HOW TO: Install front rotors
Old Jan 25, 2009, 05:49 PM
o-townFLA's Avatar
Talking HOW TO: Install front rotors
To start off I accept no responsibility for faulty installations and the consequences of the before or after results.
TOOLS:
- 19mm socket/wrench
- torque wrench
- floor jack/ lift
- 2 jack stands
- coat hanger/safety wire
First of all this install is pretty straight forward. But for those of you that may need the know here you go.
STEP 1
Jack up your car and place the jacks at the lift points of the car and then remove your wheels. Before touching your rotors or brakes make sure they are cool to the touch!
This is shot after I replaced the rotors. I also lifted the entire car due to a brake bleed after the install
STEP 2
Then turn you ignition to the "accessory" position and turn your steering wheel to the full left/right (depending on the side of the car your working on) to gain access to the caliper knuckle bolts.
STEP 3
Here are the two 19mm caliper knuckle bolts that are need to be removed. Once the caliper is unbolted you can then slide your caliper away from the rotor. BUT if your rotors have any lip on them you will need to remove your pads. Refer to the any brake pad removal HOW TO. sorry
STEP 4
Now you need to hang the caliper up. To hang it, cut up the coat hanger/safety wire long enough to hang the caliper from the suspension or whatever seats your needs. Main thing is to not let your caliper hang from the ABS/Brake line.
STEP 5
Your rotor should now easily slide off of the axle hub. Once its off slide the new rotor and then tighten it down with a few lug nuts.
BEFORE
AFTER
STEP 6
With the rotor held down with the lug nuts you can then put the caliper back on. (WITHOUT the the brake pads in the caliper, if removed) Be sure to then torque the caliper knuckle bolts to 80ft.lbs!!! If the pads were removed you can replace them when the caliper is placed back and the bolts are torqued down.
Place the wheel back on and just repeat for the other side.
CAUTION Before driving ensure all bolts are properly tightend and drive slowly. While driving, try to listen for any unusally sounds or abnormal vibrations.
Then you will have to bed in your pads to you rotors.
After all is said and done drive it like you stole it...!
Holla
o-townFLA is offline
Old Jan 29, 2009, 11:40 PM
chaotichoax's Avatar
Discuss thread HERE!
chaotichoax is offline
o-townFLA
52
Oct 11, 2010 11:22 PM
o-townFLA
May 7, 2009 11:31 AM
o-townFLA
Jan 26, 2009 12:24 PM
o-townFLA
Nov 12, 2008 10:02 PM
o-townFLA
Dec 10, 2006 08:33 PM
Quick Reply: HOW TO: Install front rotors
