Aug 29, 2009, 08:35 PM
Personal Sales Rating: ( 0)
Nisei IC Piping Install Help!!!! Cant connect BOV
Am I missing a corner tubing piece to connect my BOV from underneath on the Nisei UICP to BOV. I have a Perrin Intake and with all the pieces I got (they gave me like a 3 inch extra tube with my IC piping) it is still a couple inches short and has no right angle to make it to the fact that the inlet is on the bottom side of the piping.
Any ideas? I do not have a daily driver. Car is not in driveable state, obviously.
__________________
ETS Black 3.5" FMIC, Nisei IC Piping, Walbro Pump, Perrin Intake, Buschur TBE, Swift Springs -- UNTUNED
Offline
Aug 29, 2009, 09:55 PM
Personal Sales Rating: ( 2)
Drives: Turbo Mirage (for sale), 03 TB VIII (RIP), 05 AS VIII
Pictures? I don't follow. Can you just install your OEM IC piping in the meantime?
__________________
-Rich-
2003 Tarmac Black Evo VIII (R.I.P.)
2005 Apex Silver Evo VIII
CBRD tuned:
331whp / 319wtq @ 24psi on 93 oct.
My Photography
Offline
Aug 30, 2009, 01:11 AM
I rushed to Autozone with 5 minutes left till close, made it in and bought Rubber Radiator housing long enough with a bend, came home and razer'd the length i needed and went from the BOV to the IC pipe.
Is rubber radiator housing going to be fine for a while? Or is it sketchier then Silicone housing.
I know I explained it pretty bad originally, the problem was that I got no extra silicone piping with my Nisei Kit even though the location of the BOV Recirculation is way closer to the intake manifold then other setups. That being said they should know that users would need extra silicone to make it all the way to the BOV.
__________________
Offline
Oct 7, 2009, 10:03 AM
Drives: 03 evo 8 bby
yea rubber radiator hosing will work, the hose itself is designed to work with hot coolant....so warm air isnt gonna do anything to it, just make sure u got it clamped on there good n tight n u should be good to go... make sure the ID of the hose is the right size or u might have a boost leak problem...
good luck
__________________
espelir catback dc sports cat delete downpipe titek 3" 02 housing hks 272 cams xs engin fmic and piping 880 injectors 255 pump dejon tool greddy type rs bov tein lowering springs built 2.0 block je pistons eagle rods acl race bearings arp main head rod studs brian crower valvesprings and retainers stock valves fp red turbo balance shaft eliminator kit aem wideband gauge milspec exhaust manifold high pressure throttle body seals aem intake optima battery relocated to trunk
Offline
Oct 7, 2009, 10:08 AM
Personal Sales Rating: ( 55)
Drives: corolla
Did you try to contact Nisei? I talk to them on the phone b4, it's not that hard to reach them.
__________________
4WHEELSLIDE TUNED
ROBISPEC TUNED///
Offline
Oct 7, 2009, 10:35 AM
Personal Sales Rating: ( 27)
Drives: Silver IX Mr
Nisei sends you one silicon piping and the other side you need with the angle to the pipe, you re-use the stock one on the stock upper pipe.
__________________
Silver IX MR
AEM / AMS / APR / ARC / Blox / Buschur / Carbing / Cusco / Hallman / Helix / HKS / JDM / Megan / Mynes / Nisei / Nokya / Orbital / Pioneer / RallyArmour / S2K / Sparco / Swift / Walbro / Works
IveyTuned
AIM: porsherules911
Offline
Tags
05, bov, evo, ic, inlet, install, nisei, oem, pieces, pipe, piping, rubber, turbo  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
