the transmission you need a 15/16ths wrench and the drain plug is on the bottom the fill plug is on the front of the trans about half way up and should say fluid on it, when filling have the car level and fill till the fluid starts pouring out of the bolt hole should take roughly 3 qts in the transmission, the transfer case the bolt is on the bottom of it its big too, and the fill plug is kind of above the passenger side axel also says oil on the plug do the same for filling should take less than a qt i think
