Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo How Tos / Installations
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 24, 2009, 08:33 PM   #1
Personal Sales Rating: (18)
SixOneNine's Avatar
Drives: DSM (sold), 03 Evo
Stripped thread...how to take out?
I tried taking out the iac motor but one of the screw has been stripped so it can't be removed from the throttle body. I tried using different sized phillip screwdrivers and flat heads but none worked. So how the heck do I take out this damn screw? Any tips?
Thanks in advance..
Offline
Old Oct 24, 2009, 08:59 PM   #2
Personal Sales Rating: (36)
Evoryder's Avatar
Drives: EVO METH MACHINE
Get a small hand saw and saw In a groove for flat head. Use one of the existing lines for guidance. Should take about 5-10 mins
__________________
TEMEVO
"I'm addicted to 100% Methanol : ) "
MACHINES GONE WILD
FOR SALE: FORGE WASTGATE/PERRIN INTAKE CLICK ME
Offline
Old Oct 25, 2009, 12:59 PM   #3
SixOneNine's Avatar
Thanks. I'll try it out after football. Any other tips?
Offline
Old Oct 25, 2009, 01:20 PM   #4
Personal Sales Rating: (11)
heel2toe's Avatar
Drives: 05 Evo SSL
Quote:
^This
You should have ample room to get in there with a saw and cut a groove. If you cant seem to figure that one out then you could also try a pair of needle nose vice grips.
__________________
Turco Tuned
Offline
Old Oct 26, 2009, 06:00 AM   #5
Evoryder's Avatar
Or a dremel, not sure how steady your hand is. Dremel would take less than a minute, however, you could do more damage than good.
__________________
TEMEVO
MACHINES GONE WILD
Offline
Old Oct 26, 2009, 06:11 AM   #6
Personal Sales Rating: (13)
rcheung's Avatar
Drives: 2003 Evo 8
You could also try an impact screwdriver. Its a screwdriver you hammer down and it unscrews as you hit down. Nice thing to have it that ever happens.
__________________
2003 GSR EVO
HFC, Greddy SP2 Exhaust, HKS intake, Megan Exaust manifold , Megan O2 turbo outlet, reflash, AVC-R@21 PSI, walbro 255, HKS 264 I/E, Shep stage 2 Transfer Case with Ralliart LSD. Blox polyurethane front engine mount.
Offline
Old Oct 26, 2009, 06:16 AM   #7
Personal Sales Rating: (0)
hotrod2448's Avatar
Drives: E92 335, E65 750
If the slot method doesn't work you could get a screw extractor set or find a drill bit the proper size to drill the head off them remove the threaded portion with a pair of vise-grips.
Definitely try cutting a slot first though.
__________________
Born to lose and destined to fail
Offline
Old Oct 26, 2009, 06:18 AM   #8
Silver Sponsor +1
Personal Sales Rating: (445)
TTP Engineering's Avatar
Drives: 2008 Evolution GSR SSS, 2005 Evolution MR, 2003 Evo GSR, 1995 TsiAWD, 1995 GST, 1995 Tsi 2wd, 1991 GVR4 WW, 1991 GVR4 NBM, 1993 TsiAWD, 1991 Tsi, 1995 RS N20
Send a message via AIM to TTP Engineering
Quote:
This.
__________________
2005 Evolution VIII MR
763whp/595tq HTA86
10.19 & 143.3mph stock ECU
Factory ECU Expert
2008 Evolution X GSR
12.0@113mph Full Wt+
In House Mustang Dyno AWD-500!
www.ttp-engineering.com
(407) 475-0010
AIM=TTPEngineering
MODIFYING THE 4G63 SINCE 1995, YES 14 YEARS!
TUNING EVO V - EVO X & 2009 RALLIART!
TTP's Myspace page!
Offline
Old Oct 26, 2009, 06:26 AM   #9
Personal Sales Rating: (3)
2005 Mitsubishi Lancer Evolution
Bobster22388's Avatar
Drives: '05 AS Evo VIII SSL, '92 Eclipse GSX (Is No More)
Send a message via AIM to Bobster22388
I would definitely give the impact screw driver a try, I've used that plenty of times and taken out things I never thought would come out. Another idea if you can hold the piece still you can take a metal chisel and a hammer and hit it on one side to make a groove around the edge and then work the screw around. Penetrating oil is your friend in this case too, spray some on and let it sit for a while.
__________________
XboxLIVE: Evogamer05
Cams, Apexi 3" turboback exhaust with cat, turbosmart BOV, Vibrant filter, Greddy Profec EBC, Tein EDFC, 30R, GT-Spec manifold, Drag DR-31 Wheels (Black w/red lip), Falken Ziex tires
LaScuola Motorsports
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
