Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo How Tos / Installations
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jul 19, 2009, 05:58 PM   #1
Personal Sales Rating: (0)
NLIevo8's Avatar
Drives: 2003 Evolution 8
Evo 8/9 Aftermarker Steering Wheel Install
When I was getting ready to install my steering wheel I really couldn't find anything on forums that covered it. It is really an easy install, just wanted to post it up so there is a good write up on it
I am installing a Vertex Anniversery steering wheel using an NRG short hub part number 101H.
Disclaimer: Removing your airbag could cause serious injury or death if involved in front end collision. This is for racing/ off-road use only.
Start by removing the negative terminal from the battary. This will help protect from the airbag deploying while you are disconecting it.
Remove the small cover located on the bottom right side of the steering wheel.
Disconnect the airbag connector and the horn connector from the steering wheel. Just push in the tabs on the plugs and pull them loose.
Using an 8mm allen wrench, remove the bolt holding the steering wheel to the column. It is located on the bottom left side of the wheel at the 8 o'clock position. There is no need to pull the two bolts holding the airbag in the wheel on left and right 3 o'clock and 9 o'clock positions. You can just leave the airbag in to protect it.
You can now pull the steering wheel off the column exposing the clock spring.
Take the time now to remove anything from the top and bottom of the steering column ie: gauges, turbo timers, etc.
Romove the three bolts from the bottom of the column cover next to the tilt lever.
Romove the upper and lower column covers. This will expose the two small phillips screws holding the clock spring in.
On the bottom of the clock spring, pull down the green safety tab on the airbag connector and disconnect it along with the horn connector.
You can now pull the clock spring off the column. Be careful not to break the plastic tabs holding it in.
Now we have to deal with the airbag connector because just leaving it unplugged will cause the SRS light to stay on the car.
It is a easy fix using the little harness provided by NRG. If you don't have one, just splice two short wires with a 2 amp fuse and connect them to the airbag plug. Polarity does not matter.
As for the horn, I just used a wire splice with about a six inch peice of wire to connect to the horn. You want enough slack so it won't bind up when you turn.
Now you can attach the upper and lower cover back on the column. Make sure you feed the horn wire through.
Remove the six 4mm allen screws from the outside of the hub.
Loosen and remove the two 8mm bolts frpm the spline of the hub. These bolts will pass through the indentions in the column shaft so the have to taken out.
Slide the hub onto the splines and tighten the 8mm hex bolts. Make sure these are tight so the steering wheel won't slip.
Attach the outer portion of the short hub with 4mm hex bolts.
Plug up and attach your horn button.
......and your all done.
You can put a quick release in between the hub and steering wheel. It bolts in strait forward. This Vertex is JDM hotness but it is kinda deep (and I do like em deep) and a quick release would put it to close to the driver. Plus I don't want to be that guy walking around a local meet holding my steering wheel!
__________________
2003 Evo VIII
SBR 20g, Snow Performance Meth, Comp 272's
http://i36.photobucket.com/albums/e4...6/evostang.jpg
Offline
Old Jul 19, 2009, 06:17 PM   #2
Personal Sales Rating: (36)
Evoryder's Avatar
Drives: EVO METH MACHINE
nice write up. Wheel is not my cup of tea.
__________________
TEMEVO
"I'm addicted to 100% Methanol : ) "
MACHINES GONE WILD
FOR SALE: FORGE WASTGATE/PERRIN INTAKE CLICK ME
Offline
Old Jul 19, 2009, 06:32 PM   #3
Jp7
Jp7's Avatar
Drives: CT9A (MR/9) - Hopefully AE86 Soon
LOL, I don't think off road or race use makes it any better!
But excellent write up, might I add!
Offline
Old Jul 20, 2009, 07:11 PM   #4
NLIevo8's Avatar
Yeah, I guess getting in a collision off road or not doesnt really matter. I think it would suck either way. lol
__________________
2003 Evo VIII
Offline
Old Aug 9, 2009, 06:21 AM   #5
Personal Sales Rating: (1)
fbikawi's Avatar
Drives: Evo VII JDM
does any body know what part number is for a MOMO hub that will fit the GSR CT9A Evo, ie Evo 7, 8 and 9 with the side screw fixing.
i bought a Momo Steering Wheel and the momo hub part No. 6116 which was advertise to fit the evo 8..but it didnt.
some one advised that the correct model from Momo is No. 6106...
i am not sure, and will appriciate if some body can confirm.
__________________
www.bikawiautosports.com
Offline
Old Aug 9, 2009, 12:44 PM   #6
Hioffcr's Avatar
Location: Killeen, Tx via Fayetteville, NC via Worthington, OH
Drives: Evo VIII, Manum RT
Yeah, I got bit buying the 6116 as well. It will fit the X but not the 8. Still haven't figured out which one fits ours, but I found this:
http://www.momousa.com/products/prod...ishi-hubs.html
__________________
20 \G Turbo upgrade, 18" Advan Kreuzer X series, PRW Radiator, FMIC, Greddy UICP, LICP, MR BOV, Forge MBC, CUSCO Strut Tower Brace, Hotchkis Rear adjustable sway bar Tein Coilovers, Defi Boost, EGT, Temp guages, GTSpec Header, Greddy TBE, R1 Concept Rotors, Hawk Pads.......
Tuned by KevinD
www.evolutiondynamics.com
AEM EMS for sale:
http://cgi.ebay.com/ebaymotors/ws/eB...%3AMESELX%3AIT
Offline
Old Nov 1, 2009, 04:42 PM   #7
Personal Sales Rating: (3)
Drives: EVO9 MR
So do you know what kind of hub is perfect for MOMO millenium steering wheel? Can I get the long hub? Will still work? Thanks!
Offline
Old Nov 1, 2009, 06:22 PM   #8
Personal Sales Rating: (4)
bricel24's Avatar
Drives: GG Evo 9
Send a message via AIM to bricel24 Send a message via Yahoo to bricel24
Quote:
Any hub that is specific for the Evo will work (NRG/Momo/Works Bell/Splash). Are you planning to do a quick release system on the wheel? If you do, you can either one of these:
1. short hub + regular quick release.
Or
2. regular hub + short/thin quick release.
__________________
SpeedElement | tuned by GST Motorsports | Emperor Motorsports | RALLI////ART
www.evoempire.org
www.emperorevoclub.com
Offline
Old Nov 1, 2009, 10:46 PM   #9
aschold's Avatar
Drives: 2003 Tarmac Black Lancer Evolution VIII
Quote:
I realize this is an old post, but for clarification, your airbag can cause severe injury or even death if it deploys while you are wearing a helmet.
__________________
2009 Yamaha VX110 Waverunner
Offline
Old Nov 9, 2009, 08:44 PM   #10
up
This is a great write up! Thanks.
Offline
Tags
evo, evom, forums, horn, install, personal, quick, release, remolval, removal, slips, steering, suburban, wheel, wheels
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
