Sep 29, 2009, 07:47 PM
Personal Sales Rating: ( 0)
Synapse BOV Won't Fit. Help Needed!!
Ill try and keep it short.
My Niesi UICP for whatever reason I was dumb and ordered a stock BOV location (on the bottom of the upper part of the piping)
so its pretty darn clear the BOV will not fit connecting directly to the IC pipe, which I knew would be the case. I have a Perrin intake with a stock IX DV on right now and it barley fits on its own where it is (directly into Intake)
Basically I am thinking my only option is to buy a 90degree elbow for the intake and relocate the BOV to somewhere on-top-ish of the intake piping, or get a new UICP pipe. But if I am to relocate, my question is, where should I put it, and how can I keep it stable? if it isnt connected directly to the intake or UICP it would be fairly loose.
I know this is somewhat hard to understand especially since most people dont have both a Niesi pipe and an perrin intake and every setup is different so I will post pics as soon as I have time.
__________________
ETS Black 3.5" FMIC, Nisei IC Piping, Walbro Pump, Perrin Intake, Buschur TBE, Swift Springs -- UNTUNED
Offline
Sep 29, 2009, 08:36 PM
Actually I don't think Niesi has any other port option for their UICP from what I can tell. So if anyone knows where the Perrin Intake BOV Port is, and the Niesi UICP port is, and knows how big an Synapse BOV is, they will be able to understand that the BOV cannot fit in either place. My question is, do I have to ditch one of the two (I'd ditch the UICP) or can I figure out some sort of solution.
__________________
Offline
Sep 30, 2009, 01:03 AM
Personal Sales Rating: ( 27)
2005 Mitsubishi Lancer Evolution
Drives: '05 Tarmac Black SSL VIII
Quote:
The solution is to chop the BOV port on the nesei and have the hole patched, and weld on a new BOV port where you want it...
__________________
FP Red*Greddy ProfecB Spec II*HKS TT*Nesei Short Route IC Piping*Synapse BOV*COMP 272s*Injen Intercooler*AFE Power Dry Filter*R/TErnie Intake*R/TErnie FULL 3" O2 housing with V-band*R/TErnie Modified DCsports 3" Down/Test/Flexpipe with V-Band*Greddy Ti-C Exhaust*255lph*Tein S-Techs*18" Volk LE-28s*Progress 25mm Rear Sway*Project Mu pads*JDM Tails*Cusco Heat Shield*Mishimoto Radiator hoses/Cap*ARC shift knob*Injector Dynamics 1000cc...
Offline
Sep 30, 2009, 01:30 AM
Personal Sales Rating: ( 2)
Drives: 2006 Evolution IX MR, 1998 Honda Prelude
^+1 Now you've got to improvise to make the BOV work. Freddies solution is probably going to be your best bet. Chop off the nub for the OEM BOV and have it patched up, then find out where your BOV will fit most easily with your pipe setup, then weld on a flange and hook her up...
__________________
06 Apex Silver MR
80MM FP Green - Ported 73HTA
HKS 272 Cams
Precision 1200cc Injectors
Walbro 255 lph
Hallman Pro RX MBC @30 psi
ARP Headstuds / Conrod bolts
Injen UICP/LICP
Injen Ram Intake - K&N Cone
APS TV BOV
Greddy Spec-V FMIC
Greddy Turbo Headers
ARC Titanium Catback Exhaust
Megan Radiator
Megan O2 Housing - Ported
DC Sports downpipe/catdelete
Okada Projects Plasma Coils
Excedy Twin HD/ Fly
ROBISPEC/// KW3 Custom Clubsports
E-85 Ethanol
Offline
Oct 4, 2009, 06:25 PM
Drives: 01' BMW K1200RS Blue/Silver, 04' STi sold
Quote:
that would be clean and the most leak free
Offline
Oct 4, 2009, 06:28 PM
Personal Sales Rating: ( 1)
Drives: 03 evo8
or u could sell it on here and buy the one u need!!!
Offline
Tags
05, bov, buy, evolution, hard, lancer, mitsubishi, needed, niesi, pipe, synapse, work, works  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
