Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo How Tos / Installations
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jul 19, 2009, 04:19 PM   #1
Personal Sales Rating: (6)
05ah8james's Avatar
Drives: 05 GG MR wit dem purple rimz
AEM Uego to Evoscan Wiring...
I looked on the board to find out how to install the AEM Uego so it would work with Evoscan, but didn't find any write ups, just some discussion, so heres how to do it This project cost me $45 at my local radioshack, and about an hour of my time.
Heres what you need:
-D-sub to USB cable
-D-sub 3 male adapter
-D-Sub Shroud
Next you need to make the male connector accept the wiring needed for the install. The AEM Uego blue wire needs to go into port 2 of the d-sub, and you need to make a ground off of port 5. I chose to extend the wiring and use simple adapters to connect them in the car. Below is my crude dipiction of what the connectors look like. You need ports 2 & 5 as mentioned.
\ 1 2 3 4 5 /
\ 6 7 8 9 /
After all the soldering is complete it should look like this:
Note: continuity is very important with something that needs to be percise such as this gauge reading. Make sure all your solders are shiny and the solder sinks into the wiring. For this to happen the wire and receptical need to be hot.
I chose to use a shroud to keep everything neat and organized, and to keep any possible tension off the wiring. It should look like this before you put the other half on.
This is what the completed assembly looks like.
And what you need for the final install:
-Wire cutters
-2 Zip ties
-1/4 Rachet
-12mm Socket
-Wire Clamp
Picture:
Clamp the male addapter to the blue signal wire on the Uego.
Find a place to ground the d-sub. I chose one of the 12mm steering column bolts. Then ziptie the actual d-sub to the grounding terminal where your tatrix cable goes. This will keep everthing nice and organized.
Install the software provided with the cable you bough, open evoscan, and have fun logging!! Any Evoscan 2.6beta users. You will need to downgrade to evoscan 2.5 until this bug is worked out.
Offline
Old Aug 13, 2009, 05:16 PM   #2
Personal Sales Rating: (0)
spoolinx's Avatar
Drives: 04 WW EVO VIII GSR
great write up!!!
__________________
04 WW EVO VIII GSR
in the works!
Offline
Old Aug 16, 2009, 11:38 AM   #3
Personal Sales Rating: (2)
Preludepearl417's Avatar
Drives: DC5 Integra Type R, EVO 8 and DC2 Integra LS
i was wondering how to do this....good write up!
__________________
Burchur Stage 3 head BC valve springs retainers valves GSC S2 cams ARP studs Cometics headgasket TBE O2 housing FP Red Deatchworks 780cc injectors Fidenza cam gears Exedy Twin plate Gt Spec manifold Walbro 255 AEM gauges boost contoller Custom upper and lower IC pipes ETS IC Greddy Type S blow off valve Tein Super Street coilovers
Offline
Old Nov 5, 2009, 03:10 PM   #4
NickieBlaine's Avatar
what gauge wiring was used?
__________________
2003 AS Evo- Broken
SBR 2.4- Spun Bearing in less than 200 miles
Ported/Polished/ 1mm Oversized Head
Comp 272's
ETS 4" FMIC
BR Ported Intake Mani
FP Ported Green, 18psi actuator
BR Ported Exhaust Mani
780cc
APS DP BOV
BR Mini Battery Kit
Full 3" Exhaust
Exedy Twin Disk
Walbro 255
www.midwestevos.com
Offline
Old Nov 6, 2009, 12:06 PM   #5
Did the blue wire just pull out of the back of the plastic clip that goes into the gauge, or did you have to cut it?
__________________
2003 AS Evo- Broken
Comp 272's
ETS 4" FMIC
780cc
APS DP BOV
BR Mini Battery Kit
Full 3" Exhaust
Exedy Twin Disk
Walbro 255
www.midwestevos.com
Offline
Old Nov 6, 2009, 01:45 PM   #6
Personal Sales Rating: (27)
dsm25psi's Avatar
Drives: 2005 evo 8
thanks for the info, im getting it done
__________________
(700hp)6.6@111mph on Stock SSL car, With a sunroof lol
762hp and 608tq on the stock ecu!
771hp & 606tq - New
800s are next
Sponsored by:
ETS
JM Fab
Force-Fed Performance
Offline
Tags
aem, blue, evo, evolutionm, evoscan, extending, gauge, guage, howto, scan, uego, wire, wires, wiring, work
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
