Evo 9 Wing install
Evo 9 Wing install
Hi there,
I recently bought an Evo 9 and i was wondering what the measurements were for installing the stock wing. The previous owner had removed the wing and had the holes professionally filled, inside and out, leaving no trace of where the stock holes would be. If anyone has any info on how i should go about installing the wing it would be greatly appreciated!
Thanks
Thanks
maxspeed96ct (Aug 24, 2016)
Believe it or not im the only person in my town with an evo 9, and im not really looking to spend money on shipping when i already own the wing. ill search for a template online and if not then i suppose ill have to go into my local dealership
Look on the back side of the trunk. You can find the spaces for the holes there. If its all smooth and shaved on the back too then post up a picture. I can mark the location where the holes should go.
However, its worth it to try to look for an 02-03 lancer trunk with holes they might line up.
Your local dealership is just going to drill the holes. They will set the wing down on the trunk and mark where the studs sits and drill that. 3 holes are needed per side. One of those holes does not go through to the back.
phishy
Evo X How Tos / Installations
30
Feb 21, 2016 01:33 AM
drifthobo
Feb 6, 2013 09:32 PM
AdamWest
Feb 8, 2012 08:49 PM
BluesunsXIV
Jul 20, 2008 11:02 AM
Blackie9900
Sep 3, 2005 11:27 AM
