Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo How Tos / Installations
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Sep 11, 2009, 02:39 PM   #1
Personal Sales Rating: (3)
Monochrome's Avatar
Drives: 05 Apexi Silver EVO VIII w/ SSL
BR solid shifter bushing install
Buschur just released these last week.
Very affordable and simple to install.
All you need is a phillips head screw driver, an 8mm & 12mm socket wrench, and pliers.
First off, you need to remove the center console. Piece of cake. Open up the arm rest and remove the 2 phillips screws inside.
Lift up your e-brake handle as high as it will go and lift up on the rear section of the center console. There are 2 tabs which hold in in place where the cup holders meet the shifter shifter piece. Lift straight up and set the whole assembly aside.
Now these 2 screws will be exposed. Go ahead and remove them. Unplug the white harness between them as well.
Open up the ashtray and pull it out. This will expose another screw for you to remove.
Next, unscrew your shift knob by turning it counterclock wise and set it aside.
Okay, now you get to open the door and sit on the ground on your knees. Take a peek down on the ground near the gas pedal. Remove that plastic phillips screw.
After the screw is removed, remove that whole plastic piece. This is what you'll see after its removed.
Look close and you'll see a plastic push pin. Take your phillips screw driver and press in the center of it. The whole piece should then pull out.
Repeat for the passenger side. There isn't a plastic phillips screw. Just grap that plastic cover and pull it straight off.
At this point, you should be able to just pull out the shifter console entirely.
__________________
05 Apexi Silver EVO VIII with SSL
Non-Stop Mixes By Monochrome <- click to listen! (Updated 9-7-09)
Offline
Old Sep 11, 2009, 02:52 PM   #2
Monochrome's Avatar
Okay, now say hello to your shifter assembly. Take your 12mm and remove the 4 gold bolts which hold it to the frame.
You'll notice, the shifter cable towards the drivers side gets in the way of one of the bolts. You'll need to remove the cotter pin which holds that cable. Grab your pliers and pull it out. Manly hands should be able to remove it without the pliers.
Slide the cable off the mount, push it down and around to the back side of the shifter like so.
You should have easy access to that 4th bolt now.
Alright, now take your 8mm socket and press out the metal insert inside the bushing.
With the inserts removed you can now easily remove the rubber bushing.
BR gives you 8 pieces. 2 per mount. One goes on top of the other like so.
The bushing should hug the plastic assembly. I found it easiest to do the 2 front bushings before the rear. Slide the bottom bushing into place, lower the shifter assembly onto it, set the top bushing over it, insert the 12mm bolt and thread it in just a couple turns. Leaving it loose makes it much easier to install the others.
Tighten everything down, put the interior back together, and go for a drive.
Aren't those shifts much more crisp? Thanks Buschur!
__________________
Offline
Old Sep 17, 2009, 07:09 AM   #3
Personal Sales Rating: (86)
Jrod@Buschur's Avatar
Drives: off the road at random and hits stuff.
Excellent write up! Thank you for the contribution.
Glad you're happy with your purchase.
Offline
Old Sep 24, 2009, 09:44 AM   #4
Personal Sales Rating: (7)
EGbeater's Avatar
Drives: '93 B18C1 EG Civic, '06 GG Evo 9 SE, '03 CBR954RR
Quote:
Do these aluminum bushings add a noticeable amount of vibration through the shifter?
__________________
FP GREEN TURBO FOR SALE, ZERO MILES!
GG IX SE, 11.893 @ 114.84; 1.637 60-ft, 11.989 @ 115.65; 1.724 60-ft (Bandimere Speedway, 5,860 ft elevation) stock turbo, E85, Cosworth cams... TUNED BY Tobz Performance Tuning
"Aren't you a little too old to be driving that car?"
Offline
Old Sep 24, 2009, 10:54 AM   #5
Personal Sales Rating: (0)
Brsox10288's Avatar
Drives: 2006 Evo SE-SSL, 2001 Eclipse, 05 Mustang GT
Im curious about these too. Im looking at getting base bushings (like these) and underhood bushings?
Offline
Old Sep 24, 2009, 11:04 AM   #6
Quote:
The vibration is very minimal with these. Its not bad at all. It is nice to have the shifter base stiff and in place in my opinion.
Offline
Old Sep 24, 2009, 11:06 AM   #7
Brsox10288's Avatar
Whats the advantage of using these versus poly based bushings? same with underhood?
Offline
Old Nov 6, 2009, 06:18 PM   #8
Personal Sales Rating: (24)
detroit pistins's Avatar
Drives: tb ix gsr ssl
Monochrome, thanks for the awsome write up.
just got my bushings few days ago and will install tomorrow. will let u guys know how it goes.
Offline
Old Nov 7, 2009, 01:15 PM   #9
Monochrome's Avatar
Not really.
You'll love they way they feel though.
__________________
Offline
Old Nov 7, 2009, 09:22 PM   #10
well i added the AL bushings today, underhood and baseshifter bushings + B&M short thro shifter, and tell u what it feels alot more solid now.
the whole installation of all the bushings with the short shifter, took almost 1.5 hrs. Thanks to the Op for the great write up, otherwise it would have taken me longer.
Thanks
ps. no noise or vibrations increased.
Offline
Old Nov 9, 2009, 10:57 AM   #11
Awesome. Thank you for the pic. Glad you're happy with your purchase Detroit.
P.S.- Go Cavs!
Offline
Old Nov 9, 2009, 11:06 AM   #12
Personal Sales Rating: (14)
evoracingstar's Avatar
Drives: 06 Graphite Gray Pearl Evo 9 SE
Send a message via AIM to evoracingstar Send a message via MSN to evoracingstar
Nice write up I have to order these! I got the under hood one too
__________________
Evo 9 SE- BUSCHUR HTA35r Tubular Manifold Turbo kit, AMS Turbo Back With Test Pipe Exhaust, AMS Upper Intercooler Pipe With Tial Bov, Buschur Lower Intercooler Pipe, Odyssey Battery, Hallman Boost Controller, Walboro 255 Fuel Pump, Cosworth 272 Cams, ARP Head Studs, ACT HDSS clutch, Custom 4inch Hard Pipe with k&n filter, AMS 1000cc injectors
"Stock motor Stock ecu"
"The Build is on the way!!"
IVEY TUNE!
511hp 410tq Pump gas/ No meth
BUSCHUR RACING FTW
Offline
Old Nov 9, 2009, 03:30 PM   #13
Drives: GG IX STY?
I still cant find a how to on the underhood bushings. Can anyone help?
Offline
Old Nov 9, 2009, 07:55 PM   #14
Quote:
honestly man, it spretty straight forward, remove the battery, remove battery tray....BAAAM u will see the bushings, remove the pins that are holding the bushings (do them one at a time), replace the old bushings with the new ones, put the pins back on. and ur done!
gl
Offline
Old Nov 10, 2009, 02:17 PM   #15
Drives: GG IX STY?
tight, I shold be able to fugure it out from there, Thanks for the help.
Offline
Tags
assembly, base, br, bushing, bushings, cable, evo, instll, shifter
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
