Go Back   evolutionm.net > Market Place > Evo Vendor 'For Sale' Classifieds > Evo 'For Sale' Electronics / Lighting / Audio
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Mar 20, 2009, 11:27 AM   #1
Gold Sponsor
Personal Sales Rating: (97)
201Motorsports's Avatar
Drives: 2003 Black Evo VIII
Gauges @ 201 Motorsports - AEM / STRI / Defi
AEM UEGO @ 201 Motorsports
AEM Analog Wideband O2 52mm Gauge
Quote:
AEM's Wideband Analog 52mm o2 gauge includes a single-channel analog output with a Bosch O2 sensor in one unit! AEM's Wideband Analog 52mm o2 gauge controller features an analog sweeping needle and seven user adjustable backlight colors. Each gauge includes one silver and one black bezel. They are also available in a white or black face. The unit's 52mm (2-1/16") gauge housing fits in most gauge pods and can be remotely mounted virtually anywhere. No laptop required for monitoring! When you buy AEM you know you are buying the best!
Bosch sensor included with the gauge, 7 user adjustable backlight colors, programmable 0-5v analog output included for use with data loggers and ANY engine management system, Ideal AFR monitoring tool for carbureted applications and engine dynamometers, does not oscillate AFR like narrow band sensors, serial data stream included for output of AFR (RS 232), accurate to 0.1 AFR, two status lights for error detection & operating status, comes with black and silver bezel.
(Pictured is the BLACK FACE gauge)
Price: $207.21 shipped
AEM UEGO Wideband O2 52mm Gauge
Quote:
This is a six-in-one gauge-type UEGO controller.
AEM’s Gauge-Type Wideband UEGO Controller features an LED readout and sweeping LED “needle” that changes colors as AFR changes from rich to lean. The unit’s 52mm (2-1/16”) gauge housing fits in most gauge pods and can be remotely mounted virtually anywhere.
Key features of the AEM Gauge-Type UEGO Controller:
* 24 Color-coded LED display lights provide immediate reference to engine’s air/fuel ratio (AFR) or Lambda (11.0:1 to 17.0:1)
* Integrated three-digit display reveals AFR or Lambda in real time (10.0:1 to 18.5:1)
* User-selectable 0-5v analog output included for use with data loggers and most programmable engine management systems
* Switch between AFR or Lambda readout with a twist of a switch (included face plate change is required for proper readout)
* Included black and silver bezels, black and white AFR gauge faces and black Lambda gauge face allow you to personalize the look of your gauge!
* Quick-Connect system eases installation by allowing users to mount the gauge and sensor wiring separately
* Ideal AFR monitoring tool for carbureted applications and engine dynamometers
* Does not oscillate AFR like narrow band sensors
* Serial data stream included for output of AFR (RS 232)
* Accurate to 0.1 AFR
* Bosch UEGO sensor included
AEM Tru-Boost Boost Controller / Gauge
Quote:
The AEM Tru-Boost Boost Gauge/Controller combination is a mult-featured system for simplified, comprehensive boost control. Packaged within a 52mm gauge are a 29psi capable boost controller, peak-memory boost gauge. Other features include overboost alarm and overboost shutdown, wastegate delay for faster spool up, and a driver for an external warning lamp.
NOTE: This unit includes black and silver bezels and black and white faceplates for simple color selection and easy matching to other AEM gauges (i.e. serial gauge, UEGO, etc.)
Features:
* 52mm (2 1/16") Complete stand-alone boost controller gauge
* On-board pressure sensor included for boost levels up to 29 PSI
* Two user selectable units
* Peak boost memory
* User selectable over boost alarm with overboost shutdown
* User scaleable bar graph display
* User selectable waste gate delay for quick turbo spool
* External warning lamp driver
* No external interface required for programming
* Easy to install harness allows for quick and easy installation
* Boost hose and fittings included for easy hookup to on-board pressure sensor
* Multi-Bezel system: includes silver and black bezels, white and black face plates
Price: $302 shipped
__________________
Phil
201 Motorsports
http://201motorsports.com
Email
phil[at]201motorsports.com
Payment Methods Accepted
American Express, Discover, Visa, MasterCard, and PayPal
PayPal
paypal[at]201motorsports.com
Offline
Old Mar 20, 2009, 11:27 AM   #2
Gold Sponsor
STRI X-Line Series (Regular & Smoked Face)
Quote:
* Factory Preset Warning
* 270 Degree Sweep
* Start up open mode
* Dimmer function
* High brightness LED
* Light weight aluminum casing.
