Home Features Community Marketplace Registry Garage Store
Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo How Tos / Installations
Sign in using an external account
Register Forgot Password?
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Closed Thread
Thread Tools Search this Thread
Old May 5, 2006, 03:24 AM   #1
Personal Sales Rating: (20)
2004 Mitsubishi Lancer Evolution
SRTRaceR04's Avatar
Drives: 04 BBY 35R Evo 8 (sold), 06 GG 9 MRx2 (both sold), 04 Cobra (sold)03- AS Evo- Sold, current-05 AS Evo, 06 GG Evo, 08 Evo X, 96 Teg (beater)
Points: 9,456, Level: 65
Points: 9,456, Level: 65 Points: 9,456, Level: 65 Points: 9,456, Level: 65
Daily Activity: 6.5%
Daily Activity: 6.5% Daily Activity: 6.5% Daily Activity: 6.5%
EvoLvr2006
Send a message via AIM to SRTRaceR04 Send a message via Yahoo to SRTRaceR04
How-To polish (rims) 56k warning
This is my first how-to so hopefully I am writing and explaining everything clearly enough for people to easily understand. If their are any questions, feel free to PM me at any time. I am not an expert and do not claim that status. Remember that doing any polishing work is at your own discretion. Damage done by improperly polishing can be costly, so please plan what you are doing ahead of time. On with the show.
This is a how-to that will explain the process I applied when fixing a polished wheel. The process is very similar to polishing something that has not been polished before. The roughness of the surface will determine what grit you need to start with.
Polishing is a time consuming process that will require determination and attention to detail to get right. Skipping steps or being lazy will definitely show in your final result. So, to save time, do it right the first time!!
Ok onto the main part!! For the application I’m involved with I used the following materials:
Sandpaper - grits 400-2000
Sanding block-- not necessary but helps with first couple of steps. When you get into the higher sandpaper, do it by hand!!
Bowls-- Or something else to hold water for wet sanding:
Mothers Polish-- or some other polishing agent
Soap and water-- make sure to clean thoroughly with soap and water between each step. Some people may not do this, but I do to make sure I don’t get dirt scratches in the later high grit steps.
Non-abrasive towels-- or cloths. For applying the polish.
Ok, here we have a pretty busted up rim. Theirs is no major damage to the rim, but the salt has eaten into the polished part of the rim. What can you do for $100 for a set with tires??
Begin by starting with your lowest number grit sandpaper. I started with 400grit.
After a little while of sanding and sweating you start to see what you are taking off the surface of the rim:
And here I are about finished with step one. I still need to wash the wheel and make sure it’s clean and ready to start with the next grit up.
All clean and ready for step 2 with 600 grit
Middle of step 2:
All clean again ready for step 3 with 800 grit:
In the middle of step 3:
Steps 4-6 are more of the same. By this point you should be noticing that the metal should be looking pretty shiny. And it should also be consistant. So if their are places where it seems the marks from the sandpaper are different then that means that you probably didn't hit that area enough. So you will want to go back over it with the previos grit of sandpaper to try to get a uniform look to the entire piece.
After you have completed all the grits of sandpaper you should have a very smooth surface. It will not look completely shiny just yet. Look over your piece and make sure that everything is consistant and you don't have gaps or differences in the surface. If you do, go back and correct them. When it's completely polished imperfections are magnified and easily identified.
When your surface is all smooth and ready to go wash your pece. Wash it good to make sure you have all the oils/dirt, and debris off of the piece. Then with your terry cloth or other non-abrasive towel, start adding mothers polish a little bit at a time. You want to rub it in until it starts to turn grey/black. A little bit goes a long way. After it has a faded dry look to it, go over it with another clean cloth/towel.
I usually do pieces with 2 coats of mothers, but with this piece I have pictures taken with only one coat on them. It's up to you if you feel it is necessary to put on 2 coats. I usually put on 2 cause I tend to get spots I may have overlooked the first time around.
