Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo How Tos / Installations
New! Use your Facebook to securely log into this site, click logo to login
Sponsored by: Eibach Springs
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Closed Thread
Old Mar 1, 2004, 09:38 PM   #1
Personal Sales Rating: (3)
kdogg's Avatar
Drives: was EVO,now Montero
Send a message via MSN to kdogg
Talking How remove bumper and install HID bulbs!
Well, I finally took the time to install upgraded D2S HID bulbs. It involves removing the bumper and headlight assembly. So I thought I'd walk everyone through it. Let me know if I forget anything.
Things you'll need:
10mm Socket wrench
flat head screwdriver
philips screwdriver
philip head drive bit
garage ramps
spotlight
Time 2-3 hours.
*NOTE: Since you're removing cosmetic materials (bumper & headlight), be cautious not to scratch either while doing this.
Offline
Old Mar 1, 2004, 09:40 PM   #2
kdogg's Avatar
Remove 2 bolts and 3 clips on top of the front bumper
Offline
Old Mar 1, 2004, 09:40 PM   #3
kdogg's Avatar
Remove the non-marked clips by prying with flat head screw driver. Pop up 1/4" and you will be able to pull the entire clip out.
Offline
Old Mar 1, 2004, 09:41 PM   #4
Personal Sales Rating: (43)
mifesto's Avatar
Drives: 03 evo
Send a message via AIM to mifesto
what else you need to remove the bumper?
Offline
Old Mar 1, 2004, 09:41 PM   #5
Personal Sales Rating: (5)
LightingEvo23's Avatar
Drives: 03' Lightning evo
Send a message via AIM to LightingEvo23 Send a message via MSN to LightingEvo23
nice write up... i was planning on doing the same thing. good job bro.
Offline
Old Mar 1, 2004, 09:42 PM   #6
kdogg's Avatar
Under each wheel well, remove 1 bolt and 2 philip head clips.
Offline
Old Mar 1, 2004, 09:43 PM   #7
kdogg's Avatar
I used a philip head drill bit to unscrew the clip. You may have to apply no pressure in order for the threads to catch.
Offline
Old Mar 1, 2004, 09:44 PM   #8
kdogg's Avatar
Next remove ~10 philips head clips right behind the black plastic lip. You shouldn't have to remove any other clips holding the under carriage.
Offline
Old Mar 1, 2004, 09:45 PM   #9
kdogg's Avatar
Now unscrew the two bolts holding the intercooler screen.
Offline
Old Mar 1, 2004, 09:46 PM   #10
Personal Sales Rating: (1)
value's Avatar
Drives: Speedo baka !!
What bulbs did you upgrade to ??
Offline
Old Mar 1, 2004, 09:46 PM   #11
kdogg's Avatar
Now slightly pull the bumper down on near the wheel to 'unhook' a tab, but don't yank off the bumper just yet.
Offline
Old Mar 1, 2004, 09:47 PM   #12
kdogg's Avatar
You'll have to disconnect the intercooler spray tubing. Near the driver side headlamp on the bumper, you can disconnect the tubing from a white coupling.
Offline
Old Mar 1, 2004, 09:49 PM   #13
kdogg's Avatar
With the bumper slight pulled forward, get underneath the vehicle to reach and pop off a clip holder for the tubing. You will need a long skinny fork like tool to rock the clip loose.
Offline
Old Mar 1, 2004, 09:50 PM   #14
kdogg's Avatar
Now you should be able to carefully pull the front bumper off.
Offline
Old Mar 1, 2004, 09:52 PM   #15
kdogg's Avatar
Starting with the driver side headlamp....
Remove the clip on the inside of the headlamp. This will allow you access to one bolt. Unscrew the two top bolts. Remove the forward most bolt near the wheel. (4 bolts total)
Offline
Closed Thread
Tags
06, 2002, bulb, bulbs, bumper, clip, detach, evo, evos, hid, install, installation, montero, removal, remove
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
