Oct 22, 2008, 10:52 AM
Silver Sponsor
Personal Sales Rating: ( 13)
Drives: EVO 9 , EVO X
!!! KELFORD /// HKS /// COSWORTH /// And many more!!!
At Big Valley Performance we offer the top products from many brands! Here is just but the tip of the iceberg from what we offer! PM for pricing and details!
Kelford camshafts, #1 in AMS shootout! ON SALE!!!
performance upgrades!
Camshafts
Metal Head Gaskets
Mitsubishi 4G63 (EVOVII-VII) Camshaft Set M1
Mitsubishi 4G63 (EVOVII-VII) Camshaft Set M2
Mitsubishi 4G63 (EVO IX) Camshaft Set
Mitsubishi 4G63 (EVOVII-VIII) Forged Piston Set
...And much much more!
Product lines carried include Ferrea, ARP, WISECO, CP, INJEN, TurboXS and many others!!! PM for pricing and details!
ACT CLUTCHES
The model shown has a torque capacity of 651 FT/.LBS, a clamp load increase of 41%! Increased torque capacity and spline life, very good durability, quiet operation, and reduced driveline shock. Used by many daily driven and tracked Mitsubshi Evolutions, this is a great priced clutch for enthusiast on a budget! PM for pricing!
ACT FLYWHEELS
" Most stock flywheels are heavy cast iron and are designed for optimum drivability by storing some of the engine’s power in the form of inertia. Light flywheels provide significantly improved engine response and acceleration by compromising drivability. Xact flywheels are designed for improving engine response, strength and affordability." PM for pricing!
Streetlite / 13.1 lbs.
- Preferred for Street and Drag Racing
- Improved throttle response and acceleration
- Considerably lighter than stock
- Most durable flywheel available
- Good drivability
Prolite / 10.1 lbs.
- Preferred for Road Racing or minimum inertia
- Quick throttle response and acceleration
- Lightest with lowest inertia
- Reduced drivability
EXEDY Multiplate Clutch Kit
" For high-powered applications EXEDY offers Multi plate clutches. These are designed for hot street action as well as drag, road, and rally racing. All of our multi plate clutches come with a lightweight chromoly steel flywheel, and the famous purple anodized forged aluminum clutch cover. Depending on the application, both strap drive and lug drive models are available. All have T5001 cerametallic friction materials for extreme heat resistance. The multi plate clutches are rated up to 800+ foot pounds of torque at the flywheel. And come with spring damper or solid discs depending on the application." PM for pricing!
Specs
Number of Discs ~ Twin
Spring Damper Discs ~ Sprung Hub
Push / Pull ~ Pull Type
Disc Outer Diameter ~ 200mm (7-7/8in)
Spline Teeth / Major Diameter ~ 23T / 26.2mm
Exedy Carbon Clutch Kit
" The flagship model of EXEDY Racing Clutches: the carbon steel multi plate clutches. These clutches are light in weight, durable, and resilient to high heat, contributing to an improvement in track times. These complete bolt on designs require no additional modifications to the vehicle. The carbon materials are baked at more than 2000 degrees celsius which allows the the carbon material to dissipate heat far better than conventional metallic material." PM for pricing!
Specs
Number of Discs ~ Triple
Spring Damper Discs ~ Solid Hub
TILTON EVO OE Diameter clutches
"Tilton Performance offers three clutch packages for the Mitsubishi EVO VII (non-MR). The three clutch types have been developed to meet the requirements for high-performance street/strip and racing applications. Clutch options include a Cerametallic/Organic Hybrid, Cerametallic and Carbon clutch.
The flywheel included in the packages has been engineered to have a compromised weight/inertia that provided increased performance (faster engine acceleration) and good drivability (reduced bogging).
Also included with each clutch package is a hydraulic release bearing (HRB) that mounts inside the bellhousing and replaces the stock slave cylinder/fork arm release bearing mechanism. The HRB provides quick shifting, low pedal effort and self-adjusts for clutch wear." PM for pricing!
# 7.25" 2-pl Carbon CFAs
# 7.25" 2-pl Cera/Organic CFAs
# 7.25" 2-pl Cerametallic CFAs
Ok guys we are runing a SALE on WISECO PISTONS+EAGLE RODS ALL IN STOCK
PM FOR THE COMBO PRICE!!
Other makes and model available as well...PM for details!
__________________
Fastest USDM STI 9.20@153
BLACK FRIDAY SALE! CLICK HERE
GADIEL Tuning
Jestr tuning
World fastest stock app EVO X 10.79@124 Tuned By Gadiel
Winner EVO X class 16th Buschur DSM/EVO shootout 2008
365 W. Taft Vineland suit 102
Orlando, FL 32824
407-287-5940 & 321-578-0888
AIM tonyatBVP (online 24/7) & BigValleypr
www.bigvalleyperformance.com
Dynojet Center,Parts,Fabrication
Offline
Oct 23, 2008, 07:49 AM
Personal Sales Rating: ( 11)
Drives: WW '05
pm price for Evo 8 Kelford TX272s shipped to 11223
__________________
Offline
Oct 23, 2008, 08:12 AM
Silver Sponsor
^replied
__________________
GADIEL Tuning
Jestr tuning
Orlando, FL 32824
Offline
Oct 24, 2008, 09:23 AM
Silver Sponsor
All PM's replied! ttt
__________________
GADIEL Tuning
Jestr tuning
Orlando, FL 32824
Offline
Oct 24, 2008, 10:10 AM
Personal Sales Rating: ( 1)
Drives: 05 EVO VIII, 06 CIVIC SI (turbo-380whp260tq), 04 RSX-S
pm price for Evo 8 Kelford TX272s shipped to 07071
Offline
Oct 24, 2008, 01:57 PM
Personal Sales Rating: ( 0)
Drives: 2004 evo 8
bump runnin fully built cosworth head...cams are soo meann
Offline
Oct 25, 2008, 09:22 AM
Drives: Evo
ttt!
Offline
Oct 27, 2008, 10:41 AM
Drives: Evo
Monday bump!
Offline
Oct 28, 2008, 11:51 AM
Silver Sponsor
ttt
__________________
GADIEL Tuning
Jestr tuning
Orlando, FL 32824
Offline
Oct 29, 2008, 11:07 AM
Drives: Evo
bump
Offline
Oct 31, 2008, 02:31 PM
Drives: Evo
Trick or Treat! Bump!
Offline
Nov 3, 2008, 02:57 PM
Drives: Evo
ttt!
Offline
Nov 5, 2008, 10:50 AM
Drives: Evo
Bump!
Offline
Nov 7, 2008, 08:06 AM
Silver Sponsor
Friday bump!
__________________
GADIEL Tuning
Jestr tuning
Orlando, FL 32824
Offline
Nov 10, 2008, 09:34 AM
Drives: Evo
Bump! =)
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