And here's what you should end up with:
The pictures were taken inside with artificial light. If done correctly, the polished piece will really stand out in real sunlght!!! It's a long and tedius process. This piece alone took about 2 1/2- 3 hours. But if you stick with it you will be rewarded with a beautiful piece that looks much cleaner than it originally did. Thanks for viewing and hopefully this helps anyone looking to polish something.
Stay tuned for the how-to on painting the rest of this wheel graphite.
__________________
Back in an Evo...again. (V)(;,,;)(V)
Offline
Old May 5, 2006, 04:10 AM   #2
Former Vendor
Personal Sales Rating: (107)
Garage is empty, add now
Curt@MrLed's Avatar
Drives: www.
Points: 59,283, Level: 100
Points: 59,283, Level: 100 Points: 59,283, Level: 100 Points: 59,283, Level: 100
Daily Activity: 0%
Daily Activity: 0% Daily Activity: 0% Daily Activity: 0%
very nice writeup...
Offline
Old May 5, 2006, 04:49 AM   #3
Personal Sales Rating: (7)
Kid Lancer 7's Avatar
Drives: '03 Lancer es - '01 mirage - 2008 Ford Edge
Points: 9,451, Level: 65
Points: 9,451, Level: 65 Points: 9,451, Level: 65 Points: 9,451, Level: 65
Daily Activity: 0%
Send a message via AIM to Kid Lancer 7
wow i need to do this!!... this shouldnt be a problem while the wheels are still on the car would it? just the level of comfort?
__________________
THE LANCER SAVED MITSU!!
MY REGISTRYPics!
Offline
Old May 5, 2006, 04:30 PM   #4
SRTRaceR04's Avatar
EvoLvr2006
Quote:
I would imagine it to be a huge hassle having to do this while it was still on the car. I strongly don't recommend trying this while it's on the car.
__________________
Offline
Old May 5, 2006, 06:18 PM   #5
Personal Sales Rating: (12)
PGDlancer's Avatar
Drives: quick and careful
Points: 6,110, Level: 50
Points: 6,110, Level: 50 Points: 6,110, Level: 50 Points: 6,110, Level: 50
Daily Activity: 0.2%
Daily Activity: 0.2% Daily Activity: 0.2% Daily Activity: 0.2%
again man, you rock for this!
__________________
2nd generation lancer Intake duct for sale: CLICK ME
02-03 Lancer parts for sale:
Rear drum brake shoes for sale: CLICK ME
Stock rear oz bumper: CLICK ME
K-style body kit: CLICK ME
Offline
Old May 5, 2006, 09:31 PM   #6
Personal Sales Rating: (5)
alexandru's Avatar
Drives: Mitsubishi Lancer ES '03
Points: 12,764, Level: 73
Points: 12,764, Level: 73 Points: 12,764, Level: 73 Points: 12,764, Level: 73
Daily Activity: 0%
Send a message via AIM to alexandru
very nice writeup, that's exactly what I needed. The salt ate through the polish on my polished lip also. How about making sure it stays like that ? Can I just spray the lip after I'm done with some clearcoat or something ?
__________________
Current Mods: Buschur Racing 2.5in catback (Last Catback for the OZ/ES that Buschur Racing made !), Motegi SP10's flat black, Kumho ECSTA ASX tires, RalliArt JDM grille (Thunder Gray), K&N Short Ram Intake, NGK Spark Plug Wires, RRM Race series slotted rotors, Axxis Ultimate Pads, RRM Front Strut Bar, RDD EVO RS Style Trunk Bar, OZ Rally Sway Bar w/ Deyeme bushings, s2000 antenna
Offline
Old May 6, 2006, 12:00 AM   #7
SRTRaceR04's Avatar
EvoLvr2006
Quote:
I have never added anything after the polish so I'm not sure if you can add some kind of clear coat. I don't really see why not, but I'm not sure how well it would stick to a polished surface.