* All sensors included
* Mounting solution included
* 52mm and 60mm available
STRI X-Line Series
Regular Face (Black or White Face / Amber LED)
Boost: $67 shipped
EGT: $125 shipped
Fuel Pressure: $90 shipped
Oil Pressure: $90 shipped
Oil Temperature: $78 shipped
Water Temperature: $78 shipped
Tachometer: $67 shipped
Voltmeter: $67 shipped
Smoked Face
Amber LED
Boost: $74 shipped
EGT: $132 shipped
Fuel Pressure: $97 shipped
Oil Pressure: $97 shipped
Oil Temperature: $85 shipped
Water Temperature: $85 shipped
Tachometer: $74 shipped
Voltmeter: $74 shipped
White LED
Boost: $74 shipped
EGT: $132 shipped
__________________
Phil
201 Motorsports
Email
PayPal
Offline
Old Mar 20, 2009, 11:29 AM   #3
Gold Sponsor
STRI DSD-CS Series (Clear Lenses / Amber LED)
Quote:
STRI’s new DSD warning gauges offer all of the functions a demanding driver requires. Driven by rugged stepper motor, the DSD gauges inform you of your car’s vitals with extreme accuracy. Controlled by an advanced microprocessor, the DSD gauges are the latest in technology. Using the highest quality components DSD gauges will keep tabs on your car with surgical precision. . The DSD warning gauges are available in two sizes, 52mm and 60mm.
DSD Line Features:
* User Preset Warning
* Peak Recall
* Auto Self Calibration
* 270 Degree Sweep
* Short circuit auto detect
* Sequential open / closing mode
* Dimmer function
STRI DSD-CS Series
Clear Lense (Black Face / Amber LED)
Boost (30 PSi): $160 shipped
Boost (45 PSi): $182 shipped
EGT: $165 shipped
Fuel Pressure: $194 shipped
Oil Pressure: $194
Oil Temperature: $125 shipped
Water Temperature: $125 shipped
Tachometer: $114 shipped
Voltmeter: $114 shipped
Clear Lense (White Face / Amber LED)
EGT: $165 shipped
Oil Pressure: $194 shipped
__________________
Phil
201 Motorsports
Email
PayPal
Offline
Old Mar 20, 2009, 11:30 AM   #4
Gold Sponsor
STRI DSD-SLM II Series (Smoked Lenses / Amber or White LED)
DSD Line Features:
* Peak Recall
* 270 Degree Sweep
* Dimmer function
Smoked Lense (Amber LED)
Boost (30 PSi): $169 shipped
Boost (45 PSi): $191 shipped
EGT: $172 shipped
Fuel Pressure: $203 shipped
Oil Pressure: $203 shipped
Oil Temperature: $135 shipped
Water Temperature: $134 shipped
Tachometer: $172 shipped
Voltmeter: $123 shipped
Smoked Lense (White LED)
EGT: $172 shipped
__________________
Phil
201 Motorsports
Email
PayPal
Offline
Old Mar 20, 2009, 11:30 AM   #5
Gold Sponsor
Defi Red Racer, White Racer, and Blue Racer Gauges @ 201 Motorsports
No Control Unit Needed!!!
Quote:
Exclusive gauges for the USA which are derived from quick-responsive and high-accurate Defi analog gauges.
* Stepping motor "STEP MASTER VS-2" provides smooth operation
* Ignition ON initiates self-luminescence gauge
* Red illumination using high-brightness LEDs
* Full 270 degrees sweep dial provides ultimate visibility
* A mounting bracket and instrument case is provided with the product
* The red triangle of the regular position bezel can be used as a warning indicator
* Does not require the Defi-Link Control Unit for use (Blue Racer Gauge cannot be connected to the Defi-Link System)
Self-diagnostics function monitors both sensor disconnection and short-circuiting during startup.
