Sep 2, 2009, 08:56 AM
Gold Sponsor
Personal Sales Rating: ( 5)
ARP | Brian Crower | Exedy | ACT | Kelford | Manley | more
Don't see a brand or item you are looking for? Send me a PM to see if I can get it.
ARP Studs and Bolts
Rod Bolts - 107-6002
Main Studs - 207-5401
Head Studs - 207-4203
Exedy Clutches and Flywheels
Brian Crower Internals and Stroker Kits
Stroker Kit- BC 4340 billet steel, 7 bolt crankshaft (102mm stroke).
- BC 4340 steel Econo or Pro Series billet rods w/ARP 220,000 psi fasteners.
- CP aluminum forged pistons (any bore size, any compression ratio).
- 5100 Series carbon steel alloy wrist pins. 9310 pin upgrade available.
- Ductile iron plasma top rings, tapered second ring, low tension oil rings.
- Fully system balanced and ready to install.
Valve Spring/Retainer Kit
Designed for high rpm, BC valve springs are wound from only the highest grade, super clean, chrome silicone alloy and feature proprietary processing procedures for consistent pressures. BC titanium retainers are CNC machined from 6AL4V round bar titanium to exacting tolerances.
- Spring Pressure:BC1100 Seat: 1.550" @ 95 lbs / Open: 1.000" @ 235 lbs / Coil Bind: 0.935" (no machine work required)
Camshafts- Stage 2 Street/Strip - Plug and play application. Short duration for nice street manners, slight lope at idle. Excellent all purpose spec. OEM spring OK.
Adv. Dur - 272°/272°
Dur @ .050 - 206°/206°
Lift (mm) - 10.54/9.86
- Stage 3 Race - Longer duration profile, added rpm potential. Intended for fully built engine. Tuning and ECU mods recommended. Requires kit BC0100.
Adv. Dur - 280°/280°
Dur @ .050 - 218°/216°
Lift (mm) - 10.80/10.36
- Stage 4 Full Race - Giant lift profile intended for those looking to achieve huge power numbers at high rpm. Requires extensive tuning and modifications. Requires BC0100.
Adv. Dur - 288°/288°
Dur @ .050 - 222°/220°
Lift (mm) - 11.88/12.14
ACT Clutches and Flywheels
Kelford Camshafts
- 8-TX264 - The ULTIMATE EVO 8 Cam for engines from 350-500HP. Great for street cars and track cars where low end throttle response and midrange torque are essential.
- 8-TX272 - The Best 272 degree cam on the market. These cams are ideal for street or strip applications making 400HP or more.
- 8-TX280 - High HP Racing cams. Suitable for well built engines with GT37/82 turbocharger or similar.
- 8-TX288 - Camshafts suit high HP, high boost, professionally built drag racing engines.
Manley H and I beam Rods
PM for best pricing. Orders shipped same day!
Want something you don't see? Send a PM to check pricing and availability!
__________________
Chris
www.injectedperformance.com
(888) 465-7373 ext. 223 Toll Free
(859) 224-0461 ext.223
Paypal ID sales@injectedperformance.com Paypal must be confirmed address!
AOL, Yahoo IM - CKinjected
Wholesale Distributor:
Advan, AEM, ARC, Brian Crower, Bride, Brembo, Cosworth, Cusco, Ferrea, Gram Lights, Innovate, Innovative Turbo, JIC, Koyo, Power Enterprise, Precision Turbo, Project Mu, RPS, Seibon, StopTech, Sun-Auto, Tein, Tial, Unorthodox, Volk, Walbro
Offline
Sep 3, 2009, 10:53 AM
Gold Sponsor
bump
__________________
Chris
Offline
Sep 4, 2009, 08:35 AM
Gold Sponsor
bump to top, everything in stock
__________________
Chris
Offline
Sep 4, 2009, 02:53 PM
Gold Sponsor
have a safe labor day weekend
__________________
Chris
Offline
Sep 9, 2009, 02:38 PM
Gold Sponsor
to the top
__________________
Chris
Offline
Sep 11, 2009, 07:01 AM
Personal Sales Rating: ( 1)
Drives: Mitsubishi Lancer Evolution IX
Hello, Injectedperformance,
I'm currently searching some engine internals for EDM 2006 EvoIX. The parts needed list is below:
1) Mahle pistons, part number 367385I10
2) Scat conrods, part number 659061186
3) Cosworth main and rods bearings, part numbers PR7893 and PR7894
4) ARP head studs, part number 207-4702
Please PM me with lowest prices by each position shipped to 07106.
Offline
Sep 11, 2009, 02:19 PM
Gold Sponsor
you got PM
__________________
Chris
Offline
Sep 11, 2009, 04:50 PM
Personal Sales Rating: ( 4)
hey Chris can you pm your best price on an Exedy stage 2 and flywheel combo shipped to 07047?? lmk thanks
Offline
Sep 14, 2009, 08:34 AM
Gold Sponsor
Quote:
you got PM
__________________
Chris
Offline
Sep 15, 2009, 02:37 PM
Gold Sponsor
bump up top
__________________
Chris
Offline
Sep 16, 2009, 04:13 PM
Gold Sponsor
to the top
__________________
Chris
Offline
Sep 17, 2009, 01:16 PM
Gold Sponsor
bump
__________________
Chris
Offline
Sep 18, 2009, 08:47 AM
Gold Sponsor
CP Pistons available, stock bore and stroked!
Brian Crower stroker kits available.
__________________
Chris
Offline
Sep 21, 2009, 10:21 AM
Gold Sponsor
to the top
__________________
Chris
Offline
Sep 22, 2009, 03:52 PM
Gold Sponsor
bump up top
__________________
Chris
Offline
Tags
050, 659061186, bc1100, brian, crower, distributor, evo, ferrea, gian, horsepower, low, mahle, mitsubishi, oil, pistons, rings, spec, spring, tension, wholesale  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