Usually if you're going to (rattle) spray paint surfaces, such as rims, it's usually a good idea to scuff the surface up a little bit because it helps the paint adhere better. Now if you have a completely slick surface, it may not stick the way it's supposed to.
I have yet to have a problem with any of the pieces I have polished. I have not seen the slightest sign of rust or anything.
Here is the middle of my exhaust on my bike polished:
Then I polished the 2 ends:
It's been like this since January and I haven't seen a problem at all!!! Hope that helps!!
__________________
Offline
Old May 6, 2006, 12:07 AM   #8
SRTRaceR04's Avatar
EvoLvr2006
Here is a picture of one of the other rims I completed. It's a better pic. I think it shows how much more it shines rather than inside with artificial light. It was not a sunny day when I took the picture.
__________________
Offline
Old May 6, 2006, 12:25 AM   #9
Personal Sales Rating: (51)
Evoryder's Avatar
Drives: EVO METH MACHINE
Points: 10,961, Level: 69
Points: 10,961, Level: 69 Points: 10,961, Level: 69 Points: 10,961, Level: 69
Daily Activity: 2.9%
Daily Activity: 2.9% Daily Activity: 2.9% Daily Activity: 2.9%
sick!
__________________
TEMEVO
"I'm addicted to 100% Methanol : ) "
FP RED + SPEED DENSITY
516WHP 468WTQ
MACHINES GONE WILD
Offline
Old Jun 16, 2006, 11:27 PM   #10
Personal Sales Rating: (0)
Drives: EVO VIII
Points: 5,817, Level: 49
Points: 5,817, Level: 49 Points: 5,817, Level: 49 Points: 5,817, Level: 49
Daily Activity: 0%
Send a message via AIM to djevoawhp
wow i cant wait to doooo thissss....greatttttt writeeee- up thankss
Offline
Old Jun 19, 2006, 07:17 AM   #11
Daily Activity: 0%
the sandpaper method is great!!.. i used it on my glossblack lips that had a whole bunch of winter crap on them.. i started with a wet (soap & water) 400 grit, bumped it up to a 600 grit.. then a 1000 grit.. washed off all the crizzap lol with more soap n water.. then topped it with meguiars metal polish (get it at any car store) the shine was so immaculate.. i couldnt believe that they were my rims... even my neighbors begged me to clean theirs.... (hummm gas money for 2 weeks? ) but i declined them... cuz it was time to take my ""NEW"" rims for a spin in the busiest part of town!
__________________
MY REGISTRYPics!
Offline
Old Jun 19, 2006, 08:09 PM   #12
Personal Sales Rating: (25)
moreryce's Avatar
Drives: Wicked White GSR
Points: 5,534, Level: 47
Points: 5,534, Level: 47 Points: 5,534, Level: 47 Points: 5,534, Level: 47
Daily Activity: 1.0%
Daily Activity: 1.0% Daily Activity: 1.0% Daily Activity: 1.0%
this is used in body shops as well.. if you want to just have a quicky as long as it doesnt have big dents in it you can go from 800 to 1500... if you want to throw in some elbow grease us 2000 grit and then polish.. its'll come out straight chrome.. haha
__________________
My car owes me money...
jlbmotorsports.com
aeperformance.com
Offline
Old Jul 30, 2006, 07:51 PM   #13
EvoM Moderator
M3lachsilber's Avatar
Drives: Whatever is on the lot
Points: 52,297, Level: 100
Points: 52,297, Level: 100 Points: 52,297, Level: 100 Points: 52,297, Level: 100
Daily Activity: 0%
Nice write up..
Discuss post HERE
__________________
Geez, I havn't been on here in like forever!!
Offline
EvolutionM
Mitsubishi Lancer
Paid Advertisement
Closed Thread
Tags
blades, build, gsr, howto, lip, machine, machined, miami, polish, polished, polisher, polishing, pollish, rim, rims, turn, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
All Passwords