Sensor disconnection check:
This function reports any in-proper connections, broken or disconnected sensor or sensor wire. The pointer will wave between 250 and 260 degrees.
Short-circuiting check:
This function indicates any short circuit on the sensor or sensor wire.
__________________
Phil
201 Motorsports
Email
PayPal
Offline
Old Mar 20, 2009, 11:31 AM   #6
Gold Sponsor
Defi BF Imperial Amber and White Gauges @ 201 Motorsports
Imperial
Quote:
Defi-Link Meter BFs are electronic blacked out gauges which are high response and refined design. When the car is off they have a black face with no numbers on them. As soon as the car is turned on, the gauges light up and are in full affect.
Defi-Link Meter BFs need to be connected to Defi-Link Control Unit II. Up to 6 gauges can be connected and controlled by one Control Unit II. The name of the connection system is "Defi-Link System." Defi-Link System allows gauges to be attached to Defi-Link Control Unit II with a single "DAISY CHAIN" wiring system.
Control Unit II: $111 shipped
Defi BF Imperial Amber 60mm Gauges
Boost: $249 shipped
EGT: $291 shipped
Fuel Pressure: $291 shipped
Oil Pressure: $291 shipped
Oil Temperature: $218 shipped
Water Temperature: $218 shipped
Defi BF Imperial White 60mm Gauges
Boost: $249 shipped
EGT: $291 shipped
__________________
Phil
201 Motorsports
Email
PayPal
Offline
Old Mar 20, 2009, 11:31 AM   #7
Gold Sponsor
Defi BF Amber and White Gauges @ 201 Motorsports
Metric
Defi BF Amber 60mm Gauges
Boost: $249 shipped
EGT: $291 shipped
Defi BF White 60mm Gauges
Boost: $249 shipped
EGT: $291 shipped
__________________
Phil
201 Motorsports
Email
PayPal
Offline
Old Mar 24, 2009, 12:55 PM   #8
Gold Sponsor
So many gauges, so little time
__________________
Phil
201 Motorsports
Email
PayPal
Offline
Old Mar 25, 2009, 07:15 PM   #9
Gold Sponsor
Bump it up to the top!
__________________
Phil
201 Motorsports
Email
PayPal
Offline
Old Mar 27, 2009, 09:14 AM   #10
Gold Sponsor
So many gauges!
__________________
Phil
201 Motorsports
Email
PayPal
Offline
Old Mar 31, 2009, 08:05 AM   #11
Gold Sponsor
Gauges! BUMP!
__________________
Phil
201 Motorsports
Email
PayPal
Offline
Old Apr 17, 2009, 06:25 PM   #12
Gold Sponsor
To the top!
__________________
Phil
201 Motorsports
Email
PayPal
Offline
Old Jun 1, 2009, 04:04 PM   #13
Personal Sales Rating: (45)
peter*g's Avatar
Drives: Way too aggressively for public roads...
Send a message via AIM to peter*g Send a message via MSN to peter*g Send a message via Yahoo to peter*g
Do you guys have a replacement oil pressure sensor for the Defi BF / Head-Up display set-up? Mine is starting to fail and I'm looking for a replacement. Thanks.
__________________
peter*g
Evolved Performance
Offline
Old Jun 2, 2009, 08:46 AM   #14
Gold Sponsor
Quote:
We sure do. I have 1 Defi Oil/Fuel Pressure Sensor (sensor and sensor wire which connects to the intermediary wire included) available. The price is $160 shipped in the continental US. If you need the full sensor set (sensor, sensor wire which connects to the intermediary wire, control unit wire included), I'd need to order that. It would take about 5 business days for it to get to me and then shipping time to you. Dropshipping is unfortunately unavailable for that item
I'll PM you this info as well Thank you, Peter!
__________________
Phil
201 Motorsports
Email
PayPal
Offline
Old Jun 2, 2009, 09:28 AM   #15
peter*g's Avatar
Thanks, Phil. I'll take it. Can you send me a PayPal invoice? You probably still have my e-mail address.
__________________
peter*g
Evolved Performance
Offline
Tags
aem, calibration, defi, dsd, evo, gauge, gauges, red, sale, stri, temperatur, vs, water, white, wiring
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
