Aug 20, 2009, 07:57 PM
Personal Sales Rating: ( 31)
Drives: 03 Apex Silver Evo VIII - 05 WRB/Gold STi (both gone) - 06 EB Evo IX
Air Bag removal - after deployment?
Had my airbags deploy last year and decided to turn the car into a track car. So, instead of replacing the airbags, the shop just cut them off and done.
So I'm trying to clean things up a bit and wanting to remove all the extraneous SRS airbag parts. I've read how to remove the airbag, but this is a bit different since it's been deployed...I think.
Once I pulled the steering wheel off, there is a a yellow wire ribbon that is still connected to the inside of the steering column. My question - what is this? What should I do with it? Keep it or cut it?
Offline
Aug 20, 2009, 09:17 PM
Personal Sales Rating: ( 42)
Drives: evo 1 gsr/ evo ix mr 5spd
The yellow ribbon is your clockspring and you will need that for the horn I believe but just remove the 2 bolts in the side of the wheel and the bag will come out but you may wan't a new clock spring.
Airbag deployments in evos will need the following parts replaced
Dash
drivers bag
clockspring
steering column
seatbelts
windshield
and depending on the year it may need a new srs ecu
__________________
The good die young and the pricks live forever!
-Lewis black
Offline
Aug 20, 2009, 09:19 PM
Btw once the drivers bag deploys the clockspring will need replaced or in your case just cut it since once it comes apart it is no longer any good.
__________________
-Lewis black
Offline
Aug 20, 2009, 09:25 PM
Personal Sales Rating: ( 23)
Drives: 06 Evo MR
Info should be here. Great site for DIY for our cars.
Offline
Aug 20, 2009, 09:32 PM
Personal Sales Rating: ( 11)
Drives: Fully Built 2.3L Evolution VIII
I have a dash with a good airbag for sale much cheaper than you can get a new one for.
Pm if interested
Offline
Aug 21, 2009, 06:31 AM
Quote:
Yeah, I'm not interested in replacing it. It's mainly a track car now so it's just less weight!
I would like to have a horn back if possible. If the yellow ribbon is not part of it; sounds like I can trash it. I thought the black wire was the horn?
Offline
Aug 21, 2009, 08:11 PM
I am not 100% sure but the ribbon I know goes to the bag so I guess it would make sense that the bigger wire is for the horn.
__________________
-Lewis black
Offline
Aug 22, 2009, 10:24 AM
Here's how things look now.
Here's the pic of the wheel with everything removed. And the other pic are the spare parts. I wonder if I can make some kind of filler; maybe out of CF or something to fill in the hole? How do the RS wheels look there?
Offline
Aug 22, 2009, 11:38 AM
Personal Sales Rating: ( 2)
Drives: 03/VIII + 06/IX
Dash
drivers bag
clockspring
steering column
seatbelts
windshield
I still don't understand why the steering column would need replacing? I've fixed 2 wrecked Evo's neither of which needed steering column's. This car is not German where it drops to prevent injury.
Also the SRS Module can easily be reset vs paying a fortune for a new one. Yes, even permanent fault codes from airbag deployment.
Offline
Aug 26, 2009, 02:07 PM
Personal Sales Rating: ( 10)
Drives: '06 Lancer Evolution IX RS, '02 Montero SWB (RIP) '06 Montero SWB
RS wheels are the same as yours used to be, RS version comes with airbags.
__________________
Ralliart drop in filter, UR turbo back exhaust with test pipe (waiting for a tune)
Tuned by Mellon
Offline
Sep 9, 2009, 10:07 AM
Personal Sales Rating: ( 0)
Drives: 2004 RR RS
my steering column broke upon impact... and it wasnt that hard of a hit. i wonder how expensive the steering column is to fix.
Offline
Tags
2006, air, airbag, airbags, bag, bags, deploys, evo, gold, horn, lancer, module, removal, remove, srs, thread  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
