Greddy profec b-specii install using a external waste gate
If you are looking at using this EBC with and external waste gate here is how it should be installed. First off im using this with a external Tial waste gate. Top nipple off of the wast gate will be ran to the (COM) port on the solenoid. The lower nipple off of the waste gate will be first "T" into the the compressor housing of the turbo and then ran to the (NC) port of the solenoid. This leaving (NO) port open to vent. The rest of the install includes "T" into the fuel pressure regulator line and running that same hose through the fire wall to the controller inside the cab, then running the harness from the BOOST solenoid through the firewall to the controller in the cab as well. With this all done all is left is the ground and power for the control unit.[/b]
__________________
It Is What It Is..................
