Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo How Tos / Installations
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Sep 14, 2009, 07:01 AM   #1
Personal Sales Rating: (4)
MR. EVO MR's Avatar
Things That Will Cause A Trans To Shift Poorly
Got this from Team Rip-
THINGS THAT WILL CAUSE A TRANSMISSION TO SHIFT POORLY
AIR BUBBLES IN HYDRAULIC SYSTEM: BLEED CLUTCH CLICK HERE FOR MORE INFO
BENT OR WARPED CLUTCH DISC: WHEN INSTALLING THE TRANSMISSION DO NOT LET IT HANG BY THE INPUT SHAFT.
TRANSMISSION NOT BOLTED FLUSH TO THE ENGINE: MAKE SURE ALL BOLTS ARE IN PLACE & TIGHT.
MISSING ALIGNMENT DOWELS BETWEEN & TRANSMISSION: MAKE SURE BOTH DOWELS ARE IN PLACE.
WARPED OR DAMAGED PRESSURE PLATE: INSPECT WITH STRAIGHT EDGE TO MAKE SURE IT'S FLAT AND NOT SOUP BOWL SHAPED.
WARPED OR IMPROPERLY MACHINED FLYWHEEL: MAKE SURE FLYWHEEL IS MACHINED TO RECOMMENDED HEIGHT AND THAT THE MACHINE SHOP TRUE THEIR CUTTERS BEFORE MACHINING A STEPPED FLYWHEEL. STEPPED FLYWHEELS REQUIRE THE LEAD EDGE OF THE CUTTING STONES TO BE SQUARE. ALWAYS REQUEST THE MACHINE SHOP TO TRUE THEIR CUTTERS AND CUT THE FLYWHEEL TO THE RECOMMENDED OFFSET. CLICK HERE FOR MORE INFO
WORN OUT CLUTCH FORK: CLICK HERE FOR MORE INFO
PIVOT BALL NOT SHIMMED PROPERLY: DSM's MAY REQUIRE SHIMMING OF THE PIVOT BALL TO CORRECT CLUTCH FORK GEOMETRY. CLICK HERE FOR MORE INFO
AIR IN THE HYDRAULIC SYSTEM: BLEED CLUTCH.
WE RECOMMEND THE REPLACING THE CLUTCH LINE WITH THE AFTERMARKET VERSION.
IMPROPERLY OR WORN CLUTCH PEDAL ASSEMBLY: INSPECT AND ADJUST PEDAL TO CORRECT POSITION.
MISMATCHED CLUTCH COMPONENTS: USE A WELL KNOWN CLUTCH THAT HAS PROVEN ITSELF WORTHY.
IMPROPER OIL: FILL TRANSMISSION WITH RECOMMENDED OIL.
WORN SHIFTER CABLE BUSHINGS: REPLACE WORN OR DAMAGED BUSHINGS....POLYURETHANE BUSHINGS ARE RECOMMENDED.
IMPROPER SHIFTER CABLE ADJUSTMENT: ADJUST SHIFTER CABLES.
MISMATCHED SHIFTER BASE, CABLES OR SHIFTER LEVERS ON TRANSMISSION
Offline
Old Sep 23, 2009, 04:21 AM   #2
MR. EVO MR's Avatar
people here are asking the same questions
Offline
Old Sep 27, 2009, 08:42 PM   #3
Personal Sales Rating: (1)
Evolv3dEvo8's Avatar
Drives: 03 Evo 8
Good read
Offline
Old Sep 30, 2009, 02:07 AM   #4
Personal Sales Rating: (0)
if only it was not in all caps i would enjoyed it
Offline
Old Oct 7, 2009, 03:13 PM   #5
e2lancer's Avatar
Drives: EVOLUTION VII Lancer
Will check, does this also make a difference if the gears shift fine while car isn't running...
Stationary stage is fine, only when car has started - any ideas : anyone...
Offline
Old Oct 7, 2009, 03:18 PM   #6
EVOlute GSR's Avatar
Drives: Evolution 8 GSR
Those are really great points. Need to look into a couple, as I myself am experiencing minor issues...
Offline
Old Oct 31, 2009, 03:11 AM   #7
Drives: EVO IX
Thank you for the good ponts..
Offline
Tags
dsm, poorly, shift, shifting, trans, transmission
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
