruppe-S
20521 Teresita Way
949-457-1234
Please Note:
Online
Old Nov 24, 2008, 11:29 AM   #8
Gold Sponsor
Gruppe-S's Avatar
Bump!
__________________
Gruppe-S
20521 Teresita Way
949-457-1234
Please Note:
Online
Old Nov 25, 2008, 11:17 AM   #9
Gold Sponsor
Gruppe-S's Avatar
Bump!
__________________
Gruppe-S
20521 Teresita Way
949-457-1234
Please Note:
Online
Old Nov 25, 2008, 10:15 PM   #10
Personal Sales Rating: (11)
letMeIn's Avatar
Drives: WW '05
I will take MR BOV ... Will paypal you $$ Wednesday night ..
__________________
Offline
Old Nov 26, 2008, 11:26 AM   #11
Gold Sponsor
Gruppe-S's Avatar
Sounds good!
__________________
Gruppe-S
20521 Teresita Way
949-457-1234
Please Note:
Online
Old Nov 26, 2008, 10:46 PM   #12
letMeIn's Avatar
Drives: WW '05
check your PM... $$ sent for BOV
__________________
Offline
Old Nov 28, 2008, 07:04 AM   #13
Personal Sales Rating: (1)
MGAUTOS's Avatar
Drives: EVO IX GT
Do you have a 80mm Greddy TI cat back for an Evo IX? (Non rolled lip)
Can you ship to the UK?
Offline
Old Nov 28, 2008, 11:50 AM   #14
Gold Sponsor
Gruppe-S's Avatar
What exhaust are you asking about? I see their TI versuion but it has a rolled tip. Can you post a pic?
Thanks
Gruppe-S
__________________
Gruppe-S
20521 Teresita Way
949-457-1234
Please Note:
Online
Old Nov 28, 2008, 12:16 PM   #15
MGAUTOS's Avatar
Drives: EVO IX GT
Quote:
Thanks
Gruppe-S
Have a look here Part No. 10137900
http://www.greddy.com/products/displ...SubCategory=75
Offline
Tags
back, bov, carbon, cat, evo, greddy, gruppes, helix, international, jdm, kit, mounting, order, rsr, ti, turbo
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
