Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo How Tos / Installations
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jun 27, 2009, 03:34 PM   #1
Personal Sales Rating: (0)
Drives: 2004 evolution 8
egr valve
i have an evo8 and recently my service light came on.after a month i went to get it reset.after they ran it in the computer it show random miss fire and o2 sensor bank2.so i got the o2snsor to change it but now im still let with the miss fire code.my mech told me that the egr valve is probly cloged and is causing the miss fire.....did any one have this issue with their evo? and how did you fix it?
Offline
Old Jun 27, 2009, 03:39 PM   #2
Eric Morse's Avatar
Drives: Lotus Elise, BMW 330i, Evo VIII sold & looking to get a new X
Send a message via AIM to Eric Morse
I also have an egr solonoid valve issue that were trying to take care of since its sitting, un-registered and in unspected first, to bad the parts are 141$ alone.
Offline
Old Jun 27, 2009, 03:39 PM   #3
Personal Sales Rating: (9)
wevo1985's Avatar
Drives: '03 white evo 8, '93 black eagle talon tsi awd (dd)
Send a message via AIM to wevo1985
i havent had that problem and dont really know how a clogged egr can make a misfire. i can under stand if its stuck open itll cause it. how old are your plugs? what are they gapped at? do you have cams and or a tune?
__________________
br hta37r, br stage 4 boltons, kelford 280 cams,jam lifters, supertech duel valve springs, ti retainers, nit valves, ported and polished runners by me, ported and polished intake and exhaust mani by me, br ported throttle body, , ross custom banodized pistons, manley i-beam rods, 100mm crank
568hp 460tq at 30psi on the stock ecu tuned by ivey!!!
Offline
Old Jul 9, 2009, 01:03 PM   #4
Personal Sales Rating: (10)
bboypuertoroc's Avatar
Drives: 2006 Tarmac Black Mitsubishi Evolution IX
If you haven't fixed the problem, check your EGR and make sure that the vacuum lines that run to it are actually hooked up.
I had crazy misfire issues and was informed to check the vac lines on the EGR valve (thanks again GST). Problem solved... use a zip tie and a bit of hair spray to keep the line from popping off.
__________________
ENGINE
FPRed - Kelford - ETS - TurboXS - Buschur Racing - Walbro - GSC - EPM - ACT - Hallman - PTE - ARP - PPI - TiAL - Gruppe-S
FOOTWORK
Tanabe - Progress - Stoptech - Hawk - Motul - Whiteline - Falken
EXTERIOR
JDM IX Rear - Rexpeed - JDM VIII MR Tails - JDM Signals - Blacked-out Headlights - Debadged - S2K Antenna - 6K HIDs
INTERIOR
Defi - Kenwood - Innovate - B+M - Speed Source
Tuned by Mellon
Offline
Old Jul 9, 2009, 01:48 PM   #5
Personal Sales Rating: (15)
Kracka's Avatar
Drives: Wicked White Evo IX GSR
Send a message via AIM to Kracka
Remove your EGR valve, install an EGR block-off plate, and disable the EGR emissions checks in your ECU Cheap, easy, simple!
Disabling EGR and fuel pressure solenoids
Offline
Old Oct 16, 2009, 01:50 PM   #6
2005 Mitsubishi Lancer Evolution
adcgn45's Avatar
Drives: 2005 lancer evo 8
do you maybe have aftermarket exhaust ? not running a simulator? this could trigger the o2 code.if so return the o2 sensor and buy the 3 dollar spark plug non foulers
Offline
Tags
06, code, egr, evo, evolution, fixing, gst, installation, issue, jdm, lancer, location, mitsubishi, remove, valve
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
