Ok, this is part 2 of the how-to on how to remove the troublesome leaky seals in the throttle body.
Tools you will need:
-10mm socket
-Flathead screwdriver
-Phillips screwdriver
-Needle-nose pliers
-Sharpie
-Locktite Blue
-Dielectric Silicone Grease
-Spring clip pliers with very small tips. If you don't have a pair, you should be able to buy them at most hardware or auto part stores. I bought this pair at Home Depot
Ok now that you have the tools, lets get started
1. Mark the TPS/TB housing with little hash marks so you get it lined up when you re-intall it. The reason for doing this is that there is a preload on the spring inside the TPS and if you dont put the same preload back on the spring when you reinstall it the ECU could be interpreting incorret information and/or your idle may be a little off. Remove the TPS using the 10mm socket on the two bolts.
2. Use the spring clip pliers to remove the spring clip on the end of the shaft once the TPS is removed. There is a plastic washer and then a metal washer under it. Set these somewhere safe.
3. Take off the butterfly valve (circular plate in the TB) If you look really closely, you will see that it looks like Mitsu used Blue lock-tite on these bolts. Use the phillips screwdriver.
4. Slide out the shaft assembly with the throttle spring still attatched. The spring will unravel some.
5. Use a flathead to pop out the seals. You will see that it is a metal ring that is pressed into each side of the TB, the seal/oring is bonded to this metal ring on the inside. Pop them out. This wasn't easy and be careful not to score the inside of the TB cylinder where the new seal will be. I tried to get as much of the rubber seal out before prying off the metal ring. This allowed for a better "bite" into the ring to pop it off.
6. Once they're out, put the new ones in. The "open" end of the seal goes inward. Lube them up with the dielectric silicone grease or something similar. Press them in really well.
7. Install the shaft back in with the spring attatched. Best bet is to install it about 9-tenths of the way in, then twist the throttle spring so it sets on its catch, then push the rest of the way in. You will need to twist it about a good half turn for it to set on its catch. Make sure the tension is correct.
8. Look at the TPS side. Did the seal pop back out when you put the shaft through? No biggie if it did... use the copper washer as a "press" and used some needle-nose pliers to press it back in place where it should be. You can pull the copper washer off to inspect that it is seated properly after you feel its on there correctly.
9. Reinstall the copper washer then the plastic one then the spring clip then your TPS. Make sure your hash marks line up before you tighten it down.
10. Put a little blue locktite on the thread of the Butterfly valve screws. Screw in the plate and you're done. If you installed it correctly, the top of the butterfly valve should open inward to the Intake Manifold side.
Follow the directions backwards of
Part One on Removal of the Throttle Body to install it back on your intake manifold.
Check the tension of the throttle cable once everything is bolted back on. If you think the cable has a little too much slack in it before it opens the butterfly valve, you can adjust the "free play" i.e. slack in the throttle cable line by shifting the cable mount to the left.
After you have it all dialed in, you can be happy with the fact you have one less boost leak to worry about for awhile. Grab yourself a beer, you deserve it.
Thanks to everyone who posted up info regarding this problem and solution!
