HOW TO: AEM UEGO serial cable
assuming you have already installed the gauge itself, this is for anyone who wants to know how to make the serial cable for logging.
this was just my method. opinions may vary...
as you can see the instructions as per AEM is pretty straight forward. blue wire to no. 2 pin and black/ground to no. 5 pin.
i purchased a db9/rs232 female connector from radio shack for $2.19 and soldered the wires to the pins. the pins are labeled so you cant really go wrong.
next i crimped and soldered connectors to the ends of the serial cable in this configuration. i'll explain why later.
your serial cable should look a little something like this...length may differ
in the car...
ignition power and ground for the gauge itself comes from my radio harness adaptor.
if you've noticed, the ground is bolted to body. the ground for the serial cable will also use this ground.
here, ive connected everything together. the gauge gets its power from the ignition source and is grounded through the body. connect the blue wire for the serial cable and the ground wire, which at the same time is grounded through the body.
and in this picture, ive disconnected the serial cable completely. but because of the configuration of the serial cable, i am able to still maintain a clean connection with the gauge.
thanks and enjoy.
in the car...
thanks and enjoy.
FS[SouthEast]: FS: TN/KY 1987 Corolla GTS coupe blue 180k miles
Drill_Sergeant
May 26, 2014 12:59 PM
borievoinitialD
Feb 21, 2010 06:50 AM
Steve@NoLimitmotors
50
May 27, 2007 07:50 AM
